Author Topic: EEVblog #86  (Read 17351 times)
Offline orbiter
  • -0 Resistance is Futile
EEVblog #86
« on: May 11, 2010, 11:40:15 am »
Hey Dave, why not test that DSO Nano you love so much in your video? You know you want to ;) j/k
Plus I want to see it taken apart.
PS.. I lol'd at the end of the clip where you were singing :)
regards
orb
« Last Edit: May 11, 2010, 11:41:53 am by orbiter »
Online EEVblog
Re: EEVblog #86
« Reply #1 on: May 11, 2010, 12:30:07 pm »
If they want to send me one I'll happily slag it off!  ;D
Dave.
Offline Ferroto
Re: EEVblog #86
« Reply #2 on: May 11, 2010, 04:29:14 pm »
Since were on the topic of hand held scopes fluke has one of there own. http://us.fluke.com/fluke/usen/products/CategoryOSCILL?trck=scopemeter
Probably worth a look, although I'd prefer a bench oscilloscope for ease of use.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: EEVblog #86
« Reply #3 on: May 11, 2010, 04:35:52 pm »
Well I just took a look on ebay in the EU.
And found not that friendly prices about them.
Even for the old ones .
I am not aware if it worths to buy a damaged one and repair it some how.
It looks to be many damaged ones at low prices, what possibly can damage one oscilloscope,
would be my next question..
Offline orbiter
Re: EEVblog #86
« Reply #4 on: May 11, 2010, 05:14:37 pm »
How about this one Kiriakos my friend? Was even thinking of bidding for this myself...
http://cgi.ebay.co.uk/Tektronix-100MHz-Oscilloscope-model-2235-/140406085058?cmd=ViewItem&pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item20b0dad5c2
« Last Edit: May 11, 2010, 05:16:19 pm by orbiter »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: EEVblog #86
« Reply #5 on: May 11, 2010, 06:41:59 pm »
thats a very good buy but I think it may eek towards £ 200 at the last minute
Offline hans
Re: EEVblog #86
« Reply #6 on: May 11, 2010, 07:23:56 pm »
I agree with you on the analog and digital ease of use. Personally I find a digital USB scope is harder to use than an old analog one. You really can't beat some knobs and buttons against graphs, toolbars, etc.
I have used Analog, Digital and USB scopes on college before and personally I don't notice much difference between digital and analog one. Analog is even better in some ways, because digital tends to drag you down to a ton of menu's to unset things that the previous student has set up. You don't want that if you just want to measure something quickly..
Now I also used an USb scope on 1 occassion before for measuring a step response of some system. It has like a 300ms step response transition, which you could measure with a digital or analog one with the cursor, but I thought it lacked inaccuracy (more crucially the models we used: memory, couldn't walk futher back than 250ms on the 10ms scale). So , I happened to know my college had a handyscope. We had to 50MS/s one, which is quite expensive (1050 euro's is more like $1350 or even 1500 aus $) and has a bunch of functionalities (including AWG built in, which works to quite high performance as well). I don't know how the input protection is, we don't do ripping apart on college, but I believe they aren't like crappy devices at all.
Works quite nicely, plug in, get the software and off you go. Software was reasonably quick to learn if you know where to look and have experience with scopes. Got a excel data sample (CSV file) quite quickly with like 10k samples per second of the step response after just 30 minutes of fiddling. That was very very accurate, and very fast. I did like 20 samples (different responses) in like 15 minutes. That would otherwise have taken me a complete afternoon, with nearly as much accuracy. A digital scope could do this as well I think, but as these are designed for doing these kind of measurements, it was ideal.
Sounds good, but I want to add something crucial that is lacking with USB oscilloscopes. One is, you have to know exactly what you are doing when you use one of theses. You don't want to do something like mess up the grounds or something, otherwise your PC that is measuring WILL have a problem too. Now that's not even the biggest issue. The biggest issue is that you need the PC. A normal scope is something you can just pick up and measure anything without the need of taking a laptop with you. Now an analog scope is heavier than a laptop (and bigger), but it measures right away, not after booting for 3 minutes. That's my biggest issue. You always need the computer, which is already very full of designs, datasheets, internet, media, mail, etc. that's open all the time.
« Last Edit: May 11, 2010, 07:29:09 pm by hans »
Offline Simon
  • Global Moderator
Re: EEVblog #86
« Reply #7 on: May 11, 2010, 07:32:32 pm »
when at school I found the digital scopes (CRT versions) a nightmare and never used them. I was quite happy with an analogue scope and to be honest if your trying to use a scope properly instead of hitting the auto button then a digital one will be more baffling if you do not have a good foundation of using analogue scopes. I wish I had kept my analogue scope but had to sell it to part pay for the Rigol DS1052E
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
Re: EEVblog #86
« Reply #8 on: May 11, 2010, 10:27:21 pm »
I was looking for something compact like 60MHz dual .. but I am not willing to spent any serious amount of money so to get one, simply because I do not do any projects that needs it.
And even if I was getting one , I would probably use it, to just check for ripple in DC power supply's .
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: EEVblog #86
« Reply #9 on: May 12, 2010, 03:28:25 pm »
While I think analog scopes are better general purpose ones, I don't think a newbie should just pellmell jump into getting one without knowing some caveats Dave did not make apparent.
http://electronicdesign.com/article/communications/does-anyone-still-use-an-analog-oscilloscope-14793.aspx
Many old devices use a lot electrolytics caps that are at most, rated for 20-30 years.  If you get such a device, particularly a scope, its likely due to fail very soon, and every day it works is a blessing.  Those caps would fail sooner if the scope was used in extremes of its operating temp, such as in the winter colds or summer heat, if taken as a field instrument.  Also, how much abuse has the inputs already taken?  and was a scope 'stored' because it wasn't useful anymore or it stopped working?
Tektronics built in the 1990s and up, are increasingly difficult to repair and use specialized parts, while older ones use more 'generic' technology but are very likely to fail from sheer age.
A quick review of eBay shows many such scopes are sold AS-IS, and there is no way to ascertain it will even power up, nor that it even works near to spec.  Those that are refurbished are a better bet, but they are going for $300-400 to start, because the seller has gotten it back up to snuff, in which case you're getting mightly close to a Rigol 1052E.
So, I can see a seasoned hobbyist getting one knowing a repair is likely in order, but a newbie will likely be less served by getting one.
If you inherit a scope from a good user, or a school, it at least can be examined, and the donor may likely know something about how it works and its caveats.  And free is free.
That said, if a newbie is just getting his feet wet in electronics, a DSO nano isn't such a bad bet, given it should work out of the box, and can show them what a basic wave form looks like.
Also, a lot of folks I read here discussing equipment that can easily resolve 1MHz and up, postly elsewhere about design issues that are barely cogent for competent audio frequencies design, that I just can't see what all this extra bandwidth is going to do for someone who is challenged by Horowitz and Hill.
Don't turn off a newbie by making the barrier for entry into the hobby high.  If they outgrow the DSO nano, then good, but I feel a newbie will learn electronics by exploring the limits of their gear.  $300 reserved for a good scope, used or new, can be used to furnish almost an entire learning lab given the cost of basic lab equipment from China: DMM, evaluation board, power supply, a cheapie scope, signal generator etc.,
« Last Edit: May 12, 2010, 05:39:31 pm by saturation »
Best Wishes,
 Saturation
Offline charliex
  • Car Hacker
Re: EEVblog #86
« Reply #10 on: May 12, 2010, 04:37:05 pm »
Analogue scopes just look cooler too, I like my digital Tek TD but there's nothing quite like a bright CRT trace with a lot of fancy dials and stuff to geek out on. Playing starwars on the XY mode works a lot better too!
I like the little fpga4fun scope toy, but only as something interesting to build like the xmas tree lights from velleman etc. There's also the problem of isolation and so on.   I have a spare fpga4fun flashy, i'll send you that for a review dave even though i already know what it'd be ;)  but featurewise it'd get beat by a soundcard scope. honestly, it'd get beat by an etch a sketch and a half dozen cups of coffee.
Wouldn't mind seeing you review a picoscope though, they're fairly popular in automotive but thats because they provide a lot of comparison wave forms and tools designed for automotive diagnostic, and lots of people have them. I tried one out and wasn't into it all, the software was pretty poor, but its like apple stuff, its simplistic and works in its specific area for specific people. My curiosity piqued when I saw the software could do a compression test.
Offline Simon
  • Global Moderator
Re: EEVblog #86
« Reply #11 on: May 12, 2010, 05:22:50 pm »
how do you play starwars on a scope ?
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
Re: EEVblog #86
« Reply #12 on: May 12, 2010, 09:32:52 pm »
 ;D ;D ;D ;D ;D  LOL  ..
I had a conversation today with some friends electronic engineers ,
they told me the same stories about oscilloscope age ,  dying from age screens ,
limited support about parts etc etc ...
And they advised me to go for a Hameg , German build, reliable ones , and there is parts for them and good support even today.
Offline saturation
    • NIST
Re: EEVblog #86
« Reply #13 on: May 13, 2010, 12:01:22 am »
Hameg models are very good scopes.  CRT are quite reliable, so a most common issue is the deterioration of the discrete capacitors in its boards, especially the electrolytics.  I know CRT phosphors fade with age and use, but its hard to say how much life is left in a CRT.
http://www.hameg.com/446.0.html?L=0
H
Best Wishes,
 Saturation
Offline charliex
  • Car Hacker
Re: EEVblog #86
« Reply #14 on: May 13, 2010, 12:55:36 am »
I used to be an electronics repair tech at funland in blackpool, the XY boards on the old vector starwars machines would break a lot, so we used to check the game logic was working by connecting it to a XY scope, even better if it had a blanking input since then it was basically exactly the same look, just on a small screen. Works for any true vector based game.
this one
Online EEVblog
Re: EEVblog #86
« Reply #15 on: May 13, 2010, 01:33:26 am »
I still maintain that $80 spent on the DSO nano is pretty much money down the drain on a toy.
Aside from the obvious caveats about buying old second hand gear, the basic fact that for the same $80 you can get say a proper 20MHz dual channel analog oscilloscope that (provided it still works) will still be a useful and valuable tool in a few years time. The Nano almost certainly won't be.
And then there is the old adage that you learn the most when your you have to troubleshoot things and figure out what's going on. If for example you buy an old second hand scope and one channel starts playing up, the skills learned by
a) recognising that's it's playing up
and b) investigating it and possibly fixing it
can be invaluable.
No such luck with the toy Nano out of the box that won't even teach you much about how an oscilloscope actually functions.
But hey, if the Nano floats your boat, then go for it.
And like I've said before, I hope your next project DOESN'T work!
Dave.
alm
  • Guest
Re: EEVblog #86
« Reply #16 on: May 13, 2010, 08:25:18 am »
I guess the DSO nano appeals to people because it has more sex-appeal than an old CRT scope, especially for people used to modern electronics like ipods. This is one thing they got right compared to most DIY projects. Plus it takes up very little space (the reason why I don't have an analog scope, although I've got an excellent DSO so I don't really need it). But I agree that it's absolutely useless as a scope.
It's true that troubleshooting is very educative (especially since some of the older scopes from companies like HP and Tek have excellent documentation). An issue with learning troubleshooting on a scope, however, is that you (often) need a scope to fix a scope. No big deal if one of the vertical amplifiers dies, but you're screwed if it's the horizontal circuit or the power supply.
Offline tecman
Re: EEVblog #86
« Reply #17 on: May 13, 2010, 05:30:23 pm »
Dave:
I would disagree with you.  I have plenty of scopes in my lab, from the ultra transportable TEK 547 on to my new Rigol 100 Mhz 1052.  BTW the 547 is still the finest analog scope that I have ever used.  A bit temperamental at times with the old tubes, but when it is up and calibrated, nothing beats it.  Anyway I have a TEK 214 and a Fluke Scopemeter that I use for "away from home" needs.  Both work great.  But I got a NANO just because it was cute.  Very limited, I agree, but show me something that I can literally slip in my pocket and take a few readings if needed.  Granted most of my professional work is under 500 Hz, so bandwidth is not an issue, but on the off chance I need to see something, it is certainly not a toy.  No I would not recommend it to anyone as a first or only scope, but for the convenience and the price, tough to beat.
paul
Offline Simon
  • Global Moderator
Re: EEVblog #86
« Reply #18 on: May 13, 2010, 06:19:04 pm »
as a first scope you need something reliable that can cover anything. Personally I find the Rigol small enough to tow around with me. if you want the gadget and know exactly what limited use you are using it for sure get the nano but this is all about beginners first scopes !
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
Re: EEVblog #86
« Reply #19 on: May 13, 2010, 06:45:08 pm »
Thats true , the professionals who does repairs , does not need any scopes at all.
There no any more available, schematics with test points of oscilloscope curves, in them.
Offline Simon
  • Global Moderator
Re: EEVblog #86
« Reply #20 on: May 14, 2010, 06:47:55 am »
No because they expect you to dump the unit and buy another one
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
Re: EEVblog #86
« Reply #21 on: May 14, 2010, 01:34:48 pm »
I agree , but they had win, mostly by not offering parts.
Thats why I am avoiding of getting any goods , who follows the same philosophy .
And yes, my choices are narrowed by allot, but at list I support the ones who worths to be supported.
Offline Simon
  • Global Moderator
Re: EEVblog #86
« Reply #22 on: May 14, 2010, 06:16:23 pm »
I no longer buy cd players because they have a failure time of a year or less, I'm pretty certain that the laser head is specifically chosen of low quality so that it fails, becuase this one part fails a completely usable machine is dumped !
In our house our main CD player is an old PC CDROM drive that is powered from an old power supply and runs through my dads main amp which is older than me and still works (which is no surprise as it was made when stuff was made to be bullet proof)
Offline slburris
Re: EEVblog #86
« Reply #23 on: May 14, 2010, 07:00:30 pm »
I can't believe that people are arguing that you should get a DSO first or instead
of an analog scope.
Unless you spend your days looking at sine waves, you need at least 10X
oversampling over your frequency of interest to accurately reproduce the
waveform.  Why?  Because anything except for sine waves contain higher
order harmonics.
And don't tell me that you just use "equivalent time sampling" to build up
the waveform.  That only works if the waveform is repetitively stable.
How do you know it is?  Isn't that part of the reason you are looking
at it with a scope in the first place?
I've had jittery signals that look confusing on a DSO, but putting
them on an analog scope made the issue much clearer.
Don't get me wrong, I love my DS1052E, especially since it's now
acting like the 100Mhz model, but it's just another tool in my toolbox.
It adds to but doesn't replace my Tektronix analog scopes or logic
analyzers.
The DSO nano is really cute, but except maybe for audio circuits, I
can't think of anything I do which will fit in its bandwidth restrictions.
When I was a beginner, I couldn't afford a scope at all, so I started
out with a Radio Shack logic probe.  It's amazing what you can debug
just seeing if a signal changed or not, but you have to think.
I learned more about how things worked with that little probe (which I
still have 30 years later) then I would have learned had I just
pushed an auto button on a DSO.
One guy's opinion, anyway.
Scott
Offline adam1213
Re: EEVblog #86
« Reply #24 on: June 10, 2010, 02:53:32 pm »
In terms of a general purpose oscilloscope I agree that the DSO nano isn't the best choice. However the DSO nano does have other features if you are interested in developing software for its hardware  (such as having a nice colour screen) You could even write a game for it. (so what if its a toy - as long as you realise its limits)
- I was thinking of adding some features to it (eg RMS voltage) - all of which require learning how an oscilloscope actually calculates things.
- I appreciate that the code for the DSO nano is available (well at least until one of the newer version :() However the C code for the DSO nano is terrible. The code has lots of global variables with one letter names and a uses arrays where it should be using structs)
« Last Edit: June 10, 2010, 02:59:27 pm by adam1213 »
