Author Topic: EEVblog #997 - How To Solder Surface Mount Components  (Read 21067 times)
Offline EEVblogTopic starter
« on: June 02, 2017, 01:54:30 am »
Soldering the Nixie Tube display PCB. How to do drag and dab soldering to make surface mount parts soldering easy.
Also a look at the Elecrow blank prototype PCB quality.
Jump to 3:36 for the soldering tutorial
Part 6 of the Nixie Tube project
The following users thanked this post: SeanB, jonovid
Re: EEVblog #997 - How To Solder Surface Mount Components
« Reply #1 on: June 02, 2017, 02:18:01 am »
You didn't make mention of populating with passives first to help minimise ESD risk to active devices.
Obviously there weren't many on this layout but wouldn't you do that first ?
Offline piranha32
    • random ramblings of an engineer
« Reply #2 on: June 02, 2017, 02:23:43 am »
Drag soldering works really great, but you need to have enough solder on the tip. That's why big tips work so well. Many manufacturers also offer "mini-wave" tips with decent-sized reservoir for molten solder.
Here's how Pace's mini-wave tip works. Note how big the tip is compared to the chip
However, my favorite home-shop method of soldering SMD components is hot-air reflow. I just tin the pads, flux the board, place components, and reflow. No need to mess with stencils, works great each time, is very quick, and with a little bit of practice gives really professionally looking board.
The following users thanked this post: jonovid
Offline mdszy
  • somehow has an ee degree
    • szy.io
« Reply #3 on: June 02, 2017, 02:28:16 am »
Nice, loved the video!
I'm going to be working on a modular nixie clock project. A four-digit nixie display that will allow for swapping out a "driver" board so you can use it to display any information you'd like, or use alternatively clock drivers. For instance, I'm going to try making one with discrete logic, then an ATTiny based clock, maybe a GPS-time based one, etc. etc.
Those pins look awesome, I was under the impression that it's either sockets or nothing, but now I really want to pick up a lot of those nixie pins! Thanks for the great vid!
somehow allowed to be a Pixie Wrangler in Training
eBay Store | My site | Hackaday.io Projects | my mastodon.technology profile
Offline abdullahseba
« Reply #4 on: June 02, 2017, 03:41:48 am »
Just been watching this and wondered ho you keep your tip shiny? Mine always goes black and is useless there is a tiny bi of solder on the to transfer the heat.
« Last Edit: June 02, 2017, 03:45:10 am by abdullahseba »
This is my right hand this is my wrong hand
« Reply #5 on: June 02, 2017, 03:53:23 am »
Brass or stainless wool takes the grud off the tip and at the same time wipes solder all over it. Hakko do a brass sponge but you can also use a soft domestic stainless scourer.
There are wool holders but a smallish ceramic cup works just as well.
Stab, stab and hey presto clean tip.  :)
The following users thanked this post: abdullahseba
Offline HackedFridgeMagnet
« Reply #6 on: June 02, 2017, 04:33:14 am »
Yes clean tip before/during soldering.
But for me the important bit is, when you are finished don't clean it, instead put a big blob of solder on the tip and then turn it off.
The following users thanked this post: abdullahseba, Electro Detective
« Reply #7 on: June 02, 2017, 05:15:19 am »
I have a brass one on the hakko FX-888D. Do you have to do it vigorously?
« Reply #8 on: June 02, 2017, 05:40:49 am »
No.
Just a stab or two of a hot iron into the wool is enough. Try it a few times and you will find what works best for you.
Offline P90
« Reply #9 on: June 02, 2017, 06:06:30 am »
they make a "soft" stainless steel scrubber?
Offline plazma
    • Homepage
« Reply #10 on: June 02, 2017, 06:21:32 am »
Don't use stainless wool. It ruins the tip.
Offline Fungus
« Reply #11 on: June 02, 2017, 07:19:45 am »
You're supposed to clean it before use and every 20 minutes or so as you work. Use the sponge, make it damp with water so it doesn't burn (ie. not a puddle of water).
Once it's all blackened it's quite hard to fix. Better to get a new tip and look after it this time.
Offline P90
« Reply #12 on: June 02, 2017, 07:25:33 am »
That's what she said...
:-DD
« Reply #13 on: June 02, 2017, 07:32:51 am »
:-DD
Err? She who? where? what?
Offline P90
« Reply #14 on: June 02, 2017, 07:37:26 am »
:-DD
marhaba
Not a fan of "The Office"  ?  LOL
« Reply #15 on: June 02, 2017, 07:39:31 am »
Ohhh  :=\  8)
Offline EPTech
    • EP Technical Services
« Reply #16 on: June 02, 2017, 07:48:59 am »
Hi there,
The dab technique is also great for removing a short from between legs.It is an alternative method to using solder wick that is less stressful to the legs and pads.
1. Apply some gel flux between the legs.
2. Put some solder on the tip and clean it off so you end up with a shiny but dry tip.
3. heat up both pads at the same time at a small angle with a very small amount of pressure on the end of the pins, just touching them actually
4. the excess amount of solder should be pulled towards the solder iron. Often it will help to move the tip back and forth to pull the solder away and to prevent overheating, especially when using a fixed temperature tip like I do.
5. If I cannot get the short out, I use solder wick. But when using solder wick it helps to wet the tip a little bit to get the solder wick started or to cut the solder wick so that a little solder remains.
Gel flux: Arcoss 23-29-10AX
Solder station: OKI Metcal MFR 2000 series
Solder wick: Chemtronics Rosin SD
Kind greetings,
Pascal.
Offline EPTech
« Reply #17 on: June 02, 2017, 08:15:28 am »
Hi there,
Here are some tips to keep your tip in good condition:
1. When using a brand new tip. Wet it with solder as soon as it gets hot. In fact push the solder against it while it is heating.
2. Dampen the sponge with demineralized water, as mineral depositions will turn your tip solderphobic and they are hard to clean off.
3. The sponge must not be wet. If you hear a hiss, the sponge is to wet. The temperature shock will crack up the protective coating of your tip.
4. DO NOT use abrasives to clean the tip. Always use the least abrasive method first. Use the sponge to clean the tip in between one or several solder joints. Use the brass only if the damp sponge does not work.
5. Always wet the tip with solder before putting the iron in the stand for a longer time, like in between measurements or coffee breaks or after you finished.
In case of a black tip you can use a "tip reviver" as a last resort but it is a very aggressive flux. Alternatively you can use a box knife and scrape of the black stuff. Hold the blade perpendicular to the tip in doing so. Use very little down force and move back and forth until the shiny surface reappears. Do not try to do the entire tip at once. When you get a shiny bit, apply solder to it and clean of. This method beats the sand paper method because you have more control and visual feedback of what you are doing. The sand paper grains will make deep grooves in the tip in an uncontrolled manner. I know it sounds weird but the knife beats the sand paper if there is no other way. I would say steel wool is somewhere in between.
Hope this helps. Happy soldering.
Kind greetings,
Pascal.
The following users thanked this post: abdullahseba, trebejo
« Reply #18 on: June 02, 2017, 08:44:46 am »
Yep but if you prefer brass it doesn't last as long as SS.
Hasn't done for any of the few I use.
Nah, use some form of metal wool.
Why would Hakko make brass wool holders and supply brass sponge replacements ?
Maybe they know something you don't.
Our time at the bench is too valuable to waste pissing around with wetting sponges and fiddling to get tips clean and properly tinned.
Sure if you are soldering all day and everyday , hopefully you'd have learnt how to maintain a tip. For those of us that don't have a iron in our hands all day and just want to get on with soldering every now and then metal wools are a very viable option.
Never a blackened tip while using wool and the tip remains completely and perfectly tinned.
Offline NivagSwerdna
« Reply #19 on: June 02, 2017, 09:35:49 am »
Really nice video.  The Elecrow boards look great.  As I got older I didn't realise how my eyesight had degraded but with sufficient magnification SMD is a joy.
Perhaps there should be an EEVBlog approved Stereo Widefield scope?
I like the use of the https://threeneurons.wordpress.com/nixie-power-supply/hv-supply-kit/ PSU, that's the design I went for my own implementation and works well.  The design of that is almost worthy of a video itself.
Looking forward to seeing the end result.  (Don't forget to add some slot-machine style cycling of digits... otherwise the Nixie police will be out to get you).
Offline timgiles
  • Programmer, DB architect
« Reply #20 on: June 02, 2017, 09:55:49 am »
Great video - been waiting for an update on the Nixie tube project. Hoped it would not turn out to be something started but never finished.
My feeling on SMD techniques are to find the one that works for you. I believe it is dependent on the soldering equipment you have, what type and quality of solder etc.. you can get and how they work together. It's important to encourage new EEs to try the different techniques and understand if they produce a working PCB that lasts, that is the most important outcome.
Is the PI board ordered and progressing?
Oh almost forgot : covfefe!
Offline Halcyon
  • Global Moderator
« Reply #21 on: June 02, 2017, 10:34:01 am »
Dave, are you doing anything different with the encoding/format on this video? It's the only one I can't view using my regular browser (Opera version 36.0.2130.80). Every other video on your channel loads fine.
I get the error "Your browser does not currently recognise any of the video formats available".
It's the first time I've ever seen this error on any Youtube video.
Online Monkeh
« Reply #22 on: June 02, 2017, 02:00:48 pm »
I tend to do ICs first as the passives often limit the room to work.
Static's easily enough controlled.
Offline tchicago
« Reply #23 on: June 02, 2017, 07:38:03 pm »
A fingerprint is imprinted into the solder mask at 3:13, top left.
« Reply #24 on: June 02, 2017, 09:25:27 pm »
I think it's in the centre of the board, positioned where a grubby ozzie pulled it out from the stack of 7.
