Author Topic: Negative voltage episode  (Read 3008 times)
Offline glatochaTopic starter
« on: May 09, 2013, 01:46:31 am »
Guys,
I know there was an episode when Dave describes, several methods of making symmetrical supply from single battery.
Cannot find it :(
Please help :)
Offline IanB
Re: Negative voltage episode
« Reply #1 on: May 09, 2013, 01:50:15 am »
There really aren't many ways to do that. You can either use an op amp to create a virtual ground half way between the two rails (for low power needs), or you can use an switcher of some kind to generate additional voltages as needed.
« Reply #2 on: May 09, 2013, 02:18:53 am »
Yes, you can take the two batteries, or take opAmp, or some bulk converter application. But I watched once the episode, when Dave described it, just cannot find it now :(
Offline c4757p
  • adieu
« Reply #3 on: May 09, 2013, 02:22:27 am »
What do you need it for? For most op amp stuff, you don't really need a true power rail, just a virtual (signal) ground. Just connect anything you would normally ground to a voltage divider instead.
Offline Excavatoree
« Reply #4 on: May 09, 2013, 02:34:05 am »
I think you are remembering EEVblog 72. (Right around the 21:00 mark)
« Reply #5 on: May 09, 2013, 03:02:26 am »
I have two application in mind. One measuring, so in this case the virtual ground with opamp would work.
The other is for industrial analog signal +-10V. But here I need to check the requirements for the IC I want to use.
