Author Topic: I Made An RGB Human Circuit And I want you to explain it for me  (Read 2791 times)
Offline noah4546Topic starter
    • Noah4546 The  Website Of all Noah
« on: January 26, 2015, 07:57:53 pm »
I made an rgb led human circuit and I wonder if you could explain how this works Dave.
I Want to know how it senses that you're touching the leads?
(How the transistor read works not the output of led. I wrote the code with my friend) ;)
http://www.instructables.com/id/RGB-Human-Circuit/
Offline Phaedrus
Re: I Made An RGB Human Circuit And I want you to explain it for me
« Reply #1 on: January 26, 2015, 11:53:02 pm »
The slight difference in ground potential between your finger and the circuit ground means that your finger will produce a very small voltage on the base of the transistor. This is enough to turn the transistor on, which pulls the I/O pin on the MCU low.
The site recommends a normal NPN transistor, but these circuits normally work better/more reliably with a darlington or sziklai transistor pair, as they give a much higher gain, which will better amplify the tiny voltage applied to the base (though keep in mind transistors are transconductance devices)
« Last Edit: January 27, 2015, 12:23:01 am by Phaedrus »
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
