I'm not an expert in battery chemistry, but this may have to do with ion diffusion. When you deplete the battery so fast, the ions don't have time to diffuse to the electrodes. Squeezing the batteries causes convection (liquid mixing) that stirs the liquid, quickly moving the ions around and replenishing the battery. You might do better by alternately squeezing and releasing the battery several times.
I bought 8 of these when they came out. Six have been thrown away (bad) but I still have 2 in a lantern that I do not use. Once a year and take them out and the two always have a near full charge. I discharge them and recharge until the next year.
If they all lasted list these two they would have become the miracle battery.
OK, No one else has asked, so: How flat do I have to squash my AA's to get 800% more energy out?
In Dave's video, towards the end, the battery voltage was far too high, for a run down battery (approx 1.25V at about 1800 Sec into test). I.e. I smell a rat. (Tomfoolery/trickery).
No trickery, the electronic load had switched off because the battery voltage dropped to 0.1V. What you saw was the battery voltage recovering under no load.
What you and no one else it seems has realised is that there is no joke. It's not a trick. THAT'S the joke.
My concern, is not so much if it was a trick or NOT. But if you had merely let the "other" (non-physically "squeezed") battery, recover naturally, by just leaving it to rest, for however long that takes. I DON'T know how long it takes, maybe it is 30 minutes or an hour, but could be a completely different time range. It also would have been able to deliver more power.
I'd say the opposite was true. "A" had a least an hour to recover before retesting (while "b" was being drained). "B" had much less time to recover before being squeezed ("A" took only 15 minutes or so to discharge the second time around).
nb. This assumes Dave didn't go for lunch between the two re-drains.
I have also read that squeezing them with pliers works, but neither of these cases is relevant to my situation.
New Batteriser!
How big is your sledge hammer? .....
Non-Magnetic for use near highly sensitive magnetic equipment; MRI and Clean Room environments; Corrosion Resistant even in the most severe environments
QuoteNon-Magnetic for use near highly sensitive magnetic equipment; MRI and Clean Room environments; Corrosion Resistant even in the most severe environments
MRI system misbehaving? Not a problem...
