Here is the pboot output when I bypass uboot
********* Image 1 *******************O
BL_IMAGE_TYPE_BIN
X
XXXXOOORewrite recommended, internal ECC corrected data at 0xc57
OXXOORewrite recommended, internal ECC corrected data at 0xc88
ORewrite recommended, internal ECC corrected data at 0xc94
OOORewrite recommended, internal ECC corrected data at 0xcc0
OOXOXOOORewrite recommended, internal ECC corrected data at 0xd1c
OOORewrite recommended, internal ECC corrected data at 0xd59
OOXOOOXORewrite recommended, internal ECC corrected data at 0xdb4
ORewrite recommended, internal ECC corrected data at 0xdbb
OOXXXRewrite recommended, internal ECC corrected data at 0xdea
OOOOOOOORewrite recommended, internal ECC corrected data at 0xe7a
OXORewrite recommended, internal ECC corrected data at 0xea3
OOOXOXOXRewrite recommended, internal ECC corrected data at 0xf03
OXXOXOXOXOXXXXORewrite recommended, internal ECC corrected data at 0xf67
OXXXORewrite recommended, internal ECC corrected data at 0xf8c
Rewrite recommended, internal ECC corrected data at 0xf94
ORewrite recommended, internal ECC corrected data at 0xfab
OORewrite recommended, internal ECC corrected data at 0xfc8
OOXXRewrite recommended, internal ECC corrected data at 0xff6
OXXRewrite recommended, internal ECC corrected data at 0x1003
OXXXXXXOORewrite recommended, internal ECC corrected data at 0x1032
OXXXOOXXRewrite recommended, internal ECC corrected data at 0x1071
OOXXXOXXRewrite recommended, internal ECC corrected data at 0x109f
OORewrite recommended, internal ECC corrected data at 0x10c3
OOXOOXXOOXOXRewrite recommended, internal ECC corrected data at 0x113c
ORewrite recommended, internal ECC corrected data at 0x1152
Rewrite recommended, internal ECC corrected data at 0x1156
OOOXRewrite recommended, internal ECC corrected data at 0x1193
OXOOOOOXRewrite recommended, internal ECC corrected data at 0x1211
Rewrite recommended, internal ECC corrected data at 0x1212
OOOXOOXOXXRewrite recommended, internal ECC corrected data at 0x1275
OXOXXXXXXOXXXXOOOXOOOXOXOOOOXOORewrite recommended, internal ECC corrected data at 0x137a
OOXOXOXOOOOOOX
Rewrite recommended, internal ECC corrected data at 0x1421
Rewrite recommended, internal ECC corrected data at 0x1424
OORewrite recommended, internal ECC corrected data at 0x1453
OXODeCompressFlash: CeCompressDecode() failed
CeDecompressFlashBlock failed
****** Data record 82 corrupted, ABORT!!! ******
Completed file(s):
[0]: Address=0x80361000 Length=0x1A84978 Name="" Target=RAM
Image at 0xd0600000 is not valid
********* Image 2 *******************
BL_IMAGE_TYPE_UNKNOWN
Image at 0xd1e00000 is not valid
P500 Boot Loader Configuration :
Mac address .......... (00:03:D3:04:10:00)
Ip address ........... (192.168.1.100)
Subnet Mask address .. (255.255.255.0)
DHCP ................. (Enabled)
Boot delay (seconds).. (3)
Load image 1 at startup
Image addresses. (0xdxxxxxxx for NAND, 0x8xxxxxxx for RAM)
1 (0xd0600000)
2 (0xd1e00000)
l) Load memory resident image Load image 1 now
1) Load memory resident image 1 now
2) Load memory resident image 2 now
3) Load memory resident image 3 now
d) Download from platform builder now
u) Start u-boot by resetting
v) Verify Images
Something is happening at 0x600000, do I have to re-upload the nk.bn0 file and compare? Damn, uart is so slow
