Next time if you want to check the status of a network link continuously you could useCode: [Select]And it will ping continuously on *unix. On Windows you need to add -t.ping 8.8.8.8
To stop press ctrl+c.
Analogy:
How would you react, if someone made a Youtube video, which seemed to "attacked" Fluke multimeters ?
I've done one:
And many others for brands and products I'm big fanboy of.
I'm a bit confused. Doesn't the PE effect only work for UV light that has enough energy to knock off some charge carriers? Why do they say a laser pointer has the same effect? Shouldn't most laser pointers be low frequency red light? I know the semiconductor industry uses UV light for photoresist for etching into the silicon, but that's still UV. Any clues here?
Just shot a follow-up video to this and lost ALL the footage because of that stupid SD card bug in the Canon HF G30
At the risk of repeating myself, the big guns at Canon should be taken out the back and shot.
The exact same bug is possible on my Sony NEX-VG30, it ain't just Canon.
I should probably test the WiFi chip better though, but i couldn't get it to fail when the board was flipped over, no matter how close.
What happens if it is exposed to a professional photo flash set up, there is many times more energy from those. Will it kill the chip permanently and from what distance etc.
Mk14, Simple, the phototransistor has the junctions exposed deliberately, with only a clear oxide layer over them. The IC has the junctions buried deep in the silicon, and you are putting the light through a thick layer of absorbent silicon, which is somewhat transparent to light in the IR while it is opaque to most visible light.
The EPROM also deliberately exposes the floating gates, which is the charge store for the memory, so you can erase it by providing enough UV light to cause the electrons to tunnel through the thin oxide layer erasing the cell. Slightly different in that they use a floating polysilicon gate electrode in an insulating oxide layer as a gate to control a MOSFET switch, with another gate very close to it that is used only during programming to place a charge in the gate by quantum tunnelling.
What I find weird is ithat I have a version of raspberry pi 2, that doesn't seem to have a U16 on it.
The layout of the power supply area is also completely different.
I can't test for the issue since I don't have an slr with a xeon flash.
You will note that the board from the original video dave did it said Raspberry pi B+ 1.1
However mine is a 1.2 BUT the new video is clearly for version 3.
The EPROM also deliberately exposes the floating gates, which is the charge store for the memory, so you can erase it by providing enough UV light to cause the electrons to tunnel through the thin oxide layer erasing the cell. Slightly different in that they use a floating polysilicon gate electrode in an insulating oxide layer as a gate to control a MOSFET switch, with another gate very close to it that is used only during programming to place a charge in the gate by quantum tunnelling.Thanks, I'm very impressed with you answer, which has taught me a lot.
I see, so because only certain parts of the EPROM are actually exposed, which can be carefully/precisely controlled by the masks (or similar) and IC production processes etc. Although to the human eye it appears the chip is "fully" exposed. In reality it is not. Only the parts which need to be erased.
For serious/reliable EPROM usage, it was needed to cover the UV window, ideally with proper UV/EPROM stickers (pricey, because they had an aluminium/metal film), or the cheaper solution was to just use paper labels. Otherwise they would sometimes mis-operate under bright light or even normal light, or maybe even eventually self erase.
Now I understand a lot better, why it is so difficult to get this problem to occur. Thanks again!
I fell foul of this once, I think it was a 27C011 that wouldn't program in a bright sun lit room, but would in an artificially lit room.
It turned out out that the same die was used for both the 27C010 (might have been the 27C101 it was a long time ago) and the 27C011.
One was 16bits wide and the other was 8 bits wide and a non erasable fuse was programmed at the factory to determin which part it was eventually going to be. In sunlight the state of this fuse would flip and it became the other part until the light was removed. Our customer blamed us for having a faultly programming algorithm but sticking a label on it solved the problem. We informed the manufacturer who fixed the issue in a later die revision.
I think people program their chips, typically before covering the UV window, anyway. So it was a bad problem.
