Author Topic: EEVblog #764 - New Lab Ceiling LED Lighting Installation  (Read 20129 times)
Online EEVblogTopic starter
« on: July 10, 2015, 04:20:41 am »
Dave installs a new LED lighting system in the EEVblog lab, with 9 x 60W 600mm 5000k ceiling LED panels.
A look at hermaphroditic connectors.
What kind of lux improvement is there on the bench?
Has the colour rendering index (CRI) changed things?
They cost how much?
A look at Lifud brand LED drivers, with mini teardown of course:
http://www.lifud.com/En/index.aspx
http://www.lifud.com/En/product_detail.aspx?ProductsID=371&CateID=275
Offline steve30
    • Stephen Coates' Homepage
Re: EEVblog #764 - New Lab Ceiling LED Lighting Installation
« Reply #1 on: July 10, 2015, 05:38:46 am »
Very nice Dave.
Wouldn't mind some of those LED panels for here at home, but for now I'll stick with fluorescent.
What happened to your high quality NEC fluorescent tubes?
Offline twistedresistor
« Reply #2 on: July 10, 2015, 05:49:14 am »
Hi Dave.
Two questions about your latest video:
Can you tell us where you sourced the LED panels from?
Did you catch the brand of the little green electrolytic capacitors in the lifud LED driver? Are those Capxon/Samxon?
Offline piranha32
    • random ramblings of an engineer
« Reply #3 on: July 10, 2015, 05:54:42 am »
The connector looks like a clone of Anderson Powerpole connector
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #4 on: July 10, 2015, 06:14:22 am »
I liked this video and the audio was excellent, the lighting needed some work, oh look he did it..... :-DD
Your videos would be much brighter if you were to wear a hawaiian shirt, otherwise it all looks good.... :-+
Best Regards and Nice Job.
Muttley
« Last Edit: July 11, 2015, 02:01:17 am by Muttley Snickers »
Offline Floyo
« Reply #5 on: July 10, 2015, 06:18:38 am »
Hey Dave, I don't know if you fixed the RF switches yet, but you could try putting them a bit further apart. I have some of these kind of units that are popular over here,
and their manual instructs at least 50cm between modules. Testing confirms that they go haywire when mounted closer together, not responding properly etc.
said manual (in Dutch), page 5 (4 on the "paper" itself):
https://www.klikaanklikuit.nl/files/handleidingen/apa3-1500r_nl_updated.pdf
« Reply #6 on: July 10, 2015, 07:45:22 am »
Ironically I look shit in this video because I'm not standing at the best lighting angle  :palm:
« Reply #7 on: July 10, 2015, 07:46:17 am »
I don't understand why that would be? They are just receivers after all.
Offline bktemp
« Reply #8 on: July 10, 2015, 07:55:26 am »
Almost every receiver contains at least one oscillator. Cheap RF remote controls use something similar to a regenerative receiver and those are actually small transmitters:
https://en.wikipedia.org/wiki/Regenerative_circuit
« Last Edit: July 10, 2015, 07:57:26 am by bktemp »
Offline ElectroIrradiator
  • More analog than digital.
« Reply #9 on: July 10, 2015, 08:11:28 am »
The detectors are quite likely (pretty much guaranteed to be) super-regenerative, a configuration which is a notorious wideband noise emitter at the receiving/signal frequency. They are supposed to be properly shielded via an appropriate enclosure, an isolating RF preamp etc. Otherwise one active detector can easily completely swamp an adjacent one with RF radiation, rendering one or even both of them completely useless. But frequently - and perhaps unsurprisingly - they lack shielding.
Count your blessings if you can get a pair using the same frequency band to work in the same room. Working at 50 cm separation? Awesome! 8)
« Last Edit: July 10, 2015, 08:14:17 am by ElectroIrradiator »
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #10 on: July 10, 2015, 08:16:32 am »
Do you have a link to where you bought the panels from?
Offline Floyo
« Reply #11 on: July 10, 2015, 08:20:21 am »
Something like that seems to be the case, the circuitry inside these modules is rather basic and crusty, and the housings have no shielding whatsoever, so some kind of signal might easily get out.
A little quick and dirty test with an RTL-SDR dongle (closest thing I have to a spectrum analyser), "antenna" is an bnc to aligator clip lead with the lead shorted out into a single winding, which is put around the body of the receiver. The four dark spots at 433.92 are the signals from the transmitter from about 1m away. The huge dark red band is when I switched on the receiver. This is by no means a properly controlled test, but it suggests that the receivers do transmit. I kind of expected a cleaner tone to come out of it.
« Reply #12 on: July 10, 2015, 08:23:25 am »
Yep, moving them apart did the trick. Argh.
Offline george graves
« Reply #13 on: July 10, 2015, 10:24:21 am »
Good compromise.  I like!  I never noticed too much noise in your videos - but for tiny chip camera, more light, the better.
Well done. Actually, colors should pop more with the lighting. Not bad for a consumer camera.
Offline peter.mitchell
« Reply #14 on: July 10, 2015, 10:54:02 am »
not quite. these are ganged, non separable connectors whereas andersons are single gangable connectors.
http://uk.anen-power.com/UploadFiles/SA2-10/SA2-10guigeshu2.jpg
 the same company does make clone anderson connectors though.
Offline Dave Turner
« Reply #15 on: July 10, 2015, 12:22:01 pm »
Dave I noticed that you've removed the tube lighting that was over your bench. Whilst I understand that they weren't ideal for videoing; wouldn't they still have been useful for when you do any soldering etc? I would have thought that with the light behind you your own shadow could be an issue.
regards
Dave
« Reply #16 on: July 10, 2015, 01:12:32 pm »
Not really, shadowing is minimal because it comes at all angles from the complete strip. I now have more light on the bench than I did before.
If I wanted more light for soldering it would be better to simply add a LED strip under the shelf rather than high up on the roof.
I also have lights on my Tagarno and Mantis for soldering.
Offline piranha32
« Reply #17 on: July 10, 2015, 01:13:16 pm »
There are also ganged, non-gangable andersons. The ones on the Dave's panels are not exact copies, but clones using the same principle.
Offline plexar
« Reply #18 on: July 10, 2015, 01:39:50 pm »
Dave,
I'm looking to do a similar installation in my basement to replace some florescents.  What brand of panel did you get and where did you get it at such a good price?  I tried searching online and did not see anything comparable.
Thanks,
Plex
« Reply #19 on: July 10, 2015, 01:47:28 pm »
http://www.lumin-lighting.com/
Offline N2IXK
« Reply #20 on: July 10, 2015, 01:50:08 pm »
Some MAJOR differences in electrical wiring codes between OZ and here in the states, that's for sure.
All those flexible cords and power strips would be prohibited above a drop ceiling here in the US.  And a tenant could never do that kind of work in a rental space. The only place where a licensed electrician isn't mandatory is to do work in a building that you both own AND occupy as a residence. Commercial office space or a building that you rent out would both require hiring a sparky to do the work.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #21 on: July 10, 2015, 03:43:48 pm »
...not enough light for video work...
Maybe you should get some REAL lights in there? :)
Just kidding... unless you want to do high speed videos next, that is.
Offline eneuro
« Reply #22 on: July 10, 2015, 09:45:48 pm »
Quite nice panels, but isn't its light too directional, especially when all of them placed on roof at the middle of the room?
It looks like, there is much more lumens now, but shadows too  :-\
It is a lot of light in the room, but it is not uniformly distributed. Additionally those panels are very thin and flat, so not too much light for room walls and I do not know, but those corners looks very dark.
When looked into this specyfication of maybe similar 40W panels http://www.lumin-lighting.com/products/441_Platinum-Series-LED-Panel-Light.htm we get among others such parameters:
Lamp Rated Total Power:         40 W
200 Pieces of SMD LED 4014
Beam Angle:     120°
this means that there is 30° degs shadows on the walls, so when this room is maybe 4m wide with those panels inside, there is let ssay 1.5m from those panels to wall roof, than we get shadows on the walls: tan(30°)*1.5~0.9m ~1m from roof with very poor lighting conditions and this effect seams to be visible on top left roof wall corner in spotted photo   :-//
Quite interesting decent power LED panels, however I'd rather made measurements of room roof, than if we know what beam angle is and how many such panels we have, than simply I'd like to make rather otimization using eg. Monte Carlo method, to randomly locate them in all posible places on the roof (but in software of course  >:D) and by calculating in room areas of interest expected luminance from all placed panels, I could choose combination, which probably will create more uniformly distributed light from those flat thin LED panels  :phew:
But ok, just only thinking on possible ways to optimise placement of those panels on the roof, since their mechanical construction and beam angle can affect overall lighting conditions in the room. Probably I will try to do it this (maybe hard) way, but when we have such amount of light, than such effort to simulate in virtual reality first might be worth to try  :popcorn:
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
Offline German_EE
« Reply #23 on: July 10, 2015, 09:57:39 pm »
I was thinking that as well. Dave, when you rented the place was the drop ceiling in place or did you put it in? If it's 'Dave made' you might be covered.
Warren Buffett
« Reply #24 on: July 10, 2015, 11:34:57 pm »
Nope, works fine for all practical purposes.
I'm not concerned with shadows in the corner.
You have to remember that my requirements are different to your average person.
