Author Topic: EEVblog #742 - Why Electrolytic Capacitors Are Connected In Parallel  (Read 28380 times)
Offline EEVblog
Fundamental Friday
Dave explains why some designs have electrolytic capacitors connected in parallel. The answer is more in-depth than you might think.
9 reasons are given and explained, and then some thermal camera fun on the bench.
Rubycon capacitor datasheet: http://www.farnell.com/datasheets/1910904.pdf
NOTE: Video #741 has been skipped for a reason.
https://www.youtube.com/embed/wwANKw36Mjw
« Last Edit: May 09, 2015, 12:38:45 am by EEVblog »
Offline radioFlash
Nice video Dave, but there is one quibble: the heat dissipation will be dominated by conduction and convection with air rather than block body emission at these low temperatures.
Offline fusebit
When do we see the video about the LM741? :-+
Offline rs20
Great video, I learned a lot! One thing that still irks me is when I see a schematic published/shared that just shows "2x 470uF". If it said, "2x Panasonic 470uF model XYZ", or "1000uF with < 0.1 ohm ESR" then that would be somewhat rational. But otherwise, surely there's a wide range of performance characteristics for both 470uF and 1000uF capacitors -- there must be 1000uF capacitors out there with a way better ESR than 2x some marginal 470uF capacitors. If the original designer looked at what was available in the catalogue and concluded that 2x 470uF was the way to go back in 1973, isn't it likely that what's in the catalogues has changed since then?  I'd almost (but not quite) go so far as to say that this is a question of component procurement and selection at the time of production, not something that belongs on a timeless schematic. Stating a max ESR seems like a far better approach.
Or am I wrong, is there some sort of universal accurate standard for how much ESR a "decent normal" cap of a given voltage and capacitance has?
« Last Edit: May 09, 2015, 04:35:54 am by rs20 »
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
What happened with the DIY Current sink at the End of the Video?
Is the 100mA Current raise to show the temperature diference better or is it drifted away?
Offline Refrigerator
  • Country: lt
Dave you did it again ! Where did 741 go ?
Just started a blog at http://brimmingideas.blogspot.com/ . Not much in it as of now but more is sure to come :)
Offline Barny
  • Country: at
Look at his twitter account:
https://twitter.com/eevblog/status/596802022814384128
He want to show a special video.
Offline EEVblog
Shh, don't tell the nerds who are busy trying to calculate it  ;D
Offline EEVblog
Oh, I upped them both to 300mA off camera but didn't do anything with that.
Offline EEVblog
For sure, massive differences.
You'll see specific brand and models in the DC-DC converter datasheet like the one I showed, but without that you are left to guess why.
Offline EEVblog
Re: EEVblog #742 - Why Electrolytic Capacitors Are Connected In Parallel
« Reply #10 on: May 09, 2015, 06:52:37 am »
No idea. We tried to build something novel but in practice it didn't work. So have to go with a whole new idea.
David2 etched a board and everything.
Offline errsu
« Reply #11 on: May 09, 2015, 08:33:42 am »
The datasheet gives longer livetimes for larger diameters. This goes in the opposite direction of the temperature reduction when splitting into multiple capacitors. To know which effect is dominant, the actual dependency of the livetime from temperature would be needed, in numbers. Hmmmm...
[rsu]
Offline Towger
  • Country: ie
« Reply #12 on: May 09, 2015, 10:19:54 am »
The same place as 666.
Offline rs20
« Reply #13 on: May 09, 2015, 12:42:35 pm »
An often-stated rule is that electrolytic cap lifetime doubles for every 10 degrees C reduction in temperature. Interestingly, some solid electrolyte capacitors claim more than a tripling of lifetime for each 10 degree reduction in temperature, which really stacks up if your capacitor is rated at 105 deg C and you're actually using it at, say, 65 degrees (theoretically, 2000 hour cap at 105 degrees --> 32,000 hour cap at 65 degrees for normal cap, 200,000 hour cap for solid cap).
So there you go, have a play with that model. Clearly, which effect is dominant depends on how hot the original single capacitor would get.
But thanks for pointing that out, I hadn't considered that all the surface area of all those smaller capacitors actually means more surface area for them to dry out and age (who knows if that's really the underlying cause, but seems like a nice idea in my head). Key point is, using multiple smaller capacitors might be a strongly bad idea in some circumstances if you don't keep lifetimes in check.
« Last Edit: May 09, 2015, 12:45:37 pm by rs20 »
Offline Stupid Beard
« Reply #14 on: May 09, 2015, 01:11:20 pm »
:-DD
Offline EEVblog
« Reply #15 on: May 09, 2015, 02:07:40 pm »
Yeah, I should have mentioned that one.
On a look at the video again there is a lot of stuff I left out actually.
Offline EEVblog
« Reply #16 on: May 09, 2015, 02:11:56 pm »
If lifetime is your goal then you parallel up the best and longest life ones you can get, you wouldn't shoot for the smaller size just because you can.
Higher voltage also gives longer life, so rise and repeat your options again and again for each design criteria.
Messy business.
Offline bktemp
« Reply #17 on: May 09, 2015, 02:45:26 pm »
Do a follow up.
A follow up would be great. Then you can go a bit more into detail how to calculate/estimate the ripple current and power dissipation inside a capacitor.
Buy one of those, load it with the maximum specified current and measure the temperatur to show how not to design a circuit:
https://www.eevblog.com/forum/projects/adjustable-buck-voltage-regulator-aliexpress-exiciting-finds/
Offline NiHaoMike
    • Facebook Page
« Reply #18 on: May 09, 2015, 05:28:57 pm »
On a related note, there's a similar reason to parallel batteries.
« Last Edit: May 09, 2015, 05:30:55 pm by NiHaoMike »
Offline dentaku
« Reply #19 on: May 09, 2015, 08:12:55 pm »
I love these educational videos. :-+
Offline smashIt
« Reply #20 on: May 09, 2015, 08:23:23 pm »
you also didn't tell them to use the absolute temperature in kelvin
I guess they will be really pissed :D
Offline Tomorokoshi
« Reply #21 on: May 09, 2015, 10:01:12 pm »
In parallel configuration, if the failure mode of one of the capacitors is lower capacitance then we have a nice way of constructing some redundancy into the circuit.
What if the failure mode is a short?
Can we rely on the increase in individual reliability to outweigh the increased chance in failure now that more parts are in the circuit?
I wonder where the cross-over point is?
Offline Alexei.Polkhanov
« Reply #22 on: May 10, 2015, 04:20:18 am »
I find that one big chunk of information about electrolytic caps is missing - Bipolar Capacitors. Where and why you may use them etc. Maybe it is a good subject for another capacitor video?
Offline c4757p
  • adieu
« Reply #23 on: May 10, 2015, 04:35:38 am »
Aluminum electrolytics generally do not fail short unless the failure is caused by overvoltage or reverse polarity.
Offline bookaboo
  • Country: ie
« Reply #24 on: May 10, 2015, 08:39:19 am »
Agreed
