The last couple replies I tried worked fine here but I am also seeing intermittent gateway errors:
https://www.eevblog.com/forum/blog/eevblog-632-solar-roadways-are-bullshit!/msg1155023/#msg1155023
https://www.eevblog.com/forum/blog/eevblog-632-solar-roadways-are-bullshit!/msg1155093/#msg1155093
When it messes up, I can just reload the gateway error page and eventually it will work. Sometimes one reload, sometimes dozens of times, seconds or moments later, doesn't seem to matter or have any pattern that I can discern. The strange thing is that it is
not the whole forum like when the entire site goes down. Some pages will work (perhaps they are in a cache at Dave's end or on cloudflare or somthing?) but others or things like trying to reply will just immediately pop up the 502 or will take a long time (like 30 seconds or so with a "waiting for eevblog.com...") then finally pop up.
5 minutes later it might be fine...
5 minutes after that it might go berzerk again or be totally fine...
Hit or miss with no apparent pattern...
This machine is 10 hops from Dave's server, connected to the net upstream via a HE (Hurricane Electric) fibre...
Total of 6 (NAT + internal + gateway + link + gateway) hops on 10.x.x.x then:
v219.core1.yyc1.he.net (216.218.224.113)
100ge10-2.core1.yvr1.he.net (184.105.64.113)
vanix.cloudflare.com (206.41.104.52)
104.31.75.133
...stable at about 20ms round trip, if that helps any...
