No one's posted about this yet, but every time you said e-ink, I cringed. Pebble is not e-ink, at all. E-ink is magnetic beads, is slow, takes no power to display a static image, and any light for it is a front light. Pebble uses e-paper (which e-ink is technically a part of, but that's beside the point). It uses a Sharp Memory LCD. It can be backlit (like in the pebble), but it is also great in direct sunlight. The memory LCD also takes nanoamps of current to hold a static image, but up in the milliamps to update the display (and the display in the Time is updated by column, so if you have a watchface with a seconds hand, it's gonna have to update a lot of the columns every second, and that will really hurt battery life). It can also do a decent framerate, unlike most e-inks.
Also, you said you plan to do a teardown. FYI if you tear down the pebble time, you will not be able to use it again most likely. ifixit did a good teardown (with some assistance / commentary from some pebble engineers too, that hopefully will earn them some credibility in your book).
Overall, knowing a ton about the pebble, and having used the OG pebble since the first kickstarter, I was quite disappointed in this video.
