Author Topic: EEVblog #72 - Let_s Design a Product ( uCurrent )  (Read 1729 times)
Offline Tioleco
« on: June 10, 2011, 12:52:13 am »
Have some questions about the uCurrent:
1 - Changing the supply voltage is necessary to change the value of some component?
2 - Can I use discrete components instead of SMD (for capacitors and resistors)?
3 - Using linear DC power supply with common transformer , there would be a noise problem that would hamper the performance of the circuit?
4 - If this problem ( burden voltage ) is already well known , because the manufacturers no longer incorporate a circuit like this in their multimeters?
Offline sacherjj
Re: EEVblog #72 - Let_s Design a Product ( uCurrent )
« Reply #1 on: June 10, 2011, 01:35:46 am »
Yes.  At the minimum, the LED current limit resistor and all the low voltage detection.
Yes, but if you are doing SMD for the ICs (which is the only option) then resistors and caps aren't too hard in 0805 packages.
Absolutely.  It will run for 10 hours with a battery, why do you need to use AC power?  The noise on a circuit this sensitive will most certainly be a problem unless you filter very well.
It is impossible to have this circuit accurate and protected.
