Author Topic: EEVblog #849 - Sony E-Mount Camera Lens Teardown  (Read 14451 times)
Offline EEVblogTopic starter
« on: February 08, 2016, 11:02:45 pm »
What's inside a Sony SELP1650 compact zoom E-Mount camera lens?
How does the zoom mechanism work
How does the Sony Optical Steadyshot image stabilisation system work?
http://www.sony.com.au/product/selp1650
Offline max666
  • Country: at
Re: EEVblog #849 - Sony E-Mount Camera Lens Teardown
« Reply #1 on: February 09, 2016, 03:25:54 am »
Awesome stuff! Great teardown!
Offline daqq
  • Country: sk
    • My site
« Reply #2 on: February 09, 2016, 08:48:57 am »
Thanks Dave for the teardown.
Could someone guess at the function of the part in the picture? It's like a pad for a part, but it's connected. There are more of them on the board. It's not a test pad (unless it's an unpopulated pad for a development test point), so, why?
Offline G7PSK
  • It is hot until proved not.
« Reply #3 on: February 09, 2016, 12:02:34 pm »
The groove cut in the sleeve is an axial cam not a tread or worm.
Offline plazma
    • Homepage
« Reply #4 on: February 09, 2016, 02:50:22 pm »
I use these in designs. It's a 0R resistor that can be cut for measurements/debugging and can be replaced with a solder bridge or resistor afterwards.
Offline Fungus
« Reply #5 on: February 09, 2016, 03:01:30 pm »
I've pulled stuff like this apart before.
The mechanics always amazes me, I have no idea how they design that sort of stuff, It seems impossible.
Offline djQUAN
  • Country: ph
    • My DIY website
« Reply #6 on: February 09, 2016, 03:18:58 pm »
Where I used to work, we usually add 0 ohm resistors in series with data lines and change this to ones with resistance values (or ferrite beads) if there are any problems during EMC evaluation. If it already passes with the 0 ohm resistor, in the later revisions of the PCB, the pads will simply be bridged with a track to save cost on the part itself and the cost of mounting it.
Offline Fungus
« Reply #7 on: February 09, 2016, 04:09:51 pm »
And a Teardown Tuesday video actually available on a Tuesday. Is that a first?
Nah, this is last Tuesday's video, a week late.
(A stopped clock is right twice a day...!)
Offline PA0PBZ
« Reply #8 on: February 09, 2016, 07:41:53 pm »
But the pads are already connected, they sit on a common trace so clearly whatever component you put on there does exactly nothing.
Offline Fungus
« Reply #9 on: February 09, 2016, 07:45:41 pm »
Luckily there's no component on it. That will save money.
Offline PA0PBZ
« Reply #10 on: February 09, 2016, 07:58:42 pm »
Reading plazma's reply again I think it means cutting between the pads, which makes sense but not something I'd like to try on a flex pcb.  :scared:
Offline AF6LJ
« Reply #11 on: February 09, 2016, 08:58:01 pm »
That's really Cool Dave.
Sue AF6LJ
Offline Starman
  • It's Just Magic
« Reply #12 on: February 09, 2016, 09:42:39 pm »
Maybe you could hook up the image stabilizer portion to a joystick  or linear slide pots, and use it as an electrically movable microscope stage !
Offline max_torque
    • bitdynamics
« Reply #13 on: February 10, 2016, 08:36:10 pm »
Two questions / comments:
1) the tooling for those precision injection moulded parts must have cost $$$$ ! (especially the axial cams / tracked rings)
2) did you get it all back together again, and does it now work??  :-DD
Offline AF6LJ
« Reply #14 on: February 11, 2016, 01:15:50 am »
Hay;
That's a cool idea.  :-+ :-+
Sue AF6LJ
Offline ivaylo
« Reply #15 on: February 11, 2016, 06:16:25 am »
The few times I've tried to "service" lenses I failed miserably. The one I was sure I can clean turned out to have a six threaded focusing barrel so focus went to hell. I did try all six ways, but it was a film camera and developing the film just showed it was way off. Not to mention the fun of chasing spilled iris leaves. It was an underwater lense, glad the shop could fix it after me. Those guys have assembly guides, specialized tools, focusing stands and what not.
Offline Oskar
« Reply #16 on: February 19, 2016, 11:48:34 pm »
I really enjoyed this teardown.  Lens are amazing.  I've taken a few apart, all were broken to begin with.  Tons of fun.
Thanks again for the unique teardown!
Oskar
Offline max666
  • Country: at
« Reply #17 on: February 20, 2016, 09:21:40 am »
...  I've taken a few apart, all were broken to begin with. ...
Suuuure! That's what they all say   :P
Offline PeterL
« Reply #18 on: February 25, 2016, 11:57:19 am »
I stumbled upon this Youtube channel:
https://www.youtube.com/channel/UC2z5c8YEA5dQLi36DYpsFJg
He only has a few video's yet, but he really does a really good job of tearing down and fixing camera's and lenses. He really knows what he's doing, and let's the viewer learn along.
