Author Topic: EEVblog #837 - Reverse Engineering A Valve Headphone Amplifier  (Read 72443 times)
Offline Oskar
Re: EEVblog #837 - Reverse Engineering A Valve Headphone Amplifier
« Reply #100 on: January 08, 2016, 04:22:01 pm »
That's funny that the tube is just a buffer.  Thanks for using the DS1054Z and highlighting the channel control issue.  That does not take the DS1054Z off my to purchase list.
Nice video.
Offline Fungus
« Reply #101 on: January 08, 2016, 06:16:19 pm »
Not just a buffer, the electric heater in the tube will add 'warmth' to the electrons.
What audiophile doesn't want warmed-up sound?
Offline Richard Crowley
  • KJ7YLK
« Reply #102 on: January 08, 2016, 06:58:03 pm »
Either way, you'll still be able to use headphones, I guarantee that. It's sort of a basic requirement.
Sure. Apple headphones (or Apple-licenced headphones) at an inflated Apple price.
It's plays nicely into their "Walled Garden" scheme where they control EVERYTHING including the customer.
I am extraordinarily dubious about this.
Offline Fungus
« Reply #103 on: January 08, 2016, 07:04:34 pm »
Nah, there's no conspiracy.
It's a phone. The whole point is that it's wireless and the music plays remotely while you select songs on the screen. Bluetooth sound is built into everything these days. You don't connect a cable when you listen to your iPhone in your car, why should you do it at home.
It's the way the iTunes generation rolls, Apple is just going along.
Offline jdamewood
« Reply #104 on: January 09, 2016, 06:28:59 am »
Drawing an  analogy to a J-FET is simply wrong.
A more apt analogy would be a MOS-FET since there is an insulator between the elements like in a vacuum tube.
Sorry Dave Ya got it wrong.
No I think you got it wrong, if the control grid voltage would become positive a grid current would flow, just like in a J-FET.
Then the cathode follower would be 180° out of phase from input signal.
Preemptive call to myself as being wrong, if needed.
Offline Pentium100
  • Country: lt
« Reply #105 on: January 09, 2016, 07:15:45 am »
The cathode follower output is in phase with the input. When the control grid voltage becomes more positive than it was at idle, more current flows trough the tube causing higher voltage drop on the cathode resistor. If the control grid voltage becomes positive with respect to cathode, then some grid current flows, but the plate current is increased even more.
I have attached the IV curves of a Russian 6?2? (6N2P) tube, which is similar to 12AX7. It shows the effect of a positive grid voltage.
« Last Edit: January 09, 2016, 07:21:39 am by Pentium100 »
Offline gildasd
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
« Reply #106 on: January 09, 2016, 07:18:13 pm »
The day Apple removes the 3.5 is the day I buy a Samsung...
Apple in ear head speakers are nice, but in my use, worn under noise protection ear muffs, they last only a few weeks before splitting open.
Cheap PVC based models last until the conductors split.
I like Apple products, but my brand loyalty breaks down when said brand tries to shag me, in a fashion frowned by the ecclesiastical hierarchy, without so much as the courtesy of a reach around.
I'm electronically illiterate
Offline gadget73
« Reply #107 on: January 10, 2016, 04:28:32 am »
Cathode followers are in-phase with the input signal, anode follower would be 180 out of phase.
Offline 13hm13
« Reply #108 on: January 10, 2016, 07:27:03 am »
I think Dave meant in a GENERIC way: tubes and FETs are voltage amps (not current).
Offline jitter
« Reply #109 on: January 10, 2016, 07:35:10 am »
The way I understood the analogy is electrons flowing through a vacuum are being effected by the electrical fields on the grids. Hence the analogy to the FE part of a FET.
Offline AF6LJ
« Reply #110 on: January 10, 2016, 01:52:08 pm »
That's true The J-FET analogy just doesn't work.
Sue AF6LJ
Offline Brumby
« Reply #111 on: January 11, 2016, 02:07:05 am »
+1
After all, it's a tear-down style examination, not a quantum physics analysis.
Offline rch
  • Country: wales
« Reply #112 on: January 11, 2016, 11:33:35 am »
+1.   To those of us brought up on valves, JFETs are just like valves, and bipolar transistors are alien and odd!
  • KJ7YLK
« Reply #113 on: January 12, 2016, 06:22:15 pm »
From the BBC yesterday....
The 19th Century plug that's still being used
After rumours that Apple was going to get rid of the headphone jack in its imminent iPhone 7, more than 200,000 people have signed a petition asking them to reconsider. This humble plug is a rare example of technology that has stood the test of time, writes Chris Stokel-Walker.
For what remains an unconfirmed rumour, a lot of people are upset about the new iPhone. It's alleged that Apple will be scrapping the 3.5mm socket, instead leaving headphones to be plugged into the "Lightning" port - the company's own design of socket.
Cynics have pointed out that while this might enable iPhones to be slightly thinner, it will render many headphones useless and force manufacturers to pay Apple a fee to use their Lightning plugs on products.
The petition says Apple's purported move would "singlehandedly create mountains of electronic waste".
...history of the phone plug...
And yet, if the rumours - which Apple is not commenting on - are true, it bodes ill for the 3.5mm jack.
Apple has a track record of being early to abolish things which then start to disappear from rival products too. It killed the 3.5 inch floppy disk early. It also was among the first to remove optical drives.
But those signing the petition on the Sum of Us site and social media users have suggested that Apple's motive is greed.
The potential grief in a switch to Apple's proprietary Lightning connector is obvious.
"It feels painful because you've got hundreds of millions of devices out there that are using the old standard," says Horace Dediu, a technology analyst with in-depth knowledge of Apple.
If you're using £1,000 headphones with your iPhone at the moment, you're going to be slightly cross.
And Charlie Slee thinks consumers are also concerned about ceding control to Apple. "People are mainly upset because they like to think they're in control of their technology," he says.
But this sense of the consumer in control is misplaced, Slee says. "Actually, the contrary is true: The big technology companies have always been in control of how you listen to music and watch videos."
http://www.bbc.com/news/magazine-35253398
I don't agree that if Apple ditches the 3.5mm connector, it spells doom for that connector in the Rest Of the World.  But, at least as far as I am concerned, it just reinforces my distain for everything Apple.  If I were a dumb consumer appliance-operator, I would probably have a different opinion.
Offline helius
« Reply #114 on: January 12, 2016, 09:37:50 pm »
I very much doubt the cross section of "£1,000 headphone users" who plug them into iphones is significant. Aren't all products in that range either 600 ohm, electrostatic, or otherwise not driveable from low-output equipment?
Offline rch
  • Country: wales
« Reply #115 on: January 12, 2016, 11:01:19 pm »
Apple users may well be able to purchase £1000 headphones which look just like £3.50 headphones to the rest of us.
(DOI moderately keen Apple user.)
Offline timb
    • timb.us
« Reply #116 on: January 12, 2016, 11:15:53 pm »
It's a rumor guys. It's either not going to happen, or if it does they will still be pumping analog out through the Lightning port, which will allow you to use a $5 passive adapter. I guarantee that.
It's pointless to get worked up over an Apple rumor. This particular one has been floating around since the iPhone 3GS. (This same rumor was about the iPhone 4 not having a headphone port.)
These get started one of three ways:
1) Some Apple Rumors Blog makes up some BS and tech sites pick it up as news.
2) Apple files a patent for "Method of transporting digital audio directly to headphones" and someone interprets that to mean the headphone port is being killed.
3) Someone at Apple says, "Gee wouldn't it be nice if we didn't have to deal with external ports, we could make phones that were paper thin!" This gets repeated like the Telephone Game and eventually someone posts it on Twitter as "Apple to remove headphone ports!"
In this case, it's likely a combination of all three. If anyone wants to start a pool on Apple removing the headphone port in the 7, I'll throw down $100 right now squarely in the Not Happening category.
Offline jitter
« Reply #117 on: January 13, 2016, 06:33:42 am »
Yeah, and that hyped rumor is talking about a 3.5 mm jack like that's the smallest jack there is... which it is not.
More than a decade ago I bought a HP PDA which already did away with the 3.5 mm jack and used a 2.5 mm jack instead. Thoughtfully HP supplied a 2.5 mm to 3.5 mm adapter...
So wether or not Apple stops using the 3.5 mm jack is really not that interesting, it's been hyped because it's Apple that (allegedly) does it. And even if they were to do it, I have no doubt that aftermarket converters would become available for very little money very quickly.
I hear people say: "Yeah but that costs extra..." Well, if you're prepared to buy overpriced stuff to begin with, a few more dollars/euros/whatever isn't going to hurt your wallet that much...  ;)
« Last Edit: January 13, 2016, 06:51:01 am by jitter »
Offline gildasd
« Reply #118 on: January 13, 2016, 10:37:52 am »
Of the thing I find that Apple has to improve, thinness and size are not on my list.
Battery life, WIFI sensitivity and others come to mind.
In any case it goes in a rubber case...
Offline Fungus
« Reply #119 on: January 13, 2016, 01:34:36 pm »
Apple will charge $20 for their legacy headphone compatibility system.
Offline krivx
  • Country: ie
« Reply #120 on: January 13, 2016, 01:36:54 pm »
If it's an analog breakout cable then eBay will charge $3
  • KJ7YLK
« Reply #121 on: January 13, 2016, 02:03:39 pm »
Just because they're removing the 3.5mm jack, doesn't mean it won't still output analog audio. They could very well push the analog audio over a couple of pins on the Lightning connector.
Please explain how you think they could do that since there are no analog pins on the Lightning connector, and no re-assignable pins, either.
And furthermore, the Lightning connector is not only proprietary, but contains active circuitry to ensure that ONLY Apple-provided (or Apple-licensed) gear can connect.  (Read: $$$)
Ref: https://en.wikipedia.org/wiki/Lightning_(connector)
  • KJ7YLK
« Reply #122 on: January 13, 2016, 02:08:25 pm »
It cannot be an analog cable because Apples proprietary Lightning connector is digital-only.
Furthermore Lightning requires an active ID/authentication chip available only by licen$e from Apple.
That ensures that you won't be able to buy sensibly-priced accessories like simple cables, adapters, etc.
Apple must enforce their lucrative proprietary Walled Garden scheme.
Of course, the knock-off artists in Asia have proven themselves to be very clever.
So it seems within the realm of possibility that they can produce a counterfeit authentication chip.
Of course, then Apple could pull an FTDI stunt and brick all your counterfeit gear.
« Last Edit: January 13, 2016, 02:10:22 pm by Richard Crowley »
Offline krivx
  • Country: ie
« Reply #123 on: January 13, 2016, 02:31:09 pm »
The Wikipedia page posted above says that Apple sell a Lightning to 30pin (previous Ipod/IPhone connector) adapter and that it supports analog audio. Google brings up lots of knockoffs of this adapter, so maybe the work is already done?
Offline Brumby
« Reply #124 on: January 13, 2016, 02:35:37 pm »
I would not be comfortable trusting Apple to give me what I want - and I certainly am not one of the 'faithful' that accepts whatever is served up as being the best option.
I like to think and decide for myself on a few things....
