Author Topic: EEVblog #966 - CPM700 Counter Surveillance Monitor Repair  (Read 11517 times)
Offline EEVblog
« on: January 25, 2017, 03:03:42 am »
Repair of the CPM700 Counter Surveillance Monitor (Bug Detector)
Offline G7PSK
  • It is hot until proved not.
Re: EEVblog #966 - CPM700 Counter Surveillance Monitor Repair
« Reply #1 on: January 25, 2017, 09:42:37 am »
Is that the new EEVblog meter?
Offline Groucho2005
« Reply #2 on: January 25, 2017, 10:33:42 am »
121GW?   ???
The power required to run a flux capacitor is 1.21 GW.
Offline Brumby
« Reply #3 on: January 25, 2017, 11:52:05 am »
If you can't see the decimal point, you're not worthy.
(If Dave develops another product, I've suggested the model number: 1210MW)  While technically more accurate, it doesn't have the same ring to it.
« Last Edit: January 25, 2017, 11:54:41 am by Brumby »
Offline daveshah
  • Country: at
    • Projects
« Reply #4 on: January 25, 2017, 01:12:01 pm »
How about electronics-style notation and go for 1GW21?
Offline aromring
« Reply #5 on: January 25, 2017, 04:33:27 pm »
At 33 minutes, that cap in the upper left corner looks suspicious to me...
Great minds discuss ideas.
Average minds discuss events.
Small minds discuss people.
The following users thanked this post: error079
Offline slurry
« Reply #6 on: January 25, 2017, 04:37:44 pm »
Oh, i remeber those  ^-^ but i mostly used the clumsy briefcase oscor 5000, "omni-spectral correlator"
- toys, by todays standard  ;)
Offline error079
« Reply #7 on: January 25, 2017, 05:03:11 pm »
And at about 23:59 the spill off electrolyte can be seen on the PCB.
Offline Groucho2005
« Reply #8 on: January 25, 2017, 05:25:54 pm »
Great Scott!  :--
Offline Erikkssen
« Reply #9 on: January 25, 2017, 07:03:10 pm »
CPM700 is a discontinued product,
maybe the factory can publish the schematics?    :P
« Reply #10 on: January 25, 2017, 08:43:50 pm »
2V7 likely is a analogue ground. 2V7 is about right for a LM324 with split rails. Not 3V because of the positive common mode limit.
So a 22 is a LM324, and a 27 is a LM380.
Offline Ingineer
« Reply #11 on: January 25, 2017, 11:15:18 pm »
Dave, did you try adjusting Vcc and see if that allowed the probe detect to start working again?
Offline kcozens
« Reply #12 on: January 26, 2017, 12:31:36 am »
Hm... another successful repair. IIRC, that is two in a row. The EEVblog repair curse has gone away (for good?). We saw just the bottom portion of the new meter in a previous video. Has Dave let the cat out of the bag by allowing us to see an EEVblog branded meter that is not the Brymen one we all know about? This new meter says 121GW on the front. In electronics notation it would be 1G21W as G is the power of 10 and W is units.
Offline thm_w
« Reply #13 on: January 26, 2017, 12:42:02 am »
He mentioned on youtube that he did, and that voltage was scaled with vcc so didn't help.
https://www.eevblog.com/forum/eda/daves-eevblog-multimeter/
Offline joeqsmith
« Reply #14 on: January 26, 2017, 01:08:26 am »
Meter is looking sharp!  Hope the testing is going well and looking forward to seeing it first hand.
How electrically robust is your meter?? https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Offline Fungus
« Reply #15 on: January 26, 2017, 06:55:29 am »
Do they use resistors as "voltage regulators" to avoid the RF from real ones?
PS (at 11:10): The "ox" input ?  :-DD
« Last Edit: January 26, 2017, 06:59:51 am by Fungus »
Offline EEVblog
« Reply #16 on: January 26, 2017, 08:27:03 am »
I heard from someone who worked there, and yes it was discontinued the other year.
It's the original model that the company founder designed.
Offline EEVblog
« Reply #17 on: January 26, 2017, 08:29:24 am »
Actually, a few major issues still...
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #18 on: January 26, 2017, 10:33:13 am »
EMC issue in amp-mode?  >:D
Offline Brumby
« Reply #19 on: January 26, 2017, 10:37:47 am »
Where's an exorcist when you need one?!!
Offline Kolby_G
« Reply #20 on: January 26, 2017, 07:38:51 pm »
If you type 121GW into the Google Play store, you get what looks like a companion app for the new meter. https://play.google.com/store/apps/details?id=kr.co.finest.eevblog&hl=en
I remember in a previous video Dave mentioned that he didn't want to point out who the manufacture was, if that's the case it might be a good idea to take this app down from the public store, you can tell who the manufacture is quite easily...
Offline twice11
« Reply #21 on: January 26, 2017, 11:25:14 pm »
If you type 121GW into the Google Play store, you get what looks like a companion app for the new meter. Link removed I remember in a previous video Dave mentioned that he didn't want to point out who the manufacture was, if that's the case it might be a good idea to take this app down from the public store, you can tell who the manufacture is quite easily...
You don't even need to click that link. It cites the app package ID which has been created using the typical Java package naming convention, so it already gives everything away...
Offline joeqsmith
« Reply #22 on: January 26, 2017, 11:50:00 pm »
... Dave mentioned that he didn't want to point out who the manufacture was,...
Guessing that it is far enough along now.
Offline Stormchaser
« Reply #23 on: January 28, 2017, 04:13:59 am »
That is one sexy meter. Did I miss an announcement? All the recent videos have just said "mystery meter" and Dave's been reluctant to show much of it on screen (aside from the 3d printed model). Either way, that looks firmly in the "shut up and take my money" category; nicely done Dave! Can't wait for it to go on sale!
Offline casuallydressedguy
« Reply #24 on: February 03, 2017, 03:37:33 am »
I don't know whether these will help....   :D
It appears that my Rev E CPM-700 hasn't had all the markings removed, except for the package mounted to a half assed heatsink (folded piece of aluminium) next to the big black piezo buzzer which is marked '70'.
