Author Topic: EEVblog #855 - Ceramic Capacitor Piezoelectric Effect  (Read 30997 times)
Offline EEVblogTopic starter
« on: February 26, 2016, 05:35:00 am »
Dave investigates the piezoelectric effect in multi layer chip capacitors (MLCC's). In this case, on the backlight inverter on his own BM235 multimeter.
http://www.hycontek.com/attachments/LCD/DS-HY2613_TC.pdf
Offline ruffy91
Re: EEVblog #855 - Ceramic Capacitor Piezoelectric Effect
« Reply #1 on: February 26, 2016, 06:03:25 am »
I didn't watch the video yet, but an interesting usage of high-capacitance X7R MLCCs is as micro-actuators: http://www.theiet.org/resources/journals/eletters/5007/nano-scale-mega-scope.cfm
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #2 on: February 26, 2016, 06:18:55 am »
Wouldn't be a blob of hot glue be a fix to?
The aditional mass would reduce the noice too.
Or am I wrong?
Offline MarvinTheMartian
« Reply #3 on: February 26, 2016, 07:56:20 am »
I in effect asked that too, but no-one responded. :(
It's not really a 'fix' as such (it doesn't resolve the design fault/parts selection issue) - it is more of a possible work around for those of us less experienced in circuit design and fault finding (ie yours truly :palm:)
Loved the explanation Dave and it gives me confidence to replace the cap concerned (if and when I get an appropriate cap). Will give me some more experience with re-working SMDs (where have those stronger glasses gone?  :-DD).
Reviving my old hobby after retiring! Know so little...only one thing to do...watch Dave's videos and keep reading the forum! ;-)
« Reply #4 on: February 26, 2016, 08:47:16 am »
Likely just attenuate it, which might be good enough of course.
The vibration is happening inside the cap and it's likely being amplified by the PCB itself.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #5 on: February 26, 2016, 09:10:40 am »
Would the act of just adding those temporary test wires alter the amplitude or the ringing frequency of the DUT  to any great extent ?.
Mine is due for a thorough modification service tomorrow..... :)
Offline bktemp
« Reply #6 on: February 26, 2016, 09:14:29 am »
The capacitor itself makes almost no noise. That's the same reason why piezo speakers are always mounted in some case or glued to some other plates to have a larger moving surface.
When searching for the culprit capacitor I am using tweezers to amplify the sound the same way the needle of a record player works:
I put one tip onto the capacitor while pressing onto the other end. This allows the tweezers to vibrate feely like a tuning fork.
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #7 on: February 26, 2016, 10:37:47 am »
So... What's the point of these multimeters if it's just a re-branded unit that you "don't have a schematic of", as said in this video?
Offline wraper
  • Country: lv
« Reply #8 on: February 26, 2016, 10:56:11 am »
Earning money by selling a decent product?
  • Cursed: 679 times
« Reply #9 on: February 26, 2016, 10:59:56 am »
It's the vibe, and the squeal but mostly the vibe.
Online Brumby
« Reply #10 on: February 26, 2016, 11:12:28 am »
Offline timgiles
  • Programmer, DB architect
« Reply #11 on: February 26, 2016, 11:38:41 am »
I was hoping a pair of Tantalums would be ok, just ordered two Kemet SMD Tantalum Capacitor 35V SMT (3 Packs) 1 and 10uF.
Offline Barbossa404
« Reply #12 on: February 26, 2016, 12:24:23 pm »
This reminds me of http://thume.ca/screentunes/ (https://github.com/trishume/screentunes for a description), which uses patterns on the screen to generate a modulated and surprisingly loud humming on most lcd screens (led backlight preferred). Same effect but most people don't expect a whining pc screen after they replaced their CRTs  :D
Offline idpromnut
« Reply #13 on: February 26, 2016, 12:28:59 pm »
Thanks for the video Dave!  :-+  I was going to do a follow-on video trying to mic the sound from my unit, as even with C44 removed, I can still hear a very very faint whine coming from somewhere (only with the case open, and even then it's faint), probably from C43. Excellent scope captures; that is probably something I should have worked on for my video.
Also nice to hear the IRC channel mentioned ;)
Offline Fungus
« Reply #14 on: February 26, 2016, 12:29:20 pm »
Are you going to include a replacement cap with every meter?
 :popcorn:
Offline max666
  • Country: at
« Reply #15 on: February 26, 2016, 12:57:24 pm »
What about flip it 90 degrees? So the vibrating axis will not be stretching the PCB.
I'm curious as well how flipping the cap would affect this issue.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #16 on: February 26, 2016, 12:59:11 pm »
I quite enjoyed that Dave.   :-+
« Reply #17 on: February 26, 2016, 01:12:14 pm »
I like the meter, I want to sell it, I think it's good enough to put my name on it, I think it's cool to have a meter I can use in my video that has my brand on it, a lot of people get a kick out of having an EEVblog branded meter, and it helps feed my family. Is there anything wrong with that?
If you don't want to buy one from me that's fine, buy the regular BM235 (I deliberately didn't hide the fact that it's the same as the regular BM235). If you do want to buy one from me with the EEVblog name on it, then great, here it is. If you think its crap, that's fine too. Name an equivalent model meter on the market that you can officially get the schematic of.
« Reply #18 on: February 26, 2016, 01:16:58 pm »
Not probably, 100% certainty. There is nothing else in the backlight circuit.
Offline woox2k
  • Country: ee
« Reply #19 on: February 26, 2016, 01:28:24 pm »
Nothing wrong with that but i hope you will not choose to use that meter just for that fact even though you might have better meters around that would do the task a bit better. At least i would still like to see real examples where some high-end DMM's do a better task. Thing i'm asking is not to over-advertise it (not saying you do it now, just don't start doing it)  :-DMM
That said, i would gladly pay a bit more for a DMM knowing that some of that goes directly to you, seeing it "over-advertised" on the video would not change the fact at all.
By the way, where is the unofficial EEVBlog IRC channel you mentioned in the video?
« Last Edit: February 26, 2016, 01:30:47 pm by woox2k »
Offline idpromnut
« Reply #20 on: February 26, 2016, 01:39:49 pm »
In #eevblog on Afternet https://www.afternet.org/
Offline lapm
« Reply #21 on: February 26, 2016, 04:13:54 pm »
Its the official EEVBLOG merchandise... It has Logo on it... There's people that buy directional audio cables, this multimeter is much better purchase and support out favorite video blogger about electronics.
  8)
Electronics, Linux, Programming, Science... im interested all of it...
Offline dentaku
« Reply #22 on: February 26, 2016, 05:58:55 pm »
One squeaky thing that annoys me is Indiglow like I have on my Timex watch. It squeaks quite loudly just like that capacitor.
I once saw a remote control that had a light-up face that would activate whenever it was moved. I couldn't stand it  >:(
Offline arekm
« Reply #23 on: February 26, 2016, 06:32:29 pm »
What's the best approach to find "guilty" part if you have board with tons of capacitors, coils etc - like some laptop mainboard? Using ear doesn't work, too high frequency, so unable to locate.
Offline Artlav
  • Country: mon
    • Orbital Designs
« Reply #24 on: February 26, 2016, 07:00:02 pm »
Nope, perfectly fine. :)
I just got an impression over the last few videos that you made your own multimeter (you kept mentioning a "secret project" here and there for the past few months) and the illusion went splat on this video.
