Carlson SuperProbeCarlson introduced his SuperProbe design around 2017. Numerous implementations abound the internet. One on Instructables provided a basis for a kit design that filled in the void created by Carlson's approach. We created a new PCB design for the two PCBs and a kit of parts that allow constructors with adequate SMD skills to build the SuperProbe. It requires significant creativity because the kits provide only part of the final design. Builders must create their own amplifier case, speaker, power supply and Carlson's SuperProberobe body.
We are offering kits for building the PCBs with 3 levels of components details.
1) MK0 kit -Amp & Probe PCB only. Full paper instructions. Get your own parts.
2) MK1 kit - 26 unique parts to populate the 2 PCBs as well as the 2 POTs and ballast lamp.
3) MK2 kit - 35 unique parts to do MK1 kit plus knobs, power switch & LED, probe 3C wire, hookup wire & shrink tube, jack & plug.
4) Bat-Pak - 800mAh battery pack kit with micro-USB charger PCB, cable and wiring.
These kits are available on eBay and our website.
eBay: Just search for Carlson's SuperProbe.
Web: https://
www.hwcz.com/phpSP/MCSP_MK2.phpWeb buyers can use the following coupon code for a discount at the shopping cart checkout:
superprobesaleGood through the end of February 2025.
