There are other people in this thread discussing what happens when the battery has been discharged to 0.8V or below, but they are not the people worrying about the large white rectangle (as you would expect, since the large white rectangle has absolutely nothing to do with what happens when the battery is discharged to 0.8V or below).
Dave already explained that:
https://www.eevblog.com/forum/blog/eevblog-772-how-to-calculate-wasted-battery-capacity/msg719534/#msg719534
It makes no difference if you extend it to 0V or cut it at 0.8V because after 0.8V it just discharges way too fast, maybe you get half a percent extra if you are lucky.
Please oh please at least
try to comprehend what you read before you respond. There are
other people arguing over how much energy remains in a cell once it discharges to 0.8V, silvas and I are making no claims at all about this. For the record, my personal opinion is that it is
negligible, I'll happily call it
zero or
half a percent, whatever you like. I'd be extremely surprised if silvas disagreed on this point.
The actual issue is whether when someone tells us that the "area under the (discharge) curve is energy" we are meant to take it seriously or not. And people do draw pictures of areas and say this.
If we're not meant to take the phrase seriously, then why would people say it? My best guess would be that it's just part of the ritual passed down from electrical engineer to electrical engineer, and you have to say it, otherwise the blue magic smoke might escape or something. In other words the whole thing is just "cargo-cult calculus".
I happen to think that we are meant to take the phrase seriously --- we ought to be able to measure areas, compare areas, and come up with the right results. Our claim is that to get sensible answers out of such procedures, those areas have to be taken down to the 0V line. If you don't do this, if you instead only extend the area down to the 0.8 V line, you can't take the notion that area corresponds to energy at all seriously. Look for an earlier post where I show for example that you end up concluding that you can draw 0.1 watts for over 20 hours from a cell with a capacity of less than 1.8 watt hours --- nonsense.
Now, there are a few possibilities:
1) It turns out we're wrong. So far everyone who says this simply attacks the
straw-man about energy left in the cell after it's been discharged past 0.8V. How about instead showing me the "right" way to compute the "area under the curve", without that area extending below 0.8 V, so we don't get a violation of the law of conservation of energy.
2) We're not meant to take "areas under curves" seriously, it's just some meaningless words we say. Then wouldn't it be better to stop saying those words, stop drawing pictures of the energy being an area under the curve and save everyone a lot of time and confusion?
3) We're right, but it doesn't matter, because using the "incorrect" areas either results in the same answers for the problems we've been talking about since whilst the area representing the unused capacity of the cell is smaller than it should be, so is the area representing the total capacity of the cell, and these two effects cancel out either exactly or approximately. The problem is that they don't cancel exactly, and they generally don't even cancel approximately most of the time --- I earlier gave an example which when calculated using only the areas above 0.8 V gave an unused capacity of 25%, when calculated using what I claim were the correct areas gave an unused capacity of approximately 42%. As an approximation, being nearly a factor of two out is pretty bad for this application.
4) We're right, but so what? "We like to draw the area only down to 0.8 V, but everyone knows you have to extend right down to 0 V." Well, many of the cases in which the argument has been used has been to refute (for example) the claims of Batteriser. I think its fairly safe to guess that much of the intended audience for these arguments can't necessarily be expected to know that the areas drawn on the graph are not really the areas that need to be compared --- wouldn't it be better not to mislead that audience? Even worse however, the effect of comparing the wrong areas substantially
underestimates the capacity left in the cell. It will look like mendacity on your part when your opponent points this out --- straight out of
How to Lie with Statistics. A much better strategy is to use the depiction that more straightforwardly tells the truth, so that you don't give the likes of Batteriser ammunition to use against you.
5) We're right, and it turns out that some engineers have been wrong about this point. Well, great, because once they learn they have been wrong, they will stop being wrong in the future and as a result be slightly better engineers. I would like there to be better engineers, because a lot of the stuff that I use in my life gets made by engineers. If engineers are better then I get to have nicer stuff.
