When I write this:
wget [url=https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin]https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin[/url]
git clone [url=https://github.com/themadinventor/esptool.git]https://github.com/themadinventor/esptool.git[/url]
cd esptool
sudo python2 ./esptool.py --port /dev/ttyUSB0 write_flash 0x00000 ../nodemcu_float_0.9.6-dev_20150704.bin
It automatically adds the url-tags, but because it is code, it shows the url tags, too.
When I use quote:
git clone https://github.com/4refr0nt/luatool.git
It adds the url-tags, too, but doesn't show it, which is fine. For code I would prefer that it doesn't change anything within the block. Is this possible? Maybe would be better to disable "Automatic Link Posted URLs" altogether, this would be an easy fix.
Let me try:
wget https://github.com/nodemcu/nodemcu-firmware/releases/download/0.9.6-dev_20150704/nodemcu_float_0.9.6-dev_20150704.bin
git clone https://github.com/themadinventor/esptool.git
cd esptool
When I preview the above, nothing gets modified. Is it only when hitting post that something gets changed?
If so, I would guess it is a bug. IMHO nothing inside code tags should get modified at all.
Well, I don't know what is happening to your posts. As you saw, no URL tags got added to my experimental post here.
Ok, I found the smallest working example for this bug:
First use a url-tag with a http address, then use a code-tag with a https-address, but without an url-tag. After posting, it adds the url-tag inside the code tag. Like this:
test.com.
[url]https://test.com[/url]
The forum code must be a mess for such kind of bugs
