Author Topic: Any takers for theses ... sma rigid links, wave guide ?  (Read 1045 times)
Online coromonadalixTopic starter
« on: September 07, 2024, 01:12:21 pm »
come from a dismantled     HP AGILENT J7231B OMNIBER       thing  loll
i absolutely don't know  if they are simple links , wave guides etc ...
i have no sma test setup to test them,   but the unit passed all self tests  before dismantling ??
I have some or the interfaces pcb /cards too,  i'll put numbers later if some show interest     the cpu card is gone
3x   j7231-65036-1                                           around 25.5mm between center pins
1x   j2731-65077-1   with a small yellow tape     around 24.5mm between center pins
1x   j7231-65037-1             around 51.5mm between center pins
1x   j7231-65034                around 51.5mm between center pins
1x  j7231-65035                 around 77.5mm between center pins
just pay shipping ...  or they taste the bin   loll
Offline EggertEnjoyer123
Re: Any takers for theses ... sma rigid links, wave guide ?
« Reply #1 on: September 07, 2024, 08:32:20 pm »
How much for shipping to the US?
Also have any RF boards or anything?
« Reply #2 on: September 08, 2024, 01:21:28 am »
@eggert,  you're #2  send me an address in pm
board of ???  of the hp j7231 ??
« Reply #3 on: September 08, 2024, 01:10:45 pm »
wow   lots of pm for theses ??     some asked for internals coax or rf cables
i think theses are gone, i'll answer per order of arrival,  i'll post one card internals, it has some snapping coax cables in one
I just need to figure out the connector type
« Reply #4 on: September 08, 2024, 10:41:19 pm »
photos
Offline edavid
« Reply #5 on: September 08, 2024, 10:51:55 pm »
I would call those hardline jumpers.  Definitely not waveguide.
The following users thanked this post: Overspeed
Offline exe
  • self-educated hobbyist
« Reply #6 on: September 14, 2024, 07:14:52 pm »
Why not a waveguide? Google says that a coaxial cable is a waveguide (https://en.wikipedia.org/wiki/Coaxial_cable), and those "rigid cables" are kinda same thing.
Offline edavid
« Reply #7 on: September 14, 2024, 07:52:19 pm »
Sure, call them waveguides if you want to confuse everyone.  Then we could call actual waveguides "snafflegorps"  :-//
Online Overspeed
« Reply #8 on: September 14, 2024, 07:55:44 pm »
Hello
That a wave guide , mainly a square tube with flanges
Regards
OS
« Reply #9 on: September 15, 2024, 03:38:47 am »
thks    but  some of the wire are very stiff, maybe the shield is thinned  ...   i have 2 contenders,  i have to get bubble envelopes i ordered them   ill see
1 is in germany, 1 other in usa
here we have thickness rules,  if not, it is a small package ...  not many choices
Online Overspeed
« Reply #10 on: September 15, 2024, 07:52:19 am »
Hello
in RF cable you can have :
rigid cable which are formed as plumber copper pipe
or
semi-rigid you can form with your finger or simple jigs
or
flexible cable
BUT
all have a central wire , wave guide have no wire inside
Regards
OS
« Last Edit: September 15, 2024, 05:28:54 pm by Overspeed »
The following users thanked this post: coromonadalix
