Author Topic: What tool(s) to screen capture and comment on screen Dave uses?  (Read 347 times)
Offline Tarik
« on: February 17, 2020, 06:42:52 pm »
Hello,
I tried to make a video for my channel, but I didn't succeed.
The screen of my PC was recorded, but all the markers, lines, like Dave uses to mark points of interest, were not recorded.
I now wonder which software stack Dave may use (Inspired by "EEVblog #1285 - How to do Design By Inspection", where capture, mark and erase works very well)?
May be, it is all post-processing?
Tarik
Offline ebclr
Re: What tool(s) to screen capture and comment on screen Dave uses?
« Reply #1 on: February 17, 2020, 08:37:14 pm »
Isn't Davids one but is quote good
http://www.pointofix.de/bedienung.php
Offline delfinom
« Reply #2 on: February 18, 2020, 04:09:31 pm »
He's opening the PDF in a fantastic Windows only program called Drawboard https://www.drawboard.com/ . It only works on PDFs though, it's not a screen drawing app.
« Last Edit: February 18, 2020, 04:26:25 pm by delfinom »
Offline SilverSolder
« Reply #3 on: February 18, 2020, 06:02:46 pm »
Windows 10 only, apparently.
Haven't seen that limitation before...
Offline HwAoRrDk
« Reply #4 on: February 24, 2020, 10:25:34 am »
Perhaps because your screen capture software was set to capture only the contents of a specific window, but whatever you were using to annotate does it as an overlay that is technically a separate window, so it doesn't get captured.
Might be worth trying something as simple as capturing a specific area or the entire screen, then it might work.
