Could someone explain how the dip switch settings work when adding more batteries to a battery bank. The operation manual does not go into detail .
I would like to know what combination do you set the master and the salves in different scanerios etc.
What do the dip switches actually do ?
What setting do you use with a single battery, x2 batteries, x3 batteries ...?
