Hi!
A small question about the efficiency of the circuit:
This circuit supposes to work on battery power, so does the 1.3W-5W constant power consumption is the best solution?
Is there a way to have a more power efficient circuit?
Thanks
Yoav
(This is my first post, so if I'm breaking any rules - SORRY !!!)
If you look at the diagram, 3,5,8 all go only to the bandgap reference and is marked "internal function". I don't see what else this could be than a Kelvin type connection to the low side of the bandgap reference. It's clear to me that the 2 mA can not go through 3,5,8. These 2 mA flow because of the resistors in the feedback loop, and come out through ground pin 4.
Let's analyze the circuit. We have a 1.25 V bandgap reference and a Kelvin current shunt of 1.25 ohm. When there's a 1.25 V voltage present over the shunt, we know 1 A flows through the resistor. This is the obvious basic operation of the circuit. But the problem then becomes, where are these things actually referenced from? I would like to refine the function of the circuit to "the goal is to keep the voltage over the shunt sense pin identical to the voltage over the bandgap reference sense pins".
This is where derive that 3,5,8 instead of all the chip's ground should be connected to the shunt sense pin. There will be a small voltage drop over the shunt's current and sense pins, and the bandgap reference's lower connection will now (presumably) be lifted from the circuit ground by that many mV. If we didn't do this, we would have an error current. This error current is not caused by the shunt's voltage drop, but by the quiescent current and the drive current for the force pin, through the metal between the chip and the lower shunt sense pin. I'm even willing to bet that this may have something to do with the oscillation.
And likewise, keeping the other two legs of the circuit identical is done by the opamp in the voltage reference chip. So what does it use as it reference? Depends on your definitions. It's ultimately using the device ground as its reference. However, if the shunt's sense pin raises the reference ground to say 0.001 V over the circuit ground, then the bandgap reference will now output 1.251 V over circuit ground which is now the amplifier's target for the shunt's higher pin (which it tries to control by driving the MOSFET.) But the goal to keep the voltage over the sense pins of the hunt at 1.25 V is still met.
So yes, I think this is the way to go. Can we get an empirical confirmation from some crazy bloke down under?
Hi Folks: Is there reasonably good alternative to using the Vishay whoopty doo VPR221Z Precision 4-terminal Z-Foil resistor? For example: using eight 10 ohm 0.1% soldered in parallel (1.25 ohm) to copper bus bars with the sense and current wire connected to the buses.
in page 16 there is indication pin 4 is for 4 kelvin connection..
And that's what you want. everyone connected back to the star point, which will be the current shunt sense terminal.
IIRC that's what the app notes say as well.
Where can you actually buy the precision resistors with customer specific value ?
You can get them from Vishay directly: http://www.vishaypg.com/foil-resistors/how-to-order/
Caveat: I haven't actually ordered from them, so I don't know if they'll talk to hobbyists.
a transistor is a current controlled current source, similarly mosfets are voltage controlled current sources by themselves and between opamps output and inverting input exists a current source, that is to say a common emitter configured transistor there exists a current source between collector and the supply voltage rail.Now if we jam a reference voltage of 5.6 into a BJT' base, configured as a common emitter, with emitter degeneration of say 5 Ohms there will exist a approx 1 amp current source between collector and Vcc, as is ,you will find it to be a little unstable and drifty.
Now the thing is opamps are ubiquitus and are crying out to be used as PID controllers, each litttle opamp is a little controller in it's own right. So why not use it here, we can control the current through the transistor.
Connect the reference to the opamps non inverting input and the opamp's output to the base of the ce transistor and lastly connect the opamps inverting terminal to the bjt's emitter still using emitter degen. resistor of around 5Ohm or so and that's it for now. The current output is between top supply rail and the transistors collector terninal.
Using brand new expensive parts specialist resistors costing tens of dollars is a no no![]()
