Author Topic: The 'newer' EEVBLOG 121GW Multimeter  (Read 7516 times)
Online taydin
  • Country: tr
Re: The 'newer' EEVBLOG 121GW Multimeter
« Reply #25 on: November 13, 2017, 12:45:36 pm »
The number of digits defines the precision, which is not dependent on the meter accuracy, even though both are usually confused.
The attached image shows the difference way better than I could explain.
This picture makes the concepts clear, but I would replace the word "precision" here with "stability". A stable voltage reference (whose value changes very little) is very valuable, even if it doesn't output the desired voltage level of say, 10.0000V, but instead outputs 6.28938V.
Real programmers use machine code!
My hobby projects http://mekatronik.org/forum
Offline DrGeoff
    • AXT Systems
« Reply #26 on: December 20, 2017, 04:35:07 am »
It just occurred to me that a nice addition that might be possible in firmware in the V setting is a mode for dBV for AC volts.
I have other meters which give me this reading directly as a mode when measuring ACV. Just thought I'd put it out there.
- Geoff
Was it really supposed to do that?
Offline EEVblog
« Reply #27 on: December 20, 2017, 06:43:51 am »
LOL, I forgot it actually has this already. Need to add that to the manual.
The following users thanked this post: Andrew McNamara
Offline Bud
« Reply #28 on: December 20, 2017, 06:51:23 am »
What is the reference impedance you use to calculate dBm ?
Offline DrGeoff
    • AXT Systems
« Reply #29 on: December 20, 2017, 06:58:04 am »
Nice one Dave. Thanks!
Offline EEVblog
« Reply #30 on: December 20, 2017, 07:04:42 am »
I presume standard 600ohm, but I haven't actually tried this as I forgot all about the feature  :-[
Offline Bud
« Reply #31 on: December 21, 2017, 02:41:15 am »
This may be source of great confusion for people especially RF people, as many assume 50 Ohm reference impedance. As DrGeoff said better use dBV.
Offline drussell
  • Hardcore Geek
« Reply #32 on: December 21, 2017, 05:51:32 am »
The usual reference impedance on multimeters is for 600 \$\Omega\$ lines.
Offline Bud
« Reply #33 on: December 21, 2017, 04:23:13 pm »
Using dBV will eliminate all guesses. This is why I asked my question.
Edit: also, it is not terribly useful to have it tied to 600 Ohm. There is a multitude of measurements done with a multimeter with different circuit impedances, you do not want to recalculate every time, and may not need it in terms of power . In terms of voltage will be more useful, and that is dBV.
« Last Edit: December 21, 2017, 04:26:52 pm by Bud »
Offline Andrew McNamara
« Reply #34 on: December 22, 2017, 01:35:18 am »
600 ohms is the customary impedance for audio frequency measurements of dBm. Given the meter is likely out of spec for RF anyway, 50 ohms wouldn't make much sense. Maybe dBv would be preferable, but for AF, dBm is the tradition - maybe the assumed impedance should be configurable?
Offline lowimpedance
  • Watts in an ohm?
« Reply #35 on: December 22, 2017, 02:40:21 am »
The ancient Fluke 8050a has dB measurement and the REF. impedance is configurable, so having that ability on the 121GW would be very useful. Maybe displaying the currently set REF. IMP. briefly when the function is selected.
Offline imaradiostar
« Reply #36 on: May 24, 2019, 04:36:15 am »
Sorry for the bump- any further thoughts on this? dBv would be a nice change to this meter. My ancient Fluke 8050a and 8060a can do it, as can my 187.
Not complaining, just asking. The meter is great!
JT
