Author Topic: past mailbag item question.  (Read 1499 times)
Offline JWoodrell
    • Woodrell Machine and Control
« on: July 16, 2016, 02:34:50 am »
I remember seeing an opt in cross strip veroboard sent into the mailbag a while back.  I am working on a project which is going to use that concept and I wanted to give credit, but I can't find where I saw it on here.
the layout looks like this if that helps
the top layer lets you solder jump (6 mil gap) any given through hole to an adjoining vertical strip line.  and the bottom layer lets you solder jump any given TH to a horizontal strip line.
this will eliminate alot of the jumper wires needed for a protoboard layout.  It is a cool concept and I want to make sure I can give the guy credit.
Offline mairo
Re: past mailbag item question.
« Reply #1 on: July 16, 2016, 09:31:24 pm »
https://www.kickstarter.com/projects/658903329/perf-the-perfboard-reinvented/description
http://www.dailytelegraph.com.au/newslocal/north-shore/north-sydney-student-gains-funding-from-around-the-world-for-his-electronic-prototyping-board/news-story/cf426737386892ab37abfc422d100b6d
I think this is what you are after, not sure in which video Dave talked about it tho. Will be good to find the video as I remember either him or another boy from Sydney (I think) who made some remote PC resetting 'device' had it patented.
