Dave, the Pebbles are all designed for continuous submersion (though not with button pressing while submerged, at least not on the old Pebbles). http://help.getpebble.com/customer/portal/articles/1850071-water-resistance
I'm disappointed that you talked about the water resist so much when you've got it misunderstood. At least you got the mic and the LCD correct this time around.
I do know what I'm talking about, I simply hadn't read all the detail, which apparently is
only available in a Reddit feed.
That page you pointed to says nothing about any standard, nor does their website it seems.
It seems Pebble are using the new ISO2281:2010 standard, not the usual (older) ISO2281 standard.
Basically in the watch industry when you advertise something as having "30m water resistance" (you should use the term "proof") it means exactly as I stated based on the ISO2281 standard practically the entire industry uses. It's not hard to misunderstand huge info graphics on their main page screaming "30m water resistance", and then assume that means the same thing as when practically
everyone else in the industry uses the same term.
And based on my 10+ years experience designing underwater marine electronics I reckon their claim of 30m continuous immersion rating is suspect.
