Author Topic: EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope  (Read 110398 times)
Offline Noy
Re: EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope
« Reply #525 on: January 22, 2019, 08:43:01 pm »
I know what you mean...
Main reason for the MSO was buttons for each Channel and a bigger Screen..
And of course 350MHz BW with probes..
4  new 350MHz Hameg probes are more than half the price for the MSO...
So now is the question, is the Toellner analog FG & build in MSO AWG better than purchasing an additional FY6800?
Maybe selling the TOE 7401..?
I don't want to pay several hundreds euro for a sometimes used AWG only for the "Brand" Rigol/siglent ...
Offline Martin72
« Reply #526 on: January 22, 2019, 09:03:34 pm »
I know what you mean…. ;)
I think for sometimes in use and if you don´t Need amplitudes above 5v, the built-in awg would be enough.
And now I´m going to my siglent awg, blowing the dust away…. 8)
Offline orion242
« Reply #527 on: January 25, 2019, 02:33:12 am »
Got mine today.  Not seeing any real difference in screen brightness myself.
Offline Martin72
« Reply #528 on: January 25, 2019, 09:54:40 pm »
Mhh….
You compare it with another rigol…. ;)
Took my 5074 back to work for recording the displaying of PWM signals for the rigol support (actually I´m in touch with them, nearly daily - excellent support from rigol.eu by the way), I must dim the light on my desk to see everything on the screen almost bright.
But it´s not the most annoying thing.
On a friday afternoon none is here, I got my calm - And then switching on the 5074....The fan, god, only Lecroy Wavejets can "beat" it.
Rigol should allow customers the exchange to a silence one without loosing warranty…..
Offline orion242
« Reply #529 on: January 27, 2019, 05:17:05 am »
Either your under operating room light level or take off your sunglasses.
Offline Martin72
« Reply #530 on: January 27, 2019, 11:31:16 pm »
We´re wearing sunglasses since we got new LED Lights in our department... 8)
Seriously, the display isn´t the brightest one on the market plus the limitated angle view.
Offline Martin72
« Reply #531 on: February 01, 2019, 10:49:06 pm »
Ideal place for it is on the desk itself, in the shelf above it appears too dark.
Offline Fungus
« Reply #532 on: February 02, 2019, 10:46:46 am »
Brightness might be controlled by a single resistor. Should be hackable.
Offline oliv3r
« Reply #533 on: February 02, 2019, 10:46:58 pm »
At the cost of reduces lifetime :) but probably yes. Apearantly it runs at 9. something volt and the absolute max is 10.2 i belive
Offline Martin72
« Reply #534 on: February 02, 2019, 11:25:23 pm »
Lifetime...10 Years, 20 Years…..or less than 5.....
Offline Noy
« Reply #535 on: February 05, 2019, 03:47:20 pm »
Got a mail from Batronix..
My scope shipping will be delayed.. They said beginnt of february now its beginn of march....
Hopefully not with a new Firmware...
Offline Fungus
« Reply #536 on: February 05, 2019, 06:58:33 pm »
Don't worry, the people at Rigol already know the reason why they can't manufacture them fast enough to keep up with demand.
Offline TopLoser
« Reply #537 on: February 05, 2019, 07:11:19 pm »
Plenty of 5074 in stock at Batterfly
Offline Martin72
« Reply #538 on: February 05, 2019, 08:25:30 pm »
Official new firmware will be launched between mid/end of february.
Offline orion242
« Reply #539 on: February 06, 2019, 02:07:39 am »
<5 because they keep coming out with a better hackable unit...forcing the hand to upgrade.
..least says the guy that dumped his crow for 1052, now three Rigols later.
« Last Edit: February 06, 2019, 02:30:08 am by orion242 »
Offline Martin72
« Reply #540 on: February 07, 2019, 09:06:01 pm »
Maybe it  musn´t be hacked.
Rigol have it on their to-do list(did a request About)..
Offline Martin72
« Reply #541 on: February 12, 2019, 08:51:43 pm »
It isn´t really a bug, but today was the first time I used more than one math channel.
I took the low pass filter Funktion on three channels to filter out three phase sinewaves from pwm.
And they all got the same colour....
All 4 traces are violet - very irritating in cases described before.
Hope they´ll change it into 4 different colours.  :P
Offline offmar
  • Country: bg
« Reply #542 on: February 21, 2019, 07:56:58 am »
Hi guys,
I recently received my 5074. While trying to compensate the 10x probes, I'm unable to get the perfect square shape of the signal. On channels 1,2,4 I always get some overcompensation. On channel 3 it looks perfect. I've attached pictures to illustrate. Is it normal or should I return it, while still can?
Thanks!
Offline Fungus
« Reply #543 on: February 21, 2019, 09:11:15 am »
The test signal on 'scopes is usually about 3V peak, you're only showing 300mV.
This makes me think you're doing something wrong.
Offline offmar
  • Country: bg
« Reply #544 on: February 21, 2019, 10:14:54 am »
Thanks Fungus, you're right! I had the attenuation set to 1x on all 'scope channels. I've set it to 10X, but this had no impact on the form of the signal. It's still with some overshoot on 1,2 and 4-th channel.
Online TK
« Reply #545 on: February 21, 2019, 11:34:17 am »
Have you tried swapping the probes to different channels to see if the problem is in the probes or the scope input?
Offline David Hess
  • DavidH
« Reply #546 on: February 21, 2019, 12:00:00 pm »
I agree with TK; swap the probes around and see if the problem follows the probes or follows the separate channels.
After that, I would run the same test using a faster edge from a 50 ohm reference level pulse generator with and without the probes.
Offline offmar
  • Country: bg
« Reply #547 on: February 21, 2019, 12:13:59 pm »
Yes, I tried swapping the probes. Nothing changes, seems it's the scope input. Also, when I switch the probes to 1x, the form is the same, maybe 30% less overshoot. I have no separate generator, but when I use the scopes internal, I get slightly different result, but never perfect.
« Last Edit: February 21, 2019, 12:15:40 pm by offmar »
Offline mindy
« Reply #548 on: February 21, 2019, 12:14:44 pm »
I have very similar issue with my MSO7014, but in my case all the channels gives me the same result.
https://www.eevblog.com/forum/testgear/new-rigol-ds7000/msg2190588/#msg2190588
When tried with 50 Ohm input I got clean, perfectly compensated signal.
#nctnico suggested that this may be due to a crossover between LF & HF what kind of makes sense.
I hope that this can be calibrated and not something messed up on a hardware.
Just wondering if all MSO5k / MSO7k have similar compensation signal issue.
Offline offmar
  • Country: bg
« Reply #549 on: February 21, 2019, 12:33:05 pm »
Thanks for the link! The issue seems quite similar. As I'm not quite experienced with 'scopes, it's not clear to me, shouldn't all this probe compensation thing be a simple, straightforward process? And what worries me is that I see the same shape with probes set to 1x.
