Author Topic: EEVblog #828 - Siglent SPD3303X precision Lab PSU Teardown  (Read 63031 times)
Offline Macbeth
Re: EEVblog #828 - Siglent SPD3303X precision Lab PSU Teardown
« Reply #150 on: December 20, 2015, 01:15:44 am »
errrr wait a minute, even the screw thread got torn out?
Broke at the wire hole... the holes that Dave criticized for being too small!
Not fit for purpose it appears. What are they made of, the cheapest die-cast crap painted over or what?
Offline orin
« Reply #151 on: December 20, 2015, 03:10:02 am »
No idea about the base metal.  Shiny, so probably plated with something - nickel perhaps?
« Reply #152 on: December 20, 2015, 04:38:06 am »
Brass, but the wall thickness is so thin that it simply snapped at the thinnest part at the root of the thread, where the wall had the least area in the hole. Basically they are too thin in the wall, and need to be made larger in diameter, along with making the inner hole the correct diameter to fit the standard socket.
Basically the manufacturer took too much brass off, to cut the cost of the material used in the individual item. They probably charged Siglent the cost of the length of brass used to machine the post, adding the cost of the plating as well. The manufacturers gross profit comes from the removed brass as scrap metal to be remelted, probably around $7 per kilo.
Offline orin
« Reply #153 on: December 20, 2015, 04:59:02 am »
Make a lot of sense... although now useless as a binding post, the remaining hole is still deep enough to accept a banana plug.  Deep oversized hole = more removed material to scrap.  If the hole wasn't so oversized, the binding post might have survived shipping!
Offline madires
  • A qualified hobbyist ;)
« Reply #154 on: December 20, 2015, 01:40:49 pm »
And Siglent just wants to address the mains wiring issue while missing the gorilla at the front door.  :palm:
Offline rs20
« Reply #155 on: December 21, 2015, 10:35:11 pm »
Got a 5 mm hole for wire...
Er, how do you tighten down after you've placed the wire through the hole? Or are you supposed to just poke it in there and hope?
It looks more to me like that's supposed to be a right-angle banana jack hole. Sure it's not 4mm?
Offline Smokey
« Reply #156 on: December 22, 2015, 01:40:08 am »
There is always hope my friend!
Its just to screw around a little and the wire stick!  ;)
The end holes are 4mm.... so they fit a banana plugg...
But is it RoHS???????:)
Offline Circlotron
« Reply #157 on: January 09, 2016, 02:10:54 am »
Not sure if some already mentioned it, but in Australia at least, don't the regulations require that if you can come in contact with the output of a transformer then the primary and secondary have to be segregated as is commonly done with an EI transformer? How does a toroidal measure up in this regard?
Offline orin
« Reply #158 on: January 12, 2016, 09:52:17 pm »
Just a quick note to let everyone know that the Siglent engineering team does pay attention to your comments and suggestions. They have informed us that they are addressing the SPD3303X/X-E internal wiring placement & dressing issues pointed out on Dave's video.
Thanks
Steve
They really need to address the binding posts - see attached picture of a SPD3303D as it arrived from Tequipment.  Still haven't heard back from then what they intend to do about it...
After consulting with Siglent, TEquipment sent a replacement.  It replacement arrived today and appears to be in good shape.
A contributing factor towards the failure was immediately obvious.  The dense foam packing for the replacement has a cutout for the binding posts.  The original foam packing did not and obviously interfered with the binding post.  Presumably they used the packing meant for the rear of the instrument at the front of this particular instrument.
Orin.
Avid Rabid Hobbyist
Offline hipfan75
« Reply #160 on: April 14, 2016, 10:34:53 pm »
New FW for these PSU's:
http://www.siglentamerica.com/USA_website_2014/Firmware&Software/firmware/SPD3303X-P02.02R2.rar
The UI is much improved with the new firmware. It now simultaneously displays both the set values and actual readings. I've attached a couple of photos.
Regards,
HipFan75
« Reply #161 on: April 15, 2016, 12:43:10 am »
Regards,
HipFan75
Welcome to the forum.
Thanks for taking the trouble to register here and offer feedback.  :-+
At the time of this edit, Siglent websites had not been updated to show the new UI you've provided pics of:
« Last Edit: February 17, 2017, 09:42:58 am by tautech »
Avid Rabid Hobbyist
« Reply #162 on: December 29, 2016, 08:12:27 pm »
New Firmware for SPD3303X and X-E models.
http://www.siglentamerica.com/gjjrj.aspx?id=15
From the changelog:
Summary of Changes:
1) Add the CH3’s SCPI control command.
2) Fixed a design bug about voltage setup.
3) Remove the screen saver.
« Last Edit: April 13, 2017, 09:11:38 pm by tautech »
Avid Rabid Hobbyist
Offline JohnG
« Reply #163 on: April 13, 2017, 08:34:50 pm »
I have found a new problem with the SPD3303X-E, I think.
I bought the SPD3303X-E in part because I needed to be able to control it remotely and because I have been very happy with my SGD2042X.
However, I cannot reliably communicate with it. I am using Python 3.6 with Pyvisa 1.8 on a 32 bit Win 7 machine, using the latest Keysight Visa libraries, over USB. I have no problems talking to the SGD2042X, or any of my other equipment. But, I cannot talk reliably to the SPD3303X-E. If the default settings are used in Pyvisa, a supply.query('*IDN?') command times out. I got as far as finding out that it does not like the default write_termination of '\r\n', and I have to force it to '\n'. Sometimes it still seems to hang, and if I want to talk to the supply, I have to power it down and restart it.
Software: 1.01.01.02.03
Hardware: V3.0
Like I said, no issues with the SGD2042X, or any other equipment. Disappointing, because I bought this specifically for remote control purposes. Anyone have any ideas?
I would really not like to install NI-Visa to see if it works better. I have an Agilent USB-GPIB that I also need to use, and I have had repeated bad experiences with NI software, including one that required restoring my machine.
Any help appreciated.
John
« Reply #164 on: April 13, 2017, 09:21:10 pm »
John, there are some changes coming for many instruments to allow direct control without the need for any 3rd party software. Just where the SPD3303X and X-E fit into the FW update schedule for this I yet don't know.
Could the Labview drivers be of assistance in the meanwhile or do they need VISA too ?
http://siglentamerica.com/gjjrj-xq.aspx?id=3619&tid=204
Siglent USA have a team of techs that can look into this in detail for you.
Avid Rabid Hobbyist
Online FrankBuss
    • Frank Buss
« Reply #165 on: April 13, 2017, 11:21:23 pm »
The USB code is not the best. It works if you add delays after sending the commands:
https://www.eevblog.com/forum/metrology/raspberry-pi23-logging-platform-for-voltnuts/msg1094066/#msg1094066
Offline JohnG
« Reply #166 on: April 14, 2017, 01:53:49 am »
Thanks, I avoid Labview. Direct control is of less interest to me personally, because pyvisa forms a consistent framework. I have other equipment that I also communicate with, so a different method means I spend more time coding, which is not really my strength nor interest. That's just me, though, I'm sure others have probably been asking for it.
Thanks for this. I was looking for something like this for a while, but didn't find it. While I don't like the slowness, it will work for now. Do you have any idea if it will be any better through a LAN connection? I have to learn how to do that anyway to talk to my scope.
John
Offline Siglent America
« Reply #167 on: April 14, 2017, 05:30:56 pm »
PM sent
« Reply #168 on: August 24, 2017, 08:17:00 pm »
We now have the correct imagery on all Siglent websites showing the GUI as it is in latest firmware versions.
For some time now the display has shown dialed in values AND actual real time load values.
http://www.siglentamerica.com/pdxx.aspx?id=1393&T=2&tid=17
« Last Edit: August 24, 2017, 09:12:34 pm by tautech »
Avid Rabid Hobbyist
Offline belba
« Reply #169 on: November 10, 2017, 10:06:24 pm »
Hello,
I own a Siglent SPD3303S but the Firmware is marked the Device as a SPD3303D. The power supply shows only 2 digits after a V/A value, for example 3.00V instead 3.000V.
I have more Mysteries about my power supply Version:
At http://www.siglent.com/ENs/prodcut-dbjg.aspx?Proid=529,1142,&tid=17&id=1132&T=2 the difference between a 3303S and a 3303X ist the output voltage/current. A X-Model should have a max voltage at 32Volt and a max current at 3.2 Ampere, a S-Modell should have only 30 Volt and 3 Ampere.
If you look at my model, I have the higher output values like the modern X-model
My questions are following:
  • I have Paid for a S-model but I have not the higher resolution at the display, how can I get the higher resolution?
  • Which kind of model I own now? A SPD3303S-, SPD3303D-, SPD3303X- or a SPD3303X-E-model
  • I would like to have also the improved firmware too and I'm very shure, that the Hardware is not really different between the models, is there a improved firmware for my, whatever model, aviable?
« Reply #170 on: November 10, 2017, 10:14:18 pm »
Hello,
There's two very similar firmware versions for the S and D models, both are 6R2 versions.
Be sure to install the S version, you can find it here:
http://siglentamerica.com/gjjrj-xq.aspx?id=1223&tid=15
Avid Rabid Hobbyist
Offline Smokey
« Reply #171 on: November 10, 2017, 11:57:28 pm »
What is the highest rate that I can remotely change the output voltage on one channel and read the current on the other channel?
For background, see https://www.eevblog.com/forum/testgear/rigol-dp832-remote-command-update-rate/
Offline Smokey
« Reply #172 on: November 14, 2017, 12:39:32 am »
Just one bump in case anyone knows the remote update rate of this thing...
« Reply #173 on: April 27, 2018, 08:27:59 pm »
New 5 min vid on these PSU's.
https://youtu.be/H-BiphMqp5g
Avid Rabid Hobbyist
Offline hkBattousai
« Reply #174 on: December 09, 2018, 09:23:19 am »
Q1) What is the standard with for the banana plugs?
Q2) At 16:15, it is said that, for an adjustable current power supply, the output capacitors are desired to be minimum possible. What is the reason behind this?
« Last Edit: December 09, 2018, 01:01:01 pm by hkBattousai »
