Author Topic: You need at least 4 multimeters?  (Read 9035 times)
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
« on: March 04, 2014, 06:54:19 pm »
Does anyone remember in which episode Dave talks that you need at least 4 multimeters? One my friend just got caught by burden voltage trap, I want to give him some additional food for thought  ;D
Offline hans
Re: You need at least 4 multimeters?
« Reply #1 on: March 04, 2014, 08:12:33 pm »
Episode 110, let's design a SMPS @ 31:20
It was about the efficiency Dc/Dc converter, so you need input voltage/current and output voltage/current
Offline uwezi
    • GreenPhotons
« Reply #2 on: March 04, 2014, 11:08:34 pm »
And then you need a fifth one when you want to measure something which is inside the circuit, while still monitoring input and output. In other words, you cannot have too many multimeters - because then there is always number six, which is currently without battery...
Offline dr_p
« Reply #3 on: March 04, 2014, 11:17:35 pm »
And you have to like all of them, so you need at least 10 to choose the 6 from.
Offline zapta
Re: Re: You need at least 4 multimeters?
« Reply #4 on: March 05, 2014, 02:32:54 am »
And then there are the cases when you work on two DC/DC at the same time...
I am getting alone with one.
Sent from my Nexus 5 using Tapatalk
Drain the swamp.
Offline Pillager
  • Country: at
« Reply #5 on: March 05, 2014, 04:38:00 am »
... In other words, you cannot have too many multimeters ...
Yes, you can. Fluke has so many they're selling them... ;D
Greets
Tom
Offline Fsck
  • sleep deprived
« Reply #6 on: March 05, 2014, 05:02:57 am »
occasionally, you might actually need/want all 10.
"This is a one line proof...if we start sufficiently far to the left."
Offline Jon86
« Reply #7 on: March 05, 2014, 05:38:48 am »
In what situation?
Death, taxes and diode losses.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #8 on: March 05, 2014, 05:42:43 am »
For a post picture in show your multimeters  :-DD
Offline Dave Turner
« Reply #9 on: March 05, 2014, 06:34:54 am »
Don't forget the obligatory analogue meter(s).
I wouldn't be without my TMK 500, which is at least 30 years old, replacing another old trusty from the 60s (unfortunately accidentally destroyed by a friend  |O). Yes it has a 'burden' of 30k ohm/VDC, and requires careful thought before choosing the range and interpreting results.
Nevertheless analogue meters still have their place as discussed in another thread.
Offline Fsck
  • sleep deprived
« Reply #10 on: March 05, 2014, 07:24:07 am »
In what situation?
some kind of electronic function test.
something with many sensors.
troubleshooting/analyzing a multiple channel power supply
there's a bunch of RF applications
characterizing a whole system for repeatability
the 3458a feels like the defacto physics research bench DMM. to save money, many labs combine it with a switch system to have multichannel capabilities. which gives you similar capabilities to multiple DMMs: I've seen this more often in SS&CM physics. on the other hand, I've also seen some labs equipped with half racks of 3458's and a high speed switch system for faster acquisition and higher accuracy or to ensure certain sets of measurements are done simultaneously: more common for particle physics.
addendum: need for 4 -> it's pretty common to want 2 voltage readings and 2 current readings simultaneously.
« Last Edit: March 05, 2014, 07:25:43 am by Fsck »
Offline madshaman
  • ego trans insani
« Reply #11 on: March 05, 2014, 07:41:13 am »
I don't understand how anyone can get by with just four DMMs :-)
To be responsible, but never to let fear stop the imagination.
Offline robrenz
« Reply #12 on: March 05, 2014, 07:49:51 am »
At least 2 of the 4 must have built in graphing :-+
Offline gdewitte
« Reply #13 on: March 05, 2014, 08:05:03 am »
You really need an odd number, so they can vote…
Offline sacherjj
« Reply #14 on: March 05, 2014, 08:10:31 am »
If you have an even number voting, you can cast the last vote towards what direction you "need" the measurement to go.
Offline Jon86
« Reply #15 on: March 05, 2014, 09:52:26 am »
I wonder how big the largest collection of multimeters on here is...
Offline pickle9000
« Reply #16 on: March 05, 2014, 09:56:47 am »
Ask Dave.
Offline Astroplio
  • Country: gr
    • Welcome to myrobots
« Reply #17 on: March 05, 2014, 10:29:12 am »
LOL you guys!
Offline babysitter
  • pushing silicon at work
« Reply #18 on: March 06, 2014, 07:24:38 am »
I would say you need two DMM (for both labs), Computer control (GPIB) and a Multiplexer O0
I'm not a feature, I'm a bug! ARC DG3HDA
Offline GiskardReventlov
  • How many pseudonyms do you have?
« Reply #19 on: March 06, 2014, 08:38:56 am »
What's the handheld:bench ratio though?
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #20 on: March 06, 2014, 01:12:50 pm »
4:7
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline BMac
« Reply #21 on: March 07, 2014, 12:04:47 am »
Really, can you ever have enough test equipment, ooohh wait i see a new shiny piece of test equipment, gotta go!
BMac
Offline rjk5378
  • "Life is a science fair!" - Forrest Mims
    • Law Offices of Robert J. Keller, P.C.
« Reply #22 on: March 07, 2014, 02:08:24 am »
You also need experts on this forum and elsewher to opine often about the need for multiple multimeters and other types of equipment. This is useful when one needs to convince the bean counters at work or, as in my case, for the hobbiest to justify yet another expenditure to the spouse! And, in that regard, having lots of test gear on the bench makes it less obvious that I have smuggled in a new addition. I see each and every unit in all its beauty, but my wife just sees a bunch of junk! <g>
- Bob, KY3R
« Reply #23 on: March 07, 2014, 10:15:12 am »
So true.  A variation on this theme is to maintain a certain level of messiness, it's easy to camouflage something new.  Don't leave the shipping carton laying around though.
Offline BravoV
« Reply #24 on: March 07, 2014, 02:57:36 pm »
Once you have graduated and have enough in the progress of collecting more and more DMMs  >:D, then don't forget the task on getting more ... <gulp> ... bench power supplies !!!  :-DD
Damn .. the curse never ends.  :palm:
