Author Topic: Struts problem report : EEVBLOG forum  (Read 13650 times)
Offline wilfredTopic starter
« on: January 14, 2013, 01:42:25 am »
« Last Edit: July 28, 2018, 02:38:36 am by wilfred »
Offline free_electron
    • SiliconValleyGarage
Re: Struts problem report : EEVBLOG forum
« Reply #1 on: January 14, 2013, 01:52:51 am »
i've een that also a couple of times today. has something to do with the banner...
Offline JoannaK
    • Diytao making blog
« Reply #2 on: January 14, 2013, 06:50:01 am »
No-one should be having Java (not even serve side) allowed and running at the moment. There's way too many bugs in it and there's wild exploits and hacks.
Appartently Corel just fixed one zero.day exploit, but AfaIk it was not good enough.
Offline EEVblog
« Reply #3 on: January 14, 2013, 07:03:24 am »
Yep, I've seen a few banner errors from SupplyFrame too. Something up with their server again I suspect. Happens occasionally.
Dave.
Offline HackedFridgeMagnet
« Reply #4 on: January 14, 2013, 10:26:27 pm »
The exploits use java browser plugins to infect your JRE.
So turn off Java plugins (applets) in your browser and you should be relatively safe.
Well at least as safe as using flash, javascript, python ruby etc.
The exploit does not directly effect:
javascript, serverside struts, apache, eclipse, Open Office or Minecraft.
that said the error message might have had something to do with server side upgrading in order to fix non existent exploits because management decreed it.
