Author Topic: suggestion for blog topic -- low power design  (Read 4362 times)
Offline cksa
« on: September 11, 2010, 02:14:09 pm »
I remember dave breifly talking about low power electronics design on the amp hour. It might be a good blog topic to expand upon this. What are some of the common techniques? How can I avoid pissing away current in using a 10k pull-up resistor?
I'm sure many of us will find such an episode interesting :)
Online Simon
  • Global Moderator
    • Simon's Electronics
Re: suggestion for blog topic -- low power design
« Reply #1 on: September 11, 2010, 03:08:31 pm »
it is probably a very broad subject that starts with choosing low power parts and knowing the details specs of your parts and how far you can push them
Online Zero999
  • 0999
« Reply #2 on: September 12, 2010, 08:47:29 am »
It depends on the input impedance and the logic levels.
Here's a PIC tutorial I'm following which discusses the issue of pull-up resistors, read the first couple of pages.
http://www.gooligum.com.au/tutorials/baseline/PIC_Base_A_4.pdf
Online Simon
  • Global Moderator
« Reply #3 on: September 12, 2010, 09:01:29 am »
you using assembly ?
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: September 12, 2010, 09:48:22 am »
That's not always the case - the knack is understanding how to get the result you need with the lowest power, and in some cases, the lowest power part is not the best choice.
In many cases the critical parameter turns out to be the length of time tnings are turned on, not the current draw whilst on.
A good example is sensing analogue values, e.g. temperature or pressure, on a low duty cycle.
In this sort of application you need to  turn on the sensor and often an amplifier, wait for it to settle, read the value and then turn off.
In practice, the settling & measurement time is often the  most critical value, as everything is powered, and often the CPU running as well.
Where there is an amplifier, a fast opamp is generally more desirable than an ultra low power one, as the latter will be trading speed for power draw.
For a microcontroller, things like the number of different selectable clock rates and watchdog rates, provision of different levels of sleep, available wakeup methods and oscillator start-up time can make a bigger difference to overall power draw than the actual current draw in each mode.
Day Job: Mostly LEDs
Offline djsb
« Reply #5 on: September 12, 2010, 12:41:35 pm »
I wonder how NASA manage it on their Mars rovers. That's got to be the ultimate design challenge. Pity they don't have any design info available. They probably use FPGA's anyway. It'd be great to learn some of their tricks.
David.
Hertfordshire,UK
 University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor.  http://debuggingrules.com/ Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
Online Simon
  • Global Moderator
« Reply #6 on: September 12, 2010, 01:06:27 pm »
yes well the mars rover panels did not need to generate enough power to lift their weight into the sky, moving something along the ground is feasible, but lifting it under it's own generated power is a bit more tricky
Online NiHaoMike
    • Facebook Page
« Reply #7 on: September 12, 2010, 01:14:11 pm »
David.
I'm sure that given their budget, they probably have their own ASIC design team and perhaps some chip fabs.
Offline migsantiago
    • MigSantiago's Web Site
« Reply #8 on: September 12, 2010, 01:35:29 pm »
http://voyager.jpl.nasa.gov/faq.html
What kind of computers are used on the Voyager spacecraft?
There are three different computer types on the Voyager spacecraft and there are two of each kind. Total number of words among the six computers is about 32K.
Computer Command System (CCS) - 18-bit word, interrupt type processors (2) with 4096 words each of plated wire, non-volatile memory.
Flight Data System (FDS) - 16-bit word machine (2) with modular memories and 8198 words each
Attitude and Articulation Control System (AACS) - 18-bit word machines (2) with 4096 words each.
According to my calulations, that's a total of about 541KB, or small potatoes compared to today's microprocessors. We probably could perform all functions with one of today's boards and still have room for solid state data storage and much more fault detection software. We would still need a second unit for redundancy. Today's microprocessors are also much faster than the chips used on Voyager and a comparative system would use less electrical power. On the other hand, software might be more complicated as opposed to that used in an interrupt type system, but it would be much more capable and more flexible.
http://wapedia.mobi/en/Intel_8086?t=3.
As of 2002, NASA was still using original 8086 CPUs on equipment for ground-based maintenance of the Space Shuttle Discovery, to prevent software regression that might result from upgrading or from switching to imperfect clones. [15]
Nasa may not always use the state of the art microprocessors. I've read they're still using old Intel processors, since their reliability has grown during all these years. They are mature processors.
Online Zero999
  • 0999
« Reply #9 on: September 12, 2010, 01:36:22 pm »
What me?
Yes, I'm getting there.
Give it a go, it's more efficient, meaning you can use cheaper MCUs for the same tasks.
Online Simon
  • Global Moderator
« Reply #10 on: September 12, 2010, 01:42:16 pm »
What me?
I've not had something yet that maxs out the resources of the pic, as it is my dynamo controller needed a delay putting in the program to keep the software in sync with the rest of the world
