https://youtu.be/exn90L95dgI
What do you use for a fork?
Very good.
Now, if you keep the electrodes close to each-other and otherwise isolated, like in the contraption starred in the original subject video, where is the conductive path formed?
In between the exposed electrodes.
The very effect (stirring the water) in your video demonstrates this admirably.
Consider the rate of flow in btw the electrodes vs. elsewhere and the resistor network this creates.
This is fluid dynamics and probability.
You're welcome to try and prove me wrong.
My point was that if the device is properly built and used, it is safe enough even if at some local level it seems otherwise (exposed electrodes!!!
If the opposite were true, a user of the shower contraption would be killed as soon as one tries to start the water flow (touching metal presumably).
And the pictures posted in this thread form "the proof is in the pudding" evidence.
Or do we think that fellow Russians and Chinese are so tough that they just push the previous dead body next to the old pile of corpses and take shower without further hesitation???
The thing is that, if even the smacked together solutions seen on these photos are not regularly killing people, it's for a systemic reason, not for the lack of it (ie. massive persistent spike of luck in Russia and China???).
One more thing, these "contraptions" are certified in EU by EN 60335-1 and EN 60335-2-35
This, of course, presumes sound engineering in design and build, which was my original point.
Therefore, acceptably safe applications of the technology exist.
Therefore, the technology itself is not fundamentally "unsafe", (only the bad examples of application are unsafe, as with any other technology)
I rest my case. (damn, I sound like a lawyer, I best shut up...)
K
