Author Topic: EEVblog #894 - Keysight U1461A Insulation Resistance Multimeter Teardown  (Read 9320 times)
Offline EEVblog
Inside the Keysight U1461A Insulation Resistance Multimeter
The following users thanked this post: AF6LJ
Offline Muttley Snickers
Once again a great video on a very nice product.   :-+
The blue on the terminal could perhaps be a new elaborate form of tamper detection, who the hell would have access to a blue marker pen or sharpie anyhow ?, I'd be screwed with plenty of Loctite about the place but not a blue marker anywhere to be seen.
Offline Cliff Matthews
    • General Repair and Support
Love that soldering by the HV transfo, but what happened to C130 and C131? For a new product, I guess they didn't need the extra multiplier stage. Wah wah wah... Anyway, on the absence of a 10amp internal shunt, with all those adapters why couldn't they have rigged something external for current?
Offline Someone
Shutter speed, not the frame rate was being varied to observe the scanning of the display. It can be done with frame rate too but requires fine increments.
Offline iloveelectronics
  • Country: hk
In the video you mention only Fluke has a similar product but it's not exactly correct. Brymen has a new BM870 series which seems fairly comparable too, at much more affordable prices.
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
The following users thanked this post: gnavigator1007
I just noticed that the remote switch probe is slightly different on this meter when compared to the similar probe on the U1280 series, The U1461A uses the U5403A lead and the U1282A uses the U5404A as linked below, looks like you could use the U5404A on the U1461A but not the other way around with the jointed input jack, thought it was worth mentioning, don't get your wires crossed.   ::)
U5403A Switch probe for the U1461A.
http://www.keysight.com/en/pd-2422444-pn-U5403A/remote-test-probe
U5404A Switch probe for the U1282A.
http://www.keysight.com/en/pd-2615346-pn-U5404A/remote-switch-probe
Offline bktemp
What's the purpose of the two villard cascades?
I doubt they generate anything near 1000V, because there is almost no clearance around the traces.
The spacing around the transformer is much larger, so my guess would be it generates the 1kV directly using 2 windings in series with each having its own rectifier (C153, C154, D38, D39) with R135 being part of the voltage divider for the voltage regulation.
Offline Fungus
That doesn't matter. It's not going to arc so long as there's an easier path to go down.
Offline bktemp
If it arcs over, the arc will be the easiest path to ground. And if you have an easy path to ground somewhere else, it will load the supply and you don't have 1kV anymore.
So no, your argument is totally wrong.
Offline Fungus
Not as wrong as this: "It's not arcing so therefore it can't be 1000V"
You really think they'd release a $900 meter that can't measure voltage?
Offline NANDBlog
  • Current job: ATEX certified product design
The reason they dont build in the Bluetooth module: It needs to be FCC (and TÜV and who knows what else) certified, and that takes time, money... Doing that for every meter is a lot of trouble. I would not want to respin a multimeter because some RF stuff refuses to behave.
Offline Monkeh
The same reason the wifi and bluetooth in laptops is (almost) always on a card.
Offline bitwelder
Curious, the transformer placement seems to be a teeny tiny bit skewed from the main PCB axis.
Offline AF6LJ
That was a good teardown....
Nicely built.....
Thank You again for the good videos Dave.
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Offline TheAmmoniacal
  • Country: no
  • Cut me some slack, I'm a biochemist!
Yep, Dave should get his hands on this for comparison.
I collect [corporate] mugs.
MTBF ~ 700.000 h
Offline Hydrawerk
What is the point of an OLED display? It must consume the AA batteries pretty quickly.
And where is the high voltage line that goes from transformer to output jacks?
steverino
  • Guest
I'd like to see a brymen review also.  There was a US located member on the forum trying to source without luck.  Anybody know where to purchase one for US market?
Offline Fungus
People buy shiny things. Simple as that.
I've even seen EEVBLOG members go gaga over those - people who ought to know better.
Yep, and it has no DC input jack so you can't plug it in when it's on your workbench. You need to constantly stop work to change/charge the batteries. :palm:
The engineers must have facepalmed when management told them to make a meter that can only be used in dim lighting and you need to charge it every other every day (via the input posts!).
Marketing knew best though: There's a whole sector of drooling idiots who only see "color display!!!!"
The only thing missing is an Apple logo.
PS: The 'drooling idiots' aren't necessarily the meter owners. If I was a consultant I'd buy a huge OLED meter just so could pull it out in front of clients to show how amazing I am.
The other guy has a black and white meter, mine is color. Who you gonna hire...?
(And pray the boss leaves before the battery runs out...)
« Last Edit: June 30, 2016, 10:05:26 am by Fungus »
Offline EEVblog
Hmm, I didn't know about that model.
Offline EEVblog
You simply use a pre-certified module and solder to the board. I'm doing that for my custom meter design.
Offline Hydrawerk
I have no problem with OLED displays on a bench meter, that is not powered from batteries.
Offline f4eru
    • Chargehanger
Hello,
The blue glue on the ground post screw is a safety feature : if the screw comes loose, and the ground post is lost, the whole meter "potentially" goes to 1000V, and it can arc over to your fingers at many places (in worst case). So that ground connection is safety relevant.
The two cascades are probably for different voltages : the two with the small components and 4 stages are probably for 50V, the one with big component and one stage is for higher voltages.
The presence of the 6uA range is easy to explain : that is what is used to measure the very high resistances !
Peter Oakes also did a couple of video reviews on this meter and the common terminal was not blued on his one as shown below, if it was used to lock the thread then I would expect to see remnants of it on the thread itself but this is sometimes not the case in all applications.
Peter Oakes U1461A general review.
Peter Oakes U1461A chilling review.
Offline peteb2
Yep... great meter and yeah i own one but what i really like is the external software Keysight make available for it, especially the handy-dandy database around insulation testing when you are required to track a whole bunch of different equipment...
Offline peteb2
... and here's what is probably Keysight's own produced videos on YouTube explaining this software but i am sorry, the young lass who explains things obviously has English as a second language. I've watched it 10 times... i'm still confused.
