Author Topic: EEVblog #934 - Raspberry Pi Supercomputer Cluster PART 1  (Read 35378 times)
Offline EEVblog
« on: October 15, 2016, 12:01:59 am »
Dave sketches up an idea for a more integrated Raspberry Pi supercomputer cluster with integrated ethernet and power.
The following users thanked this post: frank_gamefreak, SgtTech
Offline riyadh144
Re: EEVblog #934 - Raspberry Pi Supercomputer Cluster PART 1
« Reply #1 on: October 15, 2016, 12:35:15 am »
You have to be careful, as the 5v pin has no input protection, I have killed a few RPis doing exactly this.
Offline johnkeates
« Reply #2 on: October 15, 2016, 01:49:17 am »
Not only the power pins, but the GPIO pins have practically no protection either.
Regarding networking, there are more options besides ethernet, you could use the serial port on the thing and PPP over it, at least one UART is on the header if I'm not mistaken.
To connect them together, you'd need a way to have them all feed back to one Pi just doing the PPP to Ethernet bridging and you can use it's existing ethernet connection to plug in to your network. It would take some sort of expander or multiplier to get all those serial connections connected back to that one Pi, so an extra chip is still needed, but only one and not one for every Pi. The nice thing about Linux is that as long as something does stuff like TCP/IP, any application running on top of it won't know or care about what transport is used on the lower levels. There is support for at least serial, parallel, usb, ethernet (of course), firewire, pcie, IRDA, ISDN and a while back someone was working on TCP/IP over I2C (but I'm not sure if that was ever completed).
With the networking thing on the hardware side, there is a software side too: proper hardware has MAC addresses for network interfaces on Ethernet, and other busses have arbitrary configurable or serial number based addresses in many cases. If you were to want to configure your cluster in a somewhat automated manner, you could just have the IP addresses preconfigured based on those addresses in a DHCP server. The compute module would request an address, the DHCP server would recognise it's MAC address or port ID and assign it the correct address.
Regarding the Software, the Raspberry Pi guys have 'Raspbian' which is a modified version of Debian, specifically for the Pi. Since Debian is completely free/libre/open/wank-word-of-the-day and the process of adding Raspbian modifications on top of it is documented, the software should always be maintained and maintainable. There is no secret sauce or a commercial entity required to keep it going on the Linux-based side. On the bootloader and GPU side of things, it's a bit tricky, since Broadcom still thinks that has to be 'secret sauce' for some reason (as if nobody else has a CPU that can boot... or a GPU that does graphics). There is the bootloader binary blob file that reads config.txt, and that's the part you can't really maintain if you're not a broadcom-zombie, so that's something that may not always be kept up-to-date. On the other hand, does it really need to be 'maintained', since it's just there for one thing: initialise the GPU, and start it, then let it start the CPU (yes, that's how the thing does it) and setup the DRAM, and kick the kernel into action. So as long as the hardware doesn't change and the kernel is fine with whatever the bootloader parks in memory, it should work indefinitely.
For other boards, this may not work out so well. There is this Banana Pi, and the Orange Pi, and there are probably a ton of other Pies (enough to fill a pastry cookbook?), and we have the 'chip' and then there are the minnow boards, beagle bones, and LeMaker is doing stuff, and everyone is coming to join the club. Specs-wise, that's nice, but when it comes to software, unless you have one of those Linux distributions (like Debian or Fedora) to build on and a platform specific community (like with Raspbian) to maintain tweaks for the board-specific things, it's impossible to maintain or develop in a workable and long-term way, because the resources are simply not there. Since software and the internet (and everything connected to it) is always changing, at some point, you'll always have to update, upgrade or modify the devices and/or software in order to keep using it or keep it connected to others. Try finding a serial modem, or an IrDA adapter, heck, try finding an analog phone line! It's annoying, but as long as stuff is connected or has to work together, everything has to keep up. (up to a certain level, of course)
So when picking a board or software distribution, the community or upstream projects feeding the software that runs it are about just as important as the hardware specs themselves.
Without good software, those tiny boards won't even cut it as a paperweight (too light to hold anything down!).
The following users thanked this post: EEVblog, elgonzo
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #3 on: October 15, 2016, 04:13:01 am »
i'd think twice about routing the slots in the backplane to accomodate the Pi headers...
it may be smarter to make small right-angle transition PCBs that would allow you to keep the backplane intact for bussing and mechanical strength.
The transition 'board' may also offer other connection and mechanical benefits as it evolves.
Don't ask a question if you aren't willing to listen to the answer.
The following users thanked this post: elgonzo
Online NiHaoMike
    • Facebook Page
« Reply #4 on: October 15, 2016, 04:22:30 am »
What about use a small FPGA to connect all the SPI lines with a master node? Or if possible, set the USB port to gadget mode and use ordinary USB hubs to link to master nodes.
I have a cluster of cheap smartphones for mining altcoins. Connectivity is just a cheap wireless router dedicated to serving the cluster. A spare 120mm fan connected to a wall wart keeps them cool.
Offline 6581
« Reply #5 on: October 15, 2016, 04:26:12 am »
Two ideas - not sure how great or viable - for physical density:  1)  45 degree connectors on backplane/motherboard, could allow sliding these tighter next to each other - (like some memory modules), 2) two boards on top of each other - top board upside down, raspberries interleaved. Just my thoughts while watching.
Great project, very interesting.
Online rs20
« Reply #6 on: October 15, 2016, 04:30:33 am »
Really cool project! A couple of ideas:
  • If you're already getting a PCB made, perhaps you could make little adapter PCBs that have a standard female header, and a card-edge connector on the side. Then you can use cheap-as-dirt (because they're so common) PCI-express connectors. This way, you don't need the slots in the PCB (and the associated routing annoyances), and you don't need any extra spacing between the modules to accommodate the sideways mounting motion. You also gain some nice features built into PCI-express, like ground-before-power, making hot-plugging modules significantly safer, perhaps.
  • It might be a nice idea to devote a few GPIO pins to a simple slot identifier: literally just a binary pattern of grounded pins (cost: $0). That way, it'd be straightforward to write a little script on the Orange Pi that enabled pullups, read in what slot it's on, and define a static IP address accordingly. (Bonus marks for silkscreening [partial] IP address directly onto the board!) The way, if you see a failing board and want to SSH in to see what's going on*, you know which IP address to use. All while the OPi's are running exactly identical system images.
* Or want to use a particular one because you're using the GPIO breakouts that you mentioned.
« Last Edit: October 15, 2016, 04:36:20 am by rs20 »
Offline facosta
« Reply #7 on: October 15, 2016, 04:48:41 am »
I'm not sure about the price Dave quotes for the Orange one. The cheapest ones I can find are AU$25 from HK delivered and the cost will double when you buy from the States once you include delivery. Obviously I'm looking at the wrong side of the distribution line. By the way, if you are in a hurry and need to buy it one of these puppies in  the local market, the average cost will be similar to the USA plus taxes or AU$55ish.
Any ideas where to look for a better deal?
Offline MauriceS
« Reply #8 on: October 15, 2016, 04:54:32 am »
There are more ways even with the Pi Zero, one of them is to use the USB connector and use USB Ethernet emulation mode:
https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/overview
So that would mean to have a bunch of micro USB sockets on a board and a USB hub. There is one USB Host needed, and the Zero's could be slaves, so one Pi 2 or 3 being the cluster master. Costwise that would be likely even less than having a ENC28J60 in use there.
Using the ENC28J60 (and there is a 100mbit version too) - there is a possibility of cost saving to use capacitive ethernet coupling, which i know that works. The company I work at uses that on the backplane of one of our systems, and we don't have problems. That would save extra magnetics...
The most funkiest solution would be to use SPI, but the problem would be that that would need a linux driver, and the second issue is that it looks that the broadcom MPU only supports master mode, so a (semi) smart slave would be needed based on an FPGA (expensive) or a microcontroller... Either one with as many SPI slave interfaces as possible - I found Microchip makes some chips with 4 SPI busses.
Offline Stefan Payne
« Reply #9 on: October 15, 2016, 05:29:05 am »
Hm...
2 Things:
1. Why not use some (short) flat ribbon cables? Than you don't Need the Slot inside the board, you just put a connector there and off you go. Though it might be some additional work for you to make These cables...
And 40 pin Flat ribbon cables should be easily obtainable via eBay. You may be able to get a box full of those -> old IDE Cables.
I don't know if the 80pin ones would work though...
2. In Ethernet the 'magnetics' are some Kind of Isolation transformers. So it may be possible to get away without it. But I've never done this, so don't Quote me on that...
Some Kind of mechanical Thing to screw the board into is needed anyways, is it not?
So I think the Version with the flat ribbon connector could be more viable, especially since you can use it to get around the 'different' Pinout between the Orange Pi and the normal Pi...
Offline Towger
  • Country: ie
« Reply #10 on: October 15, 2016, 05:37:39 am »
Wifi Dave wifi...  Just whack a couple of dollars wifi dongle into each one and use a dedicated wifi router.
The following users thanked this post: Fungus, mib
Offline Brumby
« Reply #11 on: October 15, 2016, 05:44:19 am »
All this faffing around because of non right-angled headers in place.
Dave - I'll offer to remove (up to 100 of them) for you for free - just to take this irritating limitation out of the equation.  My ZD-985 works brilliantly on headers.
Offline bktemp
« Reply #12 on: October 15, 2016, 05:51:53 am »
Adding an ENC28J60 will waste a lot of power: Those things get pretty hot, because they draw 120mA when idle and 160mA when transmitting. That's an additional 0.5W per chip!
ENC424J600 is faster and draws less current.
Offline somlioy
  • Country: no
« Reply #13 on: October 15, 2016, 07:49:13 am »
Finally a eevBlog-project. Please complete it.  8)
Offline DJVG
« Reply #14 on: October 15, 2016, 07:53:36 am »
I'm currently working on something similiar with the same boards (and the ones with 2GB ram) and I'm very suprised to see a video like this. Really nice!!
If you want to go smaller you might want to look at the NanoPi NEO: http://www.friendlyarm.com/index.php?route=product/product&path=69&product_id=132. It uses the same AllWinner H3 CPU and it's only 40x40mm!
Offline hans
« Reply #15 on: October 15, 2016, 09:26:35 am »
My thoughts:
ENC424J600 is an overall nicer chip and all.. but via SPI it won't give much more bandwidth. In addition, unless you tell it to fix to 10Mbit, at 100Mbit network speeds the chance of a ENC buffer overflow is much larger. 100Mbit/s potentially going in, only 14Mbit/s can go out (max SPI speed).
So apart from power, it won't buy you much. The package (QFP44) is also larger.
In terms of magnetics I would watch out what voltage reference (GND or VCC) the ethernet tx/rx pairs are connected to. You could also use capacitive coupling of ethernet lines instead of magnetics, seperating the DC reference, which is indeed still much cheaper and smaller than magnetics.
I would also likely add a 60-80mm fan in the enclosure. Because 40W of dissipation sounds like quite a bit of heat.
« Last Edit: October 15, 2016, 11:38:08 am by hans »
Offline metRo_
  • Country: pt
« Reply #16 on: October 15, 2016, 09:34:37 am »
And I think faster is the key here... if you can't spread the data fast enough to all boards you are wasting the parallel computing power of this kind of solution.
Offline mariush
« Reply #17 on: October 15, 2016, 10:05:52 am »
Considering the low speeds, it would be cheaper to just make your own RJ45 to 1x8 or 2x4  or 2x5 0.1" header at the end of 5cm of cable or something like that of network cable. Just enough to make a 180 degree turn and go down towards the main pcb, or to route the cable to a convenient location where it could go in a network switch. And honestly, switches are so cheap these days that it would probably be cheaper to just buy one from the store and remove it from its case and attach that internal board to your board that holds all those pi's in place. There's new 8 port switches for 10$ and 5 port switches for around 8$ in my local store in a country with 20% vat .. probably can't even buy the parts separately from stores like Digikey for that price.  You could probably buy 24-48 port used switches on eBay for less than 30-40$.
Also, 40 pin cables ribbon cables should be fairly cheap if you buy in volume,just look on ebay for ide cables - 1$ a piece ... here's an example: http://www.ebay.com/itm/40-Pin-IDE-ATA-HDD-Hard-Drive-Ribbon-Band-Cable-Dual-Device-Disk-Connectors-/171288701698?hash=item27e19a2b02:g:EgIAAOxyhXRTPLJc
You could convert such a cable into two separate cables just by cutting the ribbon cable near the middle connector and installing a new 40 pin connector at the end of the loose ribbon cable. On digikey, such connectors seem to be more expensive than an IDE cable from ebay, looks like they're about 1.5$ each : http://www.digikey.com/product-detail/en/3m/89140-0001/MSC40A-ND/229687
But alternatively, especially if you don't need all 40 pins, you could make yourself three ribbon cables just by cutting the ribbon cable in the middle or to the length you desire and install smaller connectors at the other ends (the ones which would go on your base board).
For example, you could use 10 position (2x5) connectors which are 30 cents each (which you could also reuse for the network jack) :  http://www.digikey.com/product-detail/en/on-shore-technology-inc/101-106/ED10500-ND/2794212
or you could use 20 position (2x10) connectors which are around 46 cents each on Digikey : http://www.digikey.com/product-detail/en/assmann-wsw-components/AWP-20-7240-T/HHKC20H-ND/4864473
So for 1$ ide cable + 3x 30 cents = ~ 2$ you got yourself 3 x  40 pin ->10 pin cables or for ~ 2.5$ you could have 3 x 40pin -> 20 pin cables
An extra RJ45 network jack and a 30 cent header could save you 2-3$ in that microchip IC
I was thinking you could make boards like PCI-E cards on which you'd attach up to 7 PIs (so that you'd use 8 port network switches) and those 10-20 wires from each PI would be routed to the PCI-E slot (which if i remember correctly has around 150 pins on the long side), and you could use the tiny side to send 12v or 24v on the pci-e like card and have some dc-dc converters on the card to convert that down to 5v for each pi
The pci-e slots are easy to buy and could also be positioned on a motherboard in a way that could allow you to screw these fake pci-e board to a computer case for rigidity, support whatever... you get a case with around 10 slots so you could have 10 x 7 PIs or something like that all powered from an atx power supply on 12v with regulators on each pci-e like card producing 5v
« Last Edit: October 15, 2016, 10:11:36 am by mariush »
Offline suku
  • Country: hu
« Reply #18 on: October 15, 2016, 10:10:31 am »
you could actually design the board to be fairly low profile, so it's possible to put the motherboard upside down into the case and use standard respberry pi's... i think it'd be nice to make it compatible with both boards....
Offline alexanderbrevig
  • Country: no
  • Musician, programmer and EE hobbyist
    • alexanderbrevig.com
« Reply #19 on: October 15, 2016, 10:25:24 am »
If you stagger them you'd probably get twice the density with a cost on its width
Offline CM800
« Reply #20 on: October 15, 2016, 10:40:16 am »
Might I suggest this special snowflake of a connector?
PCB mount Ethernet Plug!  :-DD
The following users thanked this post: cowana, rs20, ckambiselis, chris_leyson
Offline nctnico
« Reply #21 on: October 15, 2016, 10:50:12 am »
I doubt it makes much difference in cost to order multiple PCBs with orange pies mounted flat (and mechanically fixed to the board!) or one board with 10 standing (well, hanging on a connector). I'd mount them flat for mechanical stability. Either way a dense solution with many pies may need forced air cooling.
« Last Edit: October 15, 2016, 10:52:24 am by nctnico »
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #22 on: October 15, 2016, 10:53:00 am »
Instead of cutting slots into the backplane, you can use an adapter board that have a straight 40-way pin header socket, cutouts allowing the USB and Ethernet jacks poke through, a card edge connector to the motherboard for easier node removal, network circuitry if you are using GPIO headers for networking, and maybe some power supply and protection circuitry (so your motherboard don't have to carry too much current.) In fact by doing this your backplane will also be compatible with Raspberry Pi, if a different adapter board is used.
Each adapter board have an buck converter that converts 12V to 5V, the ENC28J60 chip and half of the termination resistors. The backplane then would be a plain old Ethernet switch.
« Last Edit: October 15, 2016, 11:17:03 am by technix »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #23 on: October 15, 2016, 11:00:10 am »
Connector issue is easy - something like a Samtec SSW right-angle header with long pins.
http://suddendocs.samtec.com/catalog_english/ssw_th.pdf
PCB pin lengths of 0.3 are available, which would probably get you high enough off the board
Day Job: Mostly LEDs
The following users thanked this post: rs20
« Reply #24 on: October 15, 2016, 11:03:01 am »
My thoughts exactly - either emulate multiple ENC28J60 chips and a swithc in the FPGA, or if there is a mechanism in the ENC protocol to add waits, maybe mux the SPIs into a single ENC chip.
Offline EEVblog
« Reply #25 on: October 15, 2016, 11:16:59 am »
Another option is the ODROID-C0 http://www.hardkernel.com/main/products/prdt_info.php?g_code=G145326484280
It comes without populated GPIO and USB connectors. Not ultra cheap but it might suit some uses.
Someone on youtube pointed me to the nanopi-neo:
http://nanopi.io/nanopi-neo.html
It's only $8 for a 4 core H3
Offline EEVblog
« Reply #26 on: October 15, 2016, 11:18:03 am »
Because that's another complex step. Far easier to just use the chips.
Offline EEVblog
« Reply #27 on: October 15, 2016, 11:22:07 am »
Hadn't looked at the power consumption yet, thanks for the heads up.
Offline EEVblog
« Reply #28 on: October 15, 2016, 11:24:00 am »
I couldn't find one of those!  :o
10 bucks says the height does not match the required vertical USB micro PCB plug!
« Last Edit: October 15, 2016, 11:26:45 am by EEVblog »
Offline EEVblog
« Reply #29 on: October 15, 2016, 11:28:33 am »
Yeah ,someone else pointed this out and I really like it. Very cheap, available by the looks of it, and tiny.
Offline CM800
« Reply #30 on: October 15, 2016, 11:30:21 am »
Went on RJ45 on Farnell, then clicked plug and solder / through hole, this came up..
Think you might use it? Much more elegant solution.
It might even be possible to make a fancy footprint to use this rightangle USB Type A right angle SMT connector as a THT vertical:
http://uk.farnell.com/multicomp/mc000991/usb-2-0-type-a-plug-smt/dp/2476092?MER=sy-me-pd-mi-alte
Don't know how well the boards would line up however... I suspect not so well. May not matter. (depends what board you go for)
They look small enough you could use them horizontally with standoffs and use pogo pins for the ethernet connection... that could be quite elegant.
EDIT:
Brought 4 of them! Look perfect to get antiquated with ARM / Linux. Maybe in the future I can fit a nice CPLD or FPGA under it too.
« Last Edit: October 15, 2016, 11:43:33 am by CM800 »
Offline bktemp
« Reply #31 on: October 15, 2016, 11:43:56 am »
You could use the PCB mount ethernet plug next to an PCB mound USB A connector and plug the NanoPi NEO into both connectors: Ethernet for communication and USB for power (you will be using the USB output as power input, but it should be ok, the schematics shows the 5V USB connected directly to the internal 5V rail).
Offline rob77
  • Country: sk
« Reply #32 on: October 15, 2016, 11:57:22 am »
regarding all the networking suggestions for a "fun" project like this ... the top priority is the question: does linux have a working and usable driver for that solution ? if the answer is no, then you should ditch the idea right away because it would increase the complexity of the project (and not everyone is able to write network device drivers for linux).
so the viable options are (simplest to most complicated):
- wifi dongles + dedicated wifi router
- pppd over serial to a "master" with ethernet connection and acting as a router/bridge
- dedicated SPI ethernet chip for each board (ENC28J60 or enc424j600) + ethernet switch (without magnetics of course)
the other possibilities are countless , virtually you can do anything.. but the question is the drivers. of course you can write you application specific communication routines but that would be single purpose...  if you are able to write the network device drivers for your solution, then go ahead with it... otherwise go for a solution which is already available.
« Last Edit: October 15, 2016, 11:59:04 am by rob77 »
Offline EEVblog
« Reply #33 on: October 15, 2016, 12:04:40 pm »
Yep, that was my first thought. Although I wouldn't use pogo pins, just suck out the RJ45 and USB and solder them in place. Could have multiple flat motherboards stacked, along with thermal sheets going over the boards and processors maybe. density would be super high. 5 per board, 5 boards stacked would be bugger-all volume for a 100 core ARM system.
Best passive thermal coupling would be 5 boards mounted back to back with thermal pads going to a thins case top and bottom.
Offline EEVblog
« Reply #34 on: October 15, 2016, 12:07:07 pm »
Murphy will ensure it's not that easy and the two are not compatible height wise.
Offline EEVblog
« Reply #35 on: October 15, 2016, 12:08:31 pm »
Doesn't matter, it's just like having dozens of RPi's plugged into a switch. Linux doesn't know any  different.
Offline rob77
  • Country: sk
« Reply #36 on: October 15, 2016, 12:13:42 pm »
i was referring to the solutions suggested above - like the multiplexed SPI... if there is no driver in the kernel for it, then it will over-complicate the project because you will have to write the divers for it.
Online rs20
« Reply #37 on: October 15, 2016, 12:22:34 pm »
Mike's suggestion explicitly mentioned emulating the ENC28J60 on the FPGA, in which case the pre-existing ENC28J60 drivers would work. However, I'd personally prefer just to use real chips though, impersonating chips on an FPGA sounds like quite the rabbit-hole.
Offline CM800
« Reply #38 on: October 15, 2016, 12:26:45 pm »
Could machine a beautiful long aluminum or copper block under them all with raises in them to touch the processor, then throw a hole through the length of it and pump water to keep each stack cool. I think this could be a fun project, even competition.... how many cores per square cm can we fit in with using only off-the-shelf ARM boards (no custom ARM boards)
Offline EEVblog
« Reply #39 on: October 15, 2016, 12:30:19 pm »
Water cooling would not be required, passive would work fine.
Offline EEVblog
« Reply #40 on: October 15, 2016, 12:34:39 pm »
Exactly. Why you'd bother to go to that effort just for a project like this is beyond me.
It's a huge job, look at the datasheet and the hundreds of registers and whatnot. What worthwhile benefit d you get for all that effort?
Time and effort much better spent on other aspects.
« Last Edit: October 15, 2016, 12:37:46 pm by EEVblog »
Offline rob77
  • Country: sk
« Reply #41 on: October 15, 2016, 12:39:27 pm »
i was more talking about this one
muxing into a single ENC chip would mean you have to implement some kind of virtualization in the driver - the driver would have to hold a "virtual" ENC chip instance and it would have to re-inicialize the real ENC oince it get it's "machine time". at least the MAC address would have to be re-initialized on every context switch of the real ENC - otherwise the whole cluster would appear as a single node on the network (single MAC address).
Offline hans
« Reply #42 on: October 15, 2016, 12:39:57 pm »
Multiplexed SPI sounds like a big can of worms. You'd need to multiplex 4 I/O's in 2 directions 8 times, which does not cut down on the number of chips and just a little on cost (ENC28J60 is 2.35 EUR each, a 4ch mux is probably more like 0.50 EUR).
Also there are no drivers. And I think this is the biggest problem; because I doubt it's even possible to create a pleasing workable system. The ENC28J60 is a nice chip because it has filters like unicast and such, so it drops any frame from the buffer that is not targetted at it's own MAC. If you have 8 linux boxes talking through the same ENC28J60 they would need to be assigned individual software MAC's. They then need to poll the ENC one by one to check if there is a packet they can take. And how are you going to handle stuff like broadcasts, multicasts and packets that do not belong to the cluster? Again: can of worms.
Emulating the ENC28J60 sounds doable, but probably a lot of work even for a dumbed down emulation. And I imagine you need a pretty large FPGA to emulate the frame buffers for each ENC28J60. If you have 8 emulations running, times 8kB of buffer, that's 64kB of RAM + all logic required to basically implement an ethernet switch. All this work for 25 euro worth of chips. Could be fun, but it is an enormous undertaking and ultimately does not add unique business logic that doesn't already exist and you absolutely need to implement in a FPGA.
ENC28J60 and ENC424J600 drivers are already in the kernel and can be used via SPI, but like I said earlier both are limited to around 10-14 Mbit/s respectively.
Offline CM800
« Reply #43 on: October 15, 2016, 12:46:14 pm »
True... I'm just looking for an excuse to use a tiny radiator like this:
Adorable  :scared: :scared:!
Also, is there any reason you don't like the idea of pogo pins? (to save desoldering / enhance plug / playability)
« Last Edit: October 15, 2016, 12:49:52 pm by CM800 »
Offline microcircuit
« Reply #44 on: October 15, 2016, 01:01:03 pm »
Hi Dave,
Just a thought, rather than routing slots in your motherboard, if you were to fit the right angle connector to a Pie before soldering it to the MB this would provide the required spacing stand off between the MB and Pie.  Not having a connector or Pie to test I'm unsure if the connector pins are long enough for this to work.
Excellent videos,
Phil
Offline crasbe
« Reply #45 on: October 15, 2016, 01:54:44 pm »
Hi Dave,
I don't know if you've seen my comment on YouTube, but maybe the NXP SC16IS740/750/760 Slave UART might be a solution to look into.
That's a I2C or SPI-attached Slave UART and you can put up to 16 of them onto one I2C-bus.
You'd have to dedicate one Orange Pi as a master for PPP over serial. There is also support for the SC16IS7x0 in the Linux kernel, so the software side shouldn't be too complex.
Greetings,
Chris
Offline CM800
« Reply #46 on: October 15, 2016, 02:18:29 pm »
I've made a nice CAD model of this now, the only inaccurate dimensions are the usb and ethernet height, the length is correct, as is the height of the BGA relitive to the pcb.
I'm not sure about the thickness of the PCB, I made it 1.5mm.
Offline BurtyB
    • 8086 Consultancy
« Reply #47 on: October 15, 2016, 02:28:57 pm »
I've been playing with the NanoPi NEO in my v1.3 Cluster HAT (http://clusterhat.com/dist/img/ClusterHAT-Zero-NanoPi.jpg) which uses USB Gadget mode to provide Ethernet, Serial Console and powering it over a single USB connector.
I can't see the NanoPi NEO without headers on the FriendlyARM site anymore which is a shame but on the up side it should be possible to boot the NEO over USB without an SD card (http://linux-sunxi.org/FEL/USBBoot) making it even cheaper to use and easier to deploy. I'm hoping the Pi Zero will also support it properly one day but it doesn't currently work (https://github.com/raspberrypi/tools/tree/master/usbboot).
Chris.
« Reply #48 on: October 15, 2016, 02:41:39 pm »
I was just thinking about cost ( and power)  if you wanted to do this on  a bigger  scale. Though it might be easier to write an ethernet driver that did parallel comms over the IO lines...
Offline @rt
« Reply #49 on: October 15, 2016, 02:45:22 pm »
Turning the boards 45 degrees would solve the routing problem if the CAD can rotate the footprint at arbitrary angles.
Offline CM800
« Reply #50 on: October 15, 2016, 03:08:48 pm »
I'm trying to make a PCB baseplate for the NanoPi... Ran into something strange.
I've got the USB connector there, trying to add holes for it, but look, they overlap. I'm certain my drawing on the left is correct, the hole positions are a direct overlay of the DXF they provide, and all the 2.48mm headers fit just fine.
Offline BurtyB
    • 8086 Consultancy
« Reply #51 on: October 15, 2016, 03:36:50 pm »
Measuring the board I have it's more like a ~0.8mm diameter hole (~1.14mm diameter ring) on 1.4mm spacing.
Chris.
The following users thanked this post: CM800
Offline Stupid Beard
« Reply #52 on: October 15, 2016, 04:20:46 pm »
Not sure if anyone's mentioned it yet, but a couple of things you will want to consider are the ability to toggle power or at the very least reset each node individually. You may not need to use it very often, but it's valuable when something goes wrong with an update or something. I guess this doesn't have to be more than a physical switch if you want to keep it simple, it just has to be accessible and hardware based so that you don't have to pull everything apart to fix one troublesome node.
Also, whilst your primary use may be low bandwidth, updating the software on all the nodes is not. You may want to take that into consideration before you lock yourself into slow networking. You may decide you don't care, but thought I'd mention it just in case.
Offline CM800
« Reply #53 on: October 15, 2016, 04:22:08 pm »
behold, a little CAD model concept.
What do you think of something like this, Dave?
if you use SMD holders for the 2.54mm pin headers you can fit one on each side of the board.
then a card edge.
the entire board assembly there is only 14.5mm wide. This could be shrunk further by thinning the cooling blocks, however I don't think it'd be worth it as you'll need space between the card edge connectors anyway.
You could break out the Ethernet connections to the board easily enough too, as I've flipped them over.
12x 1.2GHz cores, with water blocks (or just passive)
93 x 14.5 x 60mm space.
That's 81cm3,  6.7cm3 per core
You could make this board double height, fitting 8 x 4 = 32 cores per PCB, the entire base board would fit in a space under 100x100 which means you could probibly get a 4 layer board made up for $50 for 10 pcs in china.
that brings the est price of each board to $85 (8*$9.99 for the 512MB ram version) , so for $850 + backplane cost you could make  a 320 core, 1.2GHz cluster..
... I should probibly slow down now before I end up trying to do Dave's project myself.  :-DD :-DD
« Last Edit: October 15, 2016, 04:42:05 pm by CM800 »
The following users thanked this post: dekra54
Offline positivenucleus
« Reply #54 on: October 15, 2016, 04:59:04 pm »
Regarding going thru SPI to Ethernet to get internet access...
You can use the Rx/Tx (RS232 style, 5V) with PPP.  On this port you make PPP run, not huge speed: 115200 bit/s.
You will need to have a node that has all the other sides of each serial line, which kind of replaces the ethernet switch, but I think it would be cheaper.
One simple idea that I can see for it, is a bunch of USB serial ports connected to a USB hub, and that connected to one of the boards.  Yes cables (USBSerial <--> hub <--> "master node") but way more cheaper in $ and power, and easy to replace.  Maybe you can get the hub chips and create a usb hub on the "motherboard", and have only 1 single cable to master node.  Microchip USB251x can have up to 4 ports and < 100mA total current, but I guess there might be others out there ;)
Serial port + PPP: http://elinux.org/RPi_Serial_Connection
Offline crasbe
« Reply #55 on: October 15, 2016, 05:31:29 pm »
Actually you can go a lot higher with a Raspberry Pi. Let me quote the BCM2835 ARM Peripherals document:
4) The UART itself has no throughput limitations in fact it can run up to 32 Mega baud. But doing so requires significant CPU involvement as it has shallow FIFOs and no DMA support.
https://www.raspberrypi.org/wp-content/uploads/2012/02/BCM2835-ARM-Peripherals.pdf Page 10, at the very bottom.
The Allwinner H3 seems to be pretty similar but I wasn't able to find reliable numbers.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #56 on: October 15, 2016, 08:10:44 pm »
Actually the Alwinner H3 have built-in RGMII for 1Gbps Ethernet. If the required pins are broken out you may want to forget about SPI-based Ethernet and wire up some GbE direct attach connection on the backplane. RGMII interfaces can be connected directly without using a PHY in the middle (This kind of direct attach connection is fairly common especially for faster links, like SFP Direct Attach cables used in low-cost 10Gbps Ethernet stacks.) So if your Ethernet switch chipset supports it you can design your backplane using RGMII direct attach to the processors.
In fact RGMII Direct Attach and SPI-based connection can be used in tandem in a cluster like this. The high throughput low latency 1Gbps connection can be used to transfer bulk data across nodes, while the SPI-based connection can be used to transfer out-of-band events and management packets.
Offline uwe
« Reply #57 on: October 15, 2016, 08:41:17 pm »
Hi Dave,
go for the Raspberry Pi Compute Module. There will be  a new version until the end of the year ;)
From https://www.raspberrypi.org/blog/compute-module-nec-display-near-you/
Each display has an internal bay which accepts an adapter board loaded with either the existing Compute Module, or the upcoming Compute Module 3, which incorporates the BCM2837 application processor and 1GB of LPDDR2 memory found on the Raspberry Pi 3 Model B. We’re expecting to do a wider release of Compute Module 3 to everybody around the end of the year.
Greetings
Uwe
The following users thanked this post: k2teknik
Offline ebclr
« Reply #58 on: October 15, 2016, 08:43:58 pm »
Rapsberry Pi is a bad choice
Better choice
https://www.parallella.org/
Offline Wilksey
« Reply #59 on: October 15, 2016, 09:30:05 pm »
I looked at using a Pi Zero but couldn't find where to get them from all of the suppliers seem to only allow you to purchase 1.
Where can you buy them (in the UK, where they are made...) in multiple quantities, I think a Farnell link said it was discontinued.
Offline Rasz
    • My random blog.
« Reply #60 on: October 15, 2016, 10:30:49 pm »
 :-//  impressive waste of time
at the end of the day after investing >100h you will end up with something equaling performance of two year old used $40 Intel g3258 on $25 motherboard with $20 of ram ... _in some specific tasks_ ... :palm:
btw ZERO all have host and _gadget mode_ USB, meaning they all can act like ethernet over USB. $5 USB hub is the easiest solution
already done to death here: http://www.mycustard.com/ Edit: you will notice indicative lack of any performance/usefulness metrics, its because none exist for such a thing.
$30 off the shelf for custom 4 board pointless cluster pcb https://shop.pimoroni.com/products/cluster-hat
still a total waste of time. This project is EE/node.js web developer trying real computing equivalent of mounting turbo in your mums pinto/morris mini/daihatsu charade/whatever small shitty eco town car.
« Last Edit: October 15, 2016, 10:32:52 pm by Rasz »
Offline EEVblog
« Reply #61 on: October 16, 2016, 01:58:03 am »
That's like what I had in mind. Either back-to-back to center heatsink, back-to-backoutside to a long thin machined aluminium brick that becomes the housing as well. i.e. it's like a "blade" cluster module. Ethernet and 12V/24V power one end (+maybe serial monitor), and status leds on the other end.
Other option is an extruded aluminium case as I had in mind before with rows of vertical boards inside. Have to be mounted longitudinally of course for airflow.
Offline EEVblog
« Reply #62 on: October 16, 2016, 02:02:23 am »
So is your post.
If you don't have anything positive to contribute them please just ignore it.
Offline Rasz
    • My random blog.
« Reply #63 on: October 16, 2016, 03:09:12 am »
did you miss the second half?
EDIT: actually I was hoping your angle in the video would be debunking, proving how delusional project like this is, most people being suckered into this either dont do any calculations or are incapable of assessing performance and genuinely expect at the very least workstation performance (if not mini server).
TLDR:
 very best case scenario one Pee 3 = ~6-8 Pee Zero, and this is using PERFECTLY scalable cluster optimized tests.
in same test one $40 intel processor = ~three Pee 3
« Last Edit: October 16, 2016, 03:19:34 am by Rasz »
Offline optoisolated
  • If in doubt, it's probably user error.
« Reply #64 on: October 16, 2016, 03:59:01 am »
Was very excited to see Dave's video and figured it'd be a good way to learn some more about dealing with more complicated concepts.
Reading up on the requirements of transformer-less configuration and it seems rather straightforward; especially considering a 10mbps connection is more than ample for the stated purpose. Section 4 of this TI guide goes into a lot of detail of the best way to achieve it. http://www.ti.com/lit/an/snla088a/snla088a.pdf
It's made even easier wen using something like the Microchip KSZ8895MQX Integrated 5-port Ethernet Switch chip. Its manageable, but by default will function as a dumb switch; and even includes termination resistors, and power regulator internally, further simplifying the design requirements.
Started designing a circuit using the ENC28J60 and the KSZ8895MQX to see if I can and so far I haven't hit any roadblocks. Using the SPI bus as a Ethernet interface, that never even occurred to me!  :clap:
This is one of those projects where it's possible to get the same results in simpler ways, but what's the fun in that?  :-DMM   :D
Offline EEVblog
« Reply #65 on: October 16, 2016, 04:52:39 am »
You mean the part with "already done to death", pointless, and "still a total waste of time"  ::)
Offline Rasz
    • My random blog.
« Reply #66 on: October 16, 2016, 05:07:01 am »
I think it was made perfectly clear in the video why this was being done and why it was being done in this way.
yes yes, just because
Performance was specifically stated as NOT the primary aim. So my question is why make performance the primary focus of your criticism? Now that's an epic facepalm moment for you.
then dont call it supercomputer. Dave mentions it not being as fast as latest modern intel cpu while in fact the it wont even beat 2 year old budget product.
Learning how to set up ethernet over an SPI bus is generically useful information that may be applicable in other situations.
Its my autistic brain :/  There are only correct or wrong solutions. Correct is one optimizing for something. This one seems to be optimizing clicks, its neither a supercomputer nor has Pee in it. :(
its like https://hackaday.io/project/12122-raspberry-pi-project (spoiler, its a parody)
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #67 on: October 16, 2016, 07:29:57 am »
Nice project!
If you make small adapter boards for each OrangePi you can solve the angle AND the pinout problem. Also, you can do away with the cutout, which makes routing way easier and leaves you more board space. Perhaps even put them a little closer, because now they can be inserted from the top.
This would allow you to mix any compute module that has your bus-signals somewhere on its header connector, opening the door for future enhancements - when a new, better, faster compute module comes out.
[2c]
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline CM800
« Reply #68 on: October 16, 2016, 09:00:28 am »
From what I've been reading online, the Allwinner H3 throttles itself when it gets too hot and has been known to get pretty overheated sometimes, hence why they usually have a heat sink on the bottom.
If you wanted to pack as many of these boards in as smaller space as possible. putting the processors opposite each other (inside) and having an aluminum block with a water pass-through in it might be quite suitable, you could then chain them up to another water block on the case and use a little micro-pump to push the water through. The great thing about this is it will also be silent. I noticed quite a few people have put fans on the heatsinks, even then I've seen reports of it getting up to 57*C here is a pic of the block I concepted:
It's an L shaped block of aluminium or copper with 3 holes drilled in it then partially tapped so that a screw can fit in the horizontal one and two pipe connectors can fit in the other two, cheap and quick to machine. If you were making 10 blades of 4 or 8 boards, I think the benifits out way the additional work as you could put each blade next to eachother with only about 1mm spacer.
« Last Edit: October 16, 2016, 09:07:04 am by CM800 »
« Reply #69 on: October 16, 2016, 09:21:59 am »
Daughterboard with a small DC Dc converter on it, to provide 5V for the pi, and with status LEDs for power, and a small tactile switch on the one side to disable the DC Dc converter board as a reset function. As well then you can put the SPI ethernet chip on there as well with the termination circuit, and simply have 3 sets of zero ohm links to disable the SPI bus from the 40 pin connector on the bottom. the addition of another (probably 10pin) connector on the bottom will allow you to have the 12V power rail ( lower draw on the main board), the 4 differential data paths and 5 ground pins to supply power. This leaves the 40 pin connector free and standard ( with the 3 links if you need SPI on there, otherwise you just leave off the 3 jumpers and do not have the stubs to cause reflections) for further use if needed.
Main board then can be spaced so you have the daughter boards able to channel air flow from a fan through the slots, so allowing the chips to have small stick on heatsinks to cool them, powered by a single 120mm fan on one side of the case and a vent the other side.
Get the board dimensions right and you can have 3 different boards with identical placement of the main 40 pin and 10 pin connectors on the bottom, but with each variant able to accommodate either of the 3 pi variants described, as they are all electrically the same, just with a different pin position on them, or design a 4 layer board that can fit any of the 3 if you solder in the right socket for the board you want to use.
Online rs20
« Reply #70 on: October 16, 2016, 10:42:01 am »
CM800: What is the most elegant way to re-fill the third hole? Any method more elegant than a bolt+O-ring?
Offline CM800
« Reply #71 on: October 16, 2016, 11:40:36 am »
That's generally how most people do it. you could use a rubber plug and a grub screw, or a grubscrew and a dab of epoxy over the end of it.
Offline ziggyfish
« Reply #72 on: October 16, 2016, 12:04:58 pm »
In terms of networking, you could subnet the group of Pis.
For example, if you can fit 30 on a single motherboard, then set the sub netmask to 255.255.255.224, so that 192.168.0.1 to 192.168.0.30 are on one network and 192.168.0.33 to 192.168.0.62 are on another network. (with default being the first address on that switch, for example, 192.168.0.1 and 192.168.0.33 etc).
Then configure the routeing tables on the first device on each board.
« Reply #73 on: October 16, 2016, 12:11:23 pm »
If it is a soft aluminium alloy that you machined simplest is to make a solid metal slug that is 10-20 micrometers larger in diameter than the hole and press fit it in there, or make it a snug fit and use some thread sealer on it. Not much pressure, so the press fit method will be easier, but you need to either have the initial hole a very controlled diameter or ream it out to a controlled diameter.
Done that with a cooling block, though there it needed a more serpentine cooling loop so there were multiple long holes through the block, with end plugs on the ends done with press fitted plugs, and the internal ones were end drilled to intersect multiple galleys with unwanted paths ( to force the serpentine flow) filled with press fitted plugs pressed into the block. Anther just used a long length machine tap to thread the entire cross channel, and then simply put in some threaded plugs and sealer to the required points to block the passages., with the outer hole being plugged as well before being milled to final dimension so there are almost no visible marks of the plugs.
Another method if the block allows it is to drill the pocket for the pipe fittings and then angle drill 2 intersecting smaller diameter holes for the fluid to travel through.
Offline EEVblog
« Reply #74 on: October 16, 2016, 12:20:53 pm »
Then you have nothing to contribute to this thread. Please do us a favor and ignore it.
Offline chris_leyson
  • Country: wales
« Reply #75 on: October 16, 2016, 12:23:44 pm »
Hi Dave, interesting project. I've used the METZ AJP92A8813 pcb mount connector for Gige 1000BASE-T in the past and they work OK, Element 14 stock them. Also been using 0.5mm pitch flat flex cable as co-planar waveguide for Gige ethernet with no problems, I tried to measure the differential cross talk in 50mm and 200mm long flat flex cables at 125MHz but my home brewed test jig was limited to about -50dB cross talk. The connecting cable made very little difference <0.25dB so I guess cross talk in a 200mm long flat flex cable is perhaps better than -65dB or -70dB. Shouldn't be a problem with 10/100 ethernet and you might even be able to get away ribbon cable.
« Last Edit: October 16, 2016, 12:38:26 pm by chris_leyson »
Offline frank_gamefreak
« Reply #76 on: October 16, 2016, 12:34:37 pm »
Hello Community,
first of all my English is not the best, so please excuse that I don't read the complete thread. Maybe someone already mention my ideas but I would like to give my opinion to the product.
I like the idea of staking Pis together to a compact cluster. And I wish we could make a kickstarter out of it.
My first suggestion for the backplain is, could we make a „master bus“. I think of a pin that is zero if no Pi is alive and the first one that it to one. My idea is that the first Pi knows it is the first and starts a DHCP server. Also the other Pis can scan this pin and recognize if the „master Pi“ go offline and the next one have to start a dhcp server.
My second suggestion would be a switch to change the pin-out between raspberry and orange Pi. I think someone like you have an idea how to make this possible.  :-+
And my last one for now is to make the connectors different to your idea mentioned in the video. I think it is possible to place the connectors into the free space. Ok, it have do be a double sided board for this but I think it should be possible. I can't make a good picture of this. But think about a strait connector with one side of pins of each side of the board and the female part of the connector in the space for the Pi.
Please think about it and tell me your opinion about it.
Thank you.
Online rs20
« Reply #77 on: October 16, 2016, 01:14:32 pm »
Nice idea. Earlier I suggested using a series of pins to allow the Orange Pi to detect which slot it was in, and choose a static IP accordingly. This has the advantage that all of them would have a well-defined IP address.
Earlier suggestions included using little adapters with a straight female pin header + a card edge connector; one advantage of this approach is that different adapters could support different boards.
I couldn't follow what you were trying to express here?
« Reply #78 on: October 16, 2016, 02:10:13 pm »
I see a problem here with multiple backplains in a stack. The advantage of my idea is that you only connect the master bus to the next board and all pis know ther is a dhcp.
I hope this "CAD" helps you to understand.
Offline rob77
  • Country: sk
« Reply #79 on: October 16, 2016, 02:46:52 pm »
for those who think this project is a waste of time... no it's not... it's a fun project which will lead to a usable product at the end.
if you go for the highly optimized off-the-shelf solution, then where is the fun and learning ?
i bet my bottom dollar this very thread already helped to share a lot of ideas and knowledge, despite the project is in it's infancy yet ;)
Offline doobedoobedo
« Reply #80 on: October 16, 2016, 04:41:48 pm »
Think of it as a model of a supercomputer. It uses the same cluster architecture of many actual supercomputers, but at a fraction of the cost and power consumption.
I hope Dave finds time to build it to scale and paint it :).
Offline Fungus
« Reply #81 on: October 16, 2016, 05:39:26 pm »
It might actually be better in terms of bang per buck.
Yes, an i7 is probably faster than this but an i7 needs external RAM, a fancy motherboard, etc. It all costs money. For the price of an i7 plus support hardware you could buy a lot of Pis.
It will be interesting to see the final numbers if/when this thing gets built.
Online cv007
« Reply #82 on: October 16, 2016, 05:51:26 pm »
My 2 cents-
You already have the orange pi's,  I would think step 1 would be to just mount them together via standoffs (or not at all), hook up power, connect to a switch via ethernet, get them booting, working together, etc.- then see what you have. If all works as planned, go to step 2. Step 1 is 10 times easier than step 2, and you most likely have everything needed on hand to do it. (You could make a video about it- would give viewers an idea of what the end result is all about, and if step 2 never happens for whatever reason at least you will have had something to show).
You will find out what is important, what is not, you will get actual power measurements, heat measurements, what works, what doesn't. You may discover many things that could be useful to know. Let the set of pi's run for a week and see if they are what you expect- maybe they are flaky and full of little problems, or maybe they are great- you will at least get a good idea before putting in a lot of time on a board design.
Designing a board before you know you have a working 'circuit' seems like a 'trap for young players'  :)
Just a thought. (There is still 2 cents left, so must have been free advice).
Offline Fungus
« Reply #83 on: October 16, 2016, 06:13:32 pm »
I'm pretty sure they'll boot up and run BOINC - Dave already did this in his review of the OrangePi IIRC.
It might be a good idea to get a couple of ENC28J60 modules off eBay and try that part of it though, before making a PCB.  :popcorn:
Offline nctnico
« Reply #84 on: October 16, 2016, 06:34:30 pm »
How about this: create a full size ISA/PCI style board which has an onboard ethernet switch and two external network ports which can be daisy chained. The pies (mounted flat) can be connected to the onboard switch using short RJ45 cables soldered into the board. Ditto for the power. I think each board can hold 8 to 10 Orange Pi zeroes. This would address the cabling problems Dave is trying to avoid. Also the board would fit in a standard PC casing (which provides features like forced air cooling and a power supply) using a standard PCI or ISA backplane (cheap!).
Offline Frant
« Reply #85 on: October 16, 2016, 06:38:56 pm »
Before the project becomes too complicated and overengineered, it may be a good idea to take a breath and think about the actual goal. For example, I would probably choose to make the simplest possible prototype (proof of concept), just to play with it and see what can be expected from such a system in terms of its computing power and practical usability. Significant effort in order to design a professional grade hardware only makes sense if the prototype shows that the expected functionality and/or performance can be achieved. A decent off-the-shelf power supply and a 16-port Ethernet switch will be sufficient for the start. The software aspect of the project can be much more challenging than it seems at this point.
Offline Fungus
« Reply #86 on: October 16, 2016, 06:49:09 pm »
The engineering is the project.
The performance really doesn't matter. It's obvious it's a complete waste of time if "ultimate performance" is your goal. A MicroATX PC with an i7 in it will be much faster/easier to build
The "design effort" is what makes it worthwhile to Dave.
(I'm putting words into Dave's mouth as I understand this. Correct me if I'm wrong...)
The following users thanked this post: alexanderbrevig
Offline nctnico
« Reply #87 on: October 16, 2016, 06:57:20 pm »
I understand the same thing. According to the first few minutes of the video the goal is to come up with a solution which doesn't need a lot of wiring and external ethernet switches as shown in the systems which already exist. IMHO going the SPI to ethernet route is not the best one because it takes a lot of effort to build, create drivers for and it will still be slow.
Offline Fungus
« Reply #88 on: October 16, 2016, 07:04:28 pm »
The video clearly says:
a) The OrangePi kernel already has a driver for those particular SPI-to-Ethernet chips - just edit a text file and enable it
b) Network speed isn't important.
(start at 11:40 in the video if you missed it)
Online cv007
« Reply #89 on: October 16, 2016, 07:16:37 pm »
Booting up and running is one thing, running continuously is possibly another. They seem to require heatsinks (according to one of his reviews), so how big is big enough?  Will the required size heatsinks affect the spacing between boards (physical spacing because of heatsink size)?  I'm sure a lot could be learned by getting a flock of pi's setup and working as intended before finalizing any board design, which is my only point.
Offline Fungus
« Reply #90 on: October 16, 2016, 07:32:49 pm »
I doubt it will be very much if they sell them without heatsinks. If it was a big problem they'd have them welded onto the chips.
But that's just speculation. We need engineering data and I'm sure there's a video on this topic in the pipeline.  :popcorn:
Offline nctnico
« Reply #91 on: October 16, 2016, 09:36:09 pm »
Don't be so sure about it. I'm using a 'SoC on a module' for a commercial project and it needs a huge friggin heatsink which is sold seperately to keep the module within specs and it is mounted in a casing with plenty of natural convection.
« Last Edit: October 16, 2016, 10:16:36 pm by nctnico »
Offline CM800
« Reply #92 on: October 16, 2016, 10:23:28 pm »
Exactly right. These modules are designed to be as flexible as possible for as many customers as possible. Some customers can't use fans due to noise requirements, others can't have a heatsink, it takes up too much space or there won't be airflow inside the case, it'll have to be thermally coupled to said case. Others may be running in a very hot environment where the only way they could possibly cool it (along with other components) would be water cooling (say the unit is out in the desert in the sun, some electronics will be cooled via a large heat exchange unit.
Offline jolshefsky
    • Jason DoesItAll
« Reply #93 on: October 17, 2016, 12:34:41 am »
I think this has the same-ish problem as the flat-packed Pies: lots of wasted board space under them.
My first thought (echoed early on by several others) was to make a simple board that converted the dual-row pin-header to a card-edge connector. These adapter boards would be super simple and small: barely a dual-row header and one side with card-edge fingers. I very much like the idea of going with a very common connector (e.g. PCI, even though it's more pins than necessary.) For that matter, it wouldn't be much more effort to design the board with a second set of holes for another female header to handle the other rotation of the board (e.g. Raspberry vs. Orange).
The question is, should you make the adapter board include things like LEDs, pass-through pins, a local LDO regulator, or the SPI-Ethernet adapter.
May your deeds return to you tenfold.
Offline mariush
« Reply #94 on: October 17, 2016, 12:53:20 am »
Another idea just came to me  :D
use four bars to space the pi's evenly.  Fish tank , mineral oil , put the pi's all in the oil hanging down by the network and power and io cables all  going up onto a top board . add a couple of fans to circulate the mineral oil around. done.
Since they run on low voltages and relatively low currents, you probably don't have to insulate each cpu (with regular computers some hard to pour insulating material around the socket because they got shots or arcs between contacts near the cpu sockets.
Offline Frant
« Reply #95 on: October 17, 2016, 01:12:47 am »
Although a software driver for the SPI/Ethernet chip exists (Dave mentioned it in the video), I would rather try to stick with Ethernet. The idea to use right-angle pcb-mount Ethernet plugs was a good one and it remains unclear to me why it was dismissed.
Offline TheRevva
« Reply #96 on: October 17, 2016, 01:14:59 am »
All that work to achieve the ethernet I/O?
I'd be SORELY tempted to outlay a HUGE extra US$2.01 per board and use the Orange Pi Lite which has onboard WiFi!
Whether I would actually USE the supplied WiFi antennae or not is another question.
I'm willing to bet they could all 'cross-communicate' without ANY antenna being connected if they were all co-resident in a single enclosure with just a 50ohm resistor soldered across the u.fl connector?
The FIRST 'PI' within any such 'array' / 'cluster' could then serve as a wired-to-wireless protocol converter as well as a basic local WiFi 'Access Point'
It would probably work out cheaper overall and significantly reduce the internal wiring complexity.
Offline MisterDiodes
« Reply #97 on: October 17, 2016, 01:54:14 am »
A couple "Head's Up" suggestions for Dave:
1.  Check out Samtec for a right angle female header socket connector - part of their SSQ line I believe.  The female header clips on to your Pi header, then the square leads come out and turn right angle, and you can get these in a variety of lengths - say .3" or .5" long.  No need to remove existing 40 pin header on the Pi, and you can use any variety of vertical-entry sockets on the backplane - and that makes it a breeze to layout without slots in the way.  For a couple bucks you turn your Pi into a module than can stand on edge and plug into your backplane, no slots required.
2.  Watch out connecting the Ethernet PHY ports together without magnetics!  Ask me how I know.  It works sometimes, but not always - just depends on what chips you'll use.  What happens is the current drivers get confused if they are trying to negotiate auto-MDI crossover when first making the connection - and if you're using an un-managed port switch chip that can be an issue.  Those PHY port drivers are designed from ground zero to see the mags attached.  You'll also see weird noise pickup effects on a crowded board if you're not careful.
I suggest you lay in the pads for the 1:1 magnetics ALONG WITH your resistor pads on your proto board, and then you can easily experiment to see what does and doesn't work.  You definitely want to have your magnetics in place for the first few tests, and then you can always remove them to start playing with direct-connect resistors.
Remember those current driver resistors will have to be changed for the direct-connect situation.
« Last Edit: October 17, 2016, 10:28:44 am by MisterDiodes »
Offline technix
  • Country: cn
    • My Untitled Blog
Re: EEVblog #934 - Raspberry Pi Supercomputer Cluster PART 1
« Reply #98 on: October 17, 2016, 02:21:17 am »
2.  Watch out connecting the Ethernet PHY ports together without magnetics!  Ask me how I know.  It works sometimes, but not always - just depends on what chips you'll use.  What happens is the current drivers get confused if they are trying to negotiate auto-MIDI crossover when first making the connection - and if you're using an un-managed port switch chip that can be an issue.  Those PHY port drivers are designed from ground zero to see the mags attached.  You'll also see weird noise pickup effects on a crowded board if you're not careful.
I think that if you can bypass PHY entirely you may be able to connect the RGMII interfaces together directly.
« Reply #99 on: October 17, 2016, 03:24:23 am »
One of the reasons I liked the KSZ8895MQX chip is that you could configure the important registers with pull-ups. The MDI/MDIX Negotiation just happens to be switchable by pulling up pin 1. Winning! It's also programmable, but for the project Dave had in mind, that wouldn't be worth the effort. Not bad for 8 bucks.
Offline kyndal
« Reply #100 on: October 17, 2016, 03:30:44 am »
just use a 3 pin high connector. block /disregard  bottum row of pins
Kyndal
Offline Fungus
« Reply #101 on: October 17, 2016, 05:33:38 am »
I re-checked the previous video where Dave ran one of these at 100%. It got up to 90 degrees but it didn't die.
I guess the size of the heatsink will come down to airflow in the case.
Offline CM800
« Reply #102 on: October 17, 2016, 06:53:09 am »
I'd beg to differ there, Wasted board space is not the biggest issue, cores per cm^3 is something more to think about. PCBs are cheap! Each of these boards could even possibly be done on a two layer, having four, or even eight of the Pis on them (1 on each side, using SMT header connectors)
The heatsink would be in the middle, then each board can be placed on a back-plane directly next to each-other, it would be the most compact solution we've discussed here no doubt.
Few things to think about there: You're creating lots of traffic in the wifi spectrum, this thing isn't infinite, believe it or not, if you set a lot of networked devices over wifi sending data constantly, you will find all the wireless networks slow down in the vicinity. (You're broadcasting on all the available channels in the local air) I might be incorrect here but from what I've heard it's true and a real effect.
The other thing is that holds no interest to most of us I'd imagine, if your going to do it with wi-fi, you might as well do it wired. I feel the main goal (or at least what I, and others are  getting out of this project is learning electrical design knowledge, not how to turn on a load of pies then configure them to communicate with each-other through wifi. Most, if not all of us here could do that in a few hours after they first get their hands on them and read up on google. There is much more to learn developing a compact baseboard.
« Last Edit: October 17, 2016, 07:02:27 am by CM800 »
Offline NANDBlog
« Reply #103 on: October 17, 2016, 09:50:20 am »
What I would do:
Make a Eurocard PCB with the DIN41612 connector at the end (lets call it adapter board). Design the board, so it can take 2 Orange PIs, 5ish raspberry Pi zeros, 4 CHIP. or your choice of computing. Orange PI is mounted upside down on the adapter board, RPi zero has the connector soldered on the bottom, and USB pins tapped with a pogo pin. Route 24V, maybe 12V to the adapter board, have an onboard POL converter. Design a backplane, it routes power + ethernet to each board. Each adapter board has an ethernet switch, in case of necessary. Maybe it even has hot swap control. The backplane has 21 connectors (AFAIK, that is standard). I reckon, you can fit 42 RPis, 105 RPi zeros into a 3U rack. All mechanical parts are off the shelf. Cooling vertically. Hot plugging the cards, if you feel like. Mix different cards, if you feel like.
« Reply #104 on: October 17, 2016, 10:27:41 am »
RGMII is generally not thought of being perfectly symmetrical in both the hardware and protocol sense - although I know some Micrel (et al) PHY chips can be connected back to back like that if you're building a repeater or media converter.  Usually that isn't the case for a generic connection - Normally RGMII is meant for a MAC interfacing to PHY... Not MAC to MAC.
Offline Towger
  • Country: ie
« Reply #105 on: October 17, 2016, 05:25:58 pm »
I also suggested wifi, but using the small (ebay type) dongle which fit into a usb socket.  Bandwidth should not be a problem, except if all machines first start Bonic at the same time.  After Bonic downloads a block of data it (depending on cpu power) can take days before it finishes and needs more.
In saying that I like the mineral oil cooling idea, totally impractical, but leads to a more interesting video (more views).  I don't think 2.4ghz will have much of a range in oil [emoji3]
« Last Edit: October 17, 2016, 05:33:27 pm by Towger »
Offline nctnico
« Reply #106 on: October 17, 2016, 05:35:09 pm »
If you want to run tasks in parallel they are likely to need data pumped in&out so network traffic could be massive. I don't know the Allwinner's performance when it comes to compressing video but if it is any good Dave could use the cluster to compress his Youtube videos.
edit: typo
« Last Edit: October 17, 2016, 06:49:35 pm by nctnico »
Offline KenGaler
    • Innovative Electronics LLC
« Reply #107 on: October 17, 2016, 05:55:37 pm »
I agree with the suggestion of a 90Deg adapter board and get rid the slots.  They can be designed on the same layout as the mother board and v-scored.  This way they are essentially free.
Ken
Offline onarch
  • Country: no
« Reply #108 on: October 17, 2016, 06:50:02 pm »
How about using the microUSB OTG to connect all the boards together?
You can get microUSB plug connector for PCB mount. Like ZX80-B-5SA from Hirose, see [3]. (Didn't know these existed before I checked)
Use one board as the master (USB host) and connect the other ones (USB devices) to it using a USB hub chip[2]. USB OTG can act as either a device or host depening the state of the ID pin. In Linux you can then USB Ethernet gadget on the devices to create a Ethernet connection to the master (host).  See: http://linux-sunxi.org/USB_Gadget
The master can then setup a network bridge between its external Ethernet interface and the USB Ethernet connections from the devices, and will thus act like a switch.
8x NanoPi           $7.99      $63.92 [1]
8x ZX80-B-5SA       $1.60      $14.40 [2]
1x TUSB2077         $4.79      $ 4.79 [3]
+ PSU and board
Advantages:
  • Only 4 wires needed for both signal and power for each board
  • USB is easy to route on a PCB
  • USB hubs use less power than Ethernet switches
  • Standard microUSB interconnect allows you to basically use any board you want
  • USB hubs can be cascaded (like Ethernet)
Disadvantages:
  • Requires a master board
  • Boards will most likely need more mechanical support than just the microUSB connector
  • Requires somewhat advanced Linux configuration (gadget+bridge setup)
[1] http://www.friendlyarm.com/index.php?route=product/product&product_id=132
[2] http://www.digikey.com/product-detail/en/texas-instruments/TUSB2077APTR/296-37871-1-ND/4878718
[1] http://www.digikey.com/product-detail/en/hirose-electric-co-ltd/ZX80-B-5SA/H11612-ND/1963857
Offline nctnico
« Reply #109 on: October 17, 2016, 06:55:40 pm »
Connecting RGMII back to back should be possible either with an external clock or one interface as master but the point is rather moot. Routing ethernet is going to be much easier. Because of the short distance on a board you don't need matched impedance traces so as long as they are routed as pairs away from noise everything is fine (100Mbit ethernet has frequency components up 100MHz so up to 40cm long traces don't behave as transmission lines yet).
Offline claus
« Reply #110 on: October 17, 2016, 07:21:36 pm »
I think I understood that performance is not so important here, but a "supercomputer" (even if it's a pocket size supercomputer is (wikipedia): A supercomputer is a computer with a high-level computational capacity compared to a general-purpose computer. Performance of a supercomputer is measured in floating-point operations per second (FLOPS). Have in mind that a "general purpose computer" in this context is a PI.
So essentially you want to build something faster combining various cpus. The problem here is that if communications are slow, the resulting computer might be slower, and this would just be a waste of energy. Those Pi's are not so terribly bad at crunching numbers, especially the 4-cores cpus, see http://www.roylongbottom.org.uk/Raspberry%20Pi%20Multithreading%20Benchmarks.htm, they get around 2 GFlops for the multithreaded version.
So if you want the final thing to be faster (on an application that is not embarrassingly parallel) than a single PI you need good (fast) communication, otherwise a multithreaded program might run slower on 4 Pi's than on 2. The orange pi has a gigabit Ethernet port which should give a reasonable connection for parallel computation, I would use it with a gigabit switch for a model "supercomputer". If all applications will be embarrassingly parallel the SPI/Ethernet approach might make sense, but only as an application specific "supercomputer".
If on the other hand the design of a sexy SPI/Ethernet interface without cables for various Pi's is the main pointl, the Pi-zero would be the better candidate, imho, as each cpu is much slower and so are communication requirements. You might get some speedup adding Pi-zeros and thus at least get a "zero-Supercomputer" ;)
Offline free_electron
    • SiliconValleyGarage
« Reply #111 on: October 17, 2016, 07:51:55 pm »
i have one question : what are you going to run on it ? not operating system , what APPLICATION are you going to run on it ?
What ? why ? and is it made for a cluster setup ?
Offline rob77
  • Country: sk
« Reply #112 on: October 17, 2016, 09:05:18 pm »
i assume it will be boinc client on every board. it's not a computing cluster.... it's a cluster of independent single board computers ;)
Offline Poolkeeper
« Reply #113 on: October 17, 2016, 09:10:03 pm »
Interesting project to learn from.
Found this about running Ethernet connection without magnetics:
Offline rob77
  • Country: sk
« Reply #114 on: October 18, 2016, 12:24:17 am »
of course it's not a real supercomputer... a crucial component of a real supercomputer is RDMA (remote DMA) as far as i know only 2 technologies provide native RDMA , it's Infiniband and 10Gb Ethernet , and neither of those is present. (of course you could write a software RDMA implementation on top of any connection.. but that's  not the real thing ;) )
Offline Brumby
« Reply #115 on: October 18, 2016, 01:10:43 am »
It may not be a 'supercomputer' - but I think it's a super computer idea.
Engineering solutions that deliver is what enthuses me.  Who cares if performance doesn't stack up against an Intel flagship CPU - it was never meant to.  Getting the thing to work as intended is the magic.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #116 on: October 19, 2016, 01:40:21 am »
RGMII carries a 1Gbps link at 125MHz DDR, so not that much more difficult to route than 100BASE-TX. And those are single-ended signals so only length matching is required for longer runs.
Twisted pair PHY have much higher latency than other PHY due to its line encoding. This latency is not significant to 100Mbit Ethernet but when you are coming to loading down a 1Gbps connection it can become a significant portion of the system latency. There are existing backplane Ethernet standards, but those are either based on fiber PHY or use GMII/XAUI (GMII is functionally identical to RGMII but requires almost 2x the pins, XAUI is a functional sucessor to [R]GMII but carries a 10/40/100Gbps link) direct attach.
Offline haybailes
« Reply #117 on: October 20, 2016, 10:00:21 pm »
i have just finished watching the video and dont have time to read all the post
i dont know if anyone has said anything along these lines but sorry if someone has
instead of holes in the PCB and having the 90° header pins
you could you just normal straight female header pins going to a PCB with 90° header pins
then the raspberry pi attaches to that
pros: the PCB can be changed to handle other mini computer like C.H.I.P or orange pi, can be placed from the top down, more room on mother board,...
cons: more PCBs more and more components cost, may sway a lot in the slots,...
Offline xDR1TeK
  • Country: lb
« Reply #118 on: October 23, 2016, 12:35:29 am »
How is the Ethernet to SPI being done?
Emulation of TCP/IP to SPI?
Does the Linux kernel have a module to skip over the OSI physical layer which is connected to ethernet port?
Would the ARM controller be built with the whole digital TCP/IP circuitry or just the analog circuitry part to operate the port channel on the output?
This has been something eating at me for a long time, and finding books that cover this much is impossible.
Offline xDR1TeK
  • Country: lb
« Reply #119 on: October 23, 2016, 12:47:15 am »
Ok figured out this much, Application, Transport, Network layers are all in software. Then the Link layer is going to be SPI interface. The active components with the wires are the physical layer.
So the encapsulation is being routed in software to port over the SPI.
then the SPI to ethernet would be just a dummy converter.
Very interesting.
« Last Edit: October 23, 2016, 12:54:30 am by xDR1TeK »
Offline iXod
« Reply #120 on: October 23, 2016, 05:50:21 am »
Dave mentioned a price of $10 for pi. Where are these to be found at this price?
Offline Fungus
« Reply #121 on: October 23, 2016, 07:44:31 am »
Those Ethernet ships do everything - complete IP stack on a chip. You just give them a MAC address and tell them to start.
You communicate with them over SPI just to check for incoming connections and receive/send the data.
« Last Edit: October 23, 2016, 07:29:58 pm by Fungus »
The following users thanked this post: xDR1TeK
Offline rob77
  • Country: sk
« Reply #122 on: October 23, 2016, 07:56:18 am »
Those Ethernet ships do everything - complete IP stack on a chip. You give them a MAC address
You just communicate with them over SPI to check for incoming connections and grab the data as it arrives.
actually there are 2 different kind of ethernet chips for micros... ethernet only and ethernet + IP stack
the mentioned ENC28J60 is a MAC + PHY with SPI interface... so it's just a plain ethernet "network card" connected via SPI and it does have a driver in the linux kernel.
the other kind of chips are with IP stack implemented but those are mainly targeted for small microcontrollers - so you don't have to implement the IP stack on your small micro. an example of such a chip is Wiznet W5100.
Offline Fungus
« Reply #123 on: October 23, 2016, 07:31:57 pm »
OK, I got them mixed up.
I've used the Wiznet W5100 but not the ENC28J60. I thought they were similar.
Offline eneuro
« Reply #124 on: October 25, 2016, 10:17:10 pm »
Is it gigabit ethernet? If not, than forget about any supercomputing and we should... SMELL BULLSHIT  instead of supercomputing >:D
[youtube][/youtube]
Update: Yep it is  :bullshit:  Orange Pi One – 10/100M Ethernet   :popcorn:
« Last Edit: October 25, 2016, 10:25:46 pm by eneuro »
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
Offline rob77
  • Country: sk
« Reply #125 on: October 25, 2016, 10:41:11 pm »
[youtube][/youtube]
please read the whole thread...
and you're talking even bigger bullshit because gigabit ethernet doesn't provide remote DMA, therefore it's not suitable for computing node interconnect in a supercomputer.
Offline NANDBlog
« Reply #126 on: October 26, 2016, 03:17:35 pm »
Very interesting.
It actually does not matter. Newer linux kernel supports it out of the box, so you just need to recompile the kernel, and it will appear as a network card.
Offline rob77
  • Country: sk
« Reply #127 on: October 26, 2016, 09:08:27 pm »
Very interesting.
agree, it doesn't matter... and in fact the SPI is replacing the PCI or USB bus... so it has nothing to do with link layer.. link layer will be still ethernet ;)
Offline SeoulBigChris
  • Country: kr
  • "Unencumbered by the thought process"
« Reply #128 on: February 02, 2017, 11:56:35 am »
Too bad this Ethernet controller can't implement 10BASE2 (or at least I don't think it can, after only 10 minutes of study).
