Author Topic: EEVblog #765 - LED Panel Lighting Switching Noise  (Read 21245 times)
Offline EEVblogTopic starter
« on: July 12, 2015, 12:41:58 am »
A follow-up to the previous video checking if there are any noise issues with the new lab LED panel lights.
And a noise comparison with the old LED lights.
LED Lighting Install Video:
Common Mode Noise Video:
Offline jcreedon
Re: EEVblog #765 - LED Panel Lighting Switching Noise
« Reply #1 on: July 12, 2015, 01:32:55 am »
Was the noisy plug-pack identical to the other non-noisy ones?
Maybe do a tear down of a good one and the bad one and compare the two and do a post-mortem?
Offline bktemp
« Reply #2 on: July 12, 2015, 05:22:11 am »
+1 for the teadown and further investigation. Please show us the indside of this device.
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #3 on: July 12, 2015, 07:14:20 am »
Yeah I was hoping for that too.
Being a Chinese POS, I wonder if it's just a fault of assembly (part not soldered correctly) or something more sinister, like parts entirely left our.  I'm very curious to see.
It's not always the most popular person who gets the job done.
« Reply #4 on: July 12, 2015, 11:27:46 am »
More likely the caps inside were the low end of the curve on lifetime and simply failed faster than the rest. You probably would find all are leaking and popped, while the others are also losing the fight and just held on for longer.
« Reply #5 on: July 12, 2015, 11:41:47 am »
You get what you pay for. No need for that kind of language though.
I'll use whatever language I like.
Offline nixfu
« Reply #6 on: July 12, 2015, 05:54:10 pm »
+2.  Have Dave2 fish it out of the trash and lets find out why its different than the others.
Offline woox2k
  • Country: ee
« Reply #7 on: July 12, 2015, 07:06:02 pm »
+3 Please make a follow-up video showing us the insides of that crappy power supply. This should be very educational of how not to build a power supply.
Offline darrylp
« Reply #8 on: July 12, 2015, 07:17:08 pm »
Yep I'd say, let's see what is needed to fix the noise. I'd guess its poor caps, but would be educational I'd think.
Sent from my Nexus 7
Offline apis
  • Hobbyist
« Reply #9 on: July 12, 2015, 07:27:10 pm »
Mhm, a post mortem would be very interesting. :D
« Last Edit: July 12, 2015, 08:19:10 pm by apis »
Offline mikerj
« Reply #10 on: July 12, 2015, 09:08:01 pm »
It was hardly terrible language, are you American by any chance?
BTW. is your sig supposed to be ironic or did you just get it wrong?
Offline David_AVD
« Reply #11 on: July 12, 2015, 09:09:43 pm »
My guess would be the output capacitor on the PSU has gone low capacitance and/or high ESR.
Offline Someone
    • send complaints here
« Reply #12 on: July 13, 2015, 02:00:04 am »
mojo-chan seems to live in the UK but has spent a lot of time in Japan, but then uses US terms and politics a fair bit. Educated in the US perhaps?
Offline ez24
  • L.D.A.
« Reply #13 on: July 13, 2015, 03:00:50 am »
Since the PS ended up in a wok, will there be a cook off ?  I just love cook offs, but I suggest do it outside because of the fumes.  Wasn't it an Australian who ate a bicycle (I wonder if he is still alive)?  If so a PS should be no problem for an Aussie especially if it is cooked in a wok.  Go ahead Dave, eat it ha ha ha.
Offline pickle9000
« Reply #14 on: July 13, 2015, 03:11:48 am »
PS remedies
- bury it
- hit it with a big hammer
- drive over it with a compactor
- find it a nice place to rest (land fill)
To be honest I don't really find the supply all that interesting.
« Reply #15 on: July 13, 2015, 09:33:33 am »
Yup, 99% chance. That's why it's only a problem under load.
Offline steves
    • Telecnatron
« Reply #16 on: July 13, 2015, 09:41:03 am »
And I'll defend to the death your right to use it, even if you are a ******* ****.
« Last Edit: July 13, 2015, 09:51:40 am by EEVblog »
Online Fungus
« Reply #17 on: July 13, 2015, 09:58:43 am »
No.
Yes you did.
You can argue all day over the definition of "kilo" (and nobody will change their mind).
"kibi", OTOH, is always 1024. The "bi" part of "kibi" was invented for that purpose.
Online Monkeh
« Reply #18 on: July 13, 2015, 11:48:38 am »
No.
Yes you did.
Please don't feed mojo-troll.
Offline JonnyBoats
    • BitsConnect
« Reply #19 on: July 13, 2015, 03:36:00 pm »
Dave, why did you use an oscilloscope rather than a spectrum analyzer to look for interference from the switching power supplies? When looking for unintentional radiation isn't it quite possible that it could be limited to specific frequencies at relatively high levels while still having relatively low levels of broadband radiation?
Offline f4eru
    • Chargehanger
« Reply #20 on: July 13, 2015, 05:49:45 pm »
+1 for the spectrm analyzer, or, at least, the FFT mode of the scope...
If it were easier a vast amount of stuff could be saved from landfill.
If it were easier, a lot of people would get shocked by primary caps, and would repair dodgily the broken secondary wires (and some people really solder badly, which would endanger the class II isolation...
Basically hit the side with a hammer, shatter the glue.
it's not glue. it's laser or ultrasonically welded. I prefer to "gently" pop it open by deforming one half with a bench vise. Does not look good after that, but it'S far less messy...
Online Monkeh
« Reply #21 on: July 13, 2015, 05:51:54 pm »
Padding with leather or thin pieces of wood helps with the pretty problem. If you can avoid actually marring the surface, the shape is rarely affected.
Offline bitwelder
« Reply #22 on: July 13, 2015, 08:38:01 pm »
It was the first instrument available that could still show the issue during a quick video shooting?
Offline electronic_eel
« Reply #23 on: July 13, 2015, 09:06:39 pm »
+1 for a teardown of the bad power supply.
Must not be the ESR of the caps. Another possibility is that they forgot to install the Y-cap connecting primary and secondary.
Online Monkeh
« Reply #24 on: July 13, 2015, 09:56:16 pm »
Please don't troll/stalk me.
I am doing neither, but it's nice you think you're special.
