Author Topic: EEVblog Negative Feedback Shirt quality  (Read 14075 times)
Offline jerzmacow
« on: February 27, 2014, 08:46:40 pm »
Hey dave!
I was thinking of getting one of the awesome negative feedback shirts.
If you look at the preview on the teespring website though, the stencil looks like it's pretty poorly cut out: http://images.teespring.com/uploads/2014/02/23/08/406080/shirtFrontBig.jpg
Specifically the black bits around the opamp schematic... It looks like it was cut out from a black background without any feathering.
Is this just on the previews, or does it show through on the actual shirt? You can sort of see it on the shirt preview as well
« Last Edit: February 27, 2014, 10:45:45 pm by jerzmacow »
Offline linux-works
    • netstuff
Re: EEVblog Negative Feedback Shirt quality
« Reply #1 on: February 27, 2014, 10:31:47 pm »
that's interesting.  hope the real shirt does not look like that.
its probably worth checking before a bunch of people get them.
Offline electronics man
« Reply #2 on: February 27, 2014, 11:12:03 pm »
already bourght mine
follow me on twitter @get_your_byte
Offline EEVblog
« Reply #3 on: February 27, 2014, 11:43:15 pm »
I knew the text looked like that, but I didn't notice the black bits around the circuit. No idea how it will come out on the shirt I'm afraid.
Offline linux-works
    • netstuff
« Reply #4 on: February 28, 2014, 12:09:06 am »
any way to ask the shirt company for a 'proof copy', before they run off 100 of these??
Offline EEVblog
« Reply #5 on: February 28, 2014, 12:10:33 am »
Here is the original uploaded file.
I didn't see the black around the circuit because I had a black background set on my image viewer.
Offline linux-works
    • netstuff
« Reply #6 on: February 28, 2014, 12:16:14 am »
if you look at the image 1:1 (pixel-wise) there are lots of issues.
is it too late to update the graphic and 'stop the presses' until a cleaner one is released?
hope that's not being too fussy; but if it was my graphic that 100 people were wearing, I'd be a bit of a perfectionist and would only want vector art or clean raster art for the submission.
Offline EEVblog
« Reply #7 on: February 28, 2014, 12:21:35 am »
Too late for automatic update, yes. But they can probably do it manually if I send them a new graphic. If someone has the skills to clean it up, please do so.
I kinda liked the distressed spotty nature of the text, but I agree that the circuit has to be clean at the very least.
« Last Edit: February 28, 2014, 12:23:28 am by EEVblog »
Offline EEVblog
« Reply #8 on: February 28, 2014, 12:38:58 am »
Here is the original file, plus the transparent version uploaded for the previous campaign.
Offline Ketturi
    • Ketturi Electronics
« Reply #9 on: February 28, 2014, 12:53:54 am »
I tried quickly to clean edges and make fillings more solid. Now edges are not so perfect and bit coarse, but can't do better, whole image would need to be converted to vectors, and that takes some time...
Ketturi electronics: http://ketturi.kapsi.fi
Offline madworm
« Reply #10 on: February 28, 2014, 12:57:24 am »
Vectorized as .svg
« Last Edit: February 28, 2014, 01:02:49 am by madworm »
Offline EEVblog
« Reply #11 on: February 28, 2014, 01:00:31 am »
Vectorized as .svg
Thanks but it needs to be a transparent PNG for upload to Teespring. Supports .EPS too.
« Last Edit: February 28, 2014, 01:02:08 am by EEVblog »
Offline madworm
« Reply #12 on: February 28, 2014, 01:03:58 am »
.eps file
Offline EEVblog
« Reply #13 on: February 28, 2014, 01:05:20 am »
Circuit looks good, but I see nothing on the text Irfanview. It's white  instead of the gray colour?
Offline EEVblog
« Reply #14 on: February 28, 2014, 01:06:43 am »
.eps file
Neither Irfanview or GIMP can read that.
Offline madworm
« Reply #15 on: February 28, 2014, 01:07:50 am »
Did you unzip it?
Works fine here :-)
Offline Ketturi
« Reply #16 on: February 28, 2014, 01:08:17 am »
Oh snap, wrong colors, here the fixed one. Hopefully colors are right now!
Offline liquibyte
« Reply #17 on: February 28, 2014, 01:08:33 am »
Removed artifacts.  Looks like it was originally a gif or antialiasing was on.
Offline linux-works
    • netstuff
« Reply #18 on: February 28, 2014, 01:11:30 am »
I also gave it a shot (used the ancient 'xv' program under linux).  used the color editor and tried to combine the colors and reduce the color count.  that often helps, but in this case, there were still 'dot-lets' left behind and it would need manual cleanup.
sheesh.  just do the thing right for next time ;)  do the schematic in vector and do the lettering in a real font so that its vector, too.
Offline linux-works
    • netstuff
« Reply #19 on: February 28, 2014, 01:12:52 am »
liquibyte's version looks quite good.
Ketturi's version does not have the rounded edges, that I think dave was shooting for.
 you guys do fast work, lol.
Offline linux-works
    • netstuff
« Reply #20 on: February 28, 2014, 01:15:54 am »
the spotty nature looks like a bad printing job.  or a bad drawing job; not an intentional 'effect'.  if you have a cheap tee and some of the screening comes off in the wash, it would look like this.  not sure that's a good thing, to be honest.
Offline EEVblog
« Reply #21 on: February 28, 2014, 01:19:09 am »
Hmm can't seem to get this working with Irfanview. If I lave at 256 colours it doesn't save the transparency properly. If I reduce to 16 colour I get the outline around the circuit and text again...
Offline ep1cman
« Reply #22 on: February 28, 2014, 01:20:01 am »
My attempt at it
One EPS (zipped) and one PNG both with no background (text is white so it may be hard to read)
Offline Ketturi
« Reply #23 on: February 28, 2014, 01:21:59 am »
D'oh I used wrong file, my bad, and l liquibyte did great work too.
I'd say we go with it. (I won't make another try as I'm going just now to sleep fever&flu off...)
Offline EEVblog
« Reply #24 on: February 28, 2014, 01:22:50 am »
I think it looks wrong somehow, like the characters have been eaten away. Plus the ground symbol and +/- are missing!
