Author Topic: 25MM Thermal camera IR lens wanted  (Read 1472 times)
Offline radioorizontTopic starter
« on: April 06, 2024, 12:57:39 pm »
Hi All.
Looking for a replacement front lens for a T3XX/ T4XX / B3XX B4XX camera.
The front lens has been damaged hence looking for a similar spec lens to replace it.
It's 25mm meniscus (convex on both inner and outer side). Not sure yet of exact specs but it's F1.3 FOCAL LENGTH 18
Also looking for a 10m wide lens for same models if you have one.
Thanks all.
« Last Edit: April 06, 2024, 06:12:56 pm by radioorizont »
Offline Hazel
Re: 25MM Thermal camera IR lens wanted
« Reply #1 on: April 30, 2024, 01:18:59 am »
Hi,have you found the right lens?
« Reply #2 on: May 10, 2024, 10:34:59 am »
Hi, not yet. Cheers
Offline Hazel
