Author Topic: For Sale: Fluke 5790A AC  (Read 537 times)
Offline AMS09Topic starter
« on: February 01, 2025, 11:59:34 pm »
This item is an excellent condition used Fluke 5790A AC Measurement Standard (5790A-03) with Wideband Option 03: Low-loss Type-N connector for making wideband voltage measurements from 10 Hz to 30MHz. Has original Fluke feet and handles. This unit was calibrated by Fluke at their primary standards lab on December 31 2023, expiry date of December 31 2024. Comes with power cable and Fluke ISO 17025 accredited calibration certificate with full as-found data report (expired December 31, 2024). All pictures are of the actual unit.
This item comes with a 6 Month (180 day) warranty. This unit has gone through meticulous inspection to guarantee its reliability and durability.
The 5790A is a complete automated ac measurement standard designed for the most demanding calibration applications. It combines the accuracy you would expect from a thermal transfer standard with the ease-of-use of a digital multimeter. Absolute ac voltage measurement uncertainties are as low as 24 ppm (one year, 23oC 5oC). The 5790A is designed to meet the complete ac voltage and wideband verification requirements of the Fluke 5700A, 5500A and other calibrators, amplifiers like the 5725A and 5205A, and transfer standards and ac voltmeters.
The 5790A covers an alternating voltage range of 700 MicroV to 1000V, and a frequency range of 10 Hz to 1 MHz. A wideband voltage option extends frequency range to 30 MHz to meet the calibration requirements of Fluke 5700A, 5720A and 5100 Series Wideband Options.
The 5790A is also compatible with Fluke A40 and A40A Current Shunts, which permit you to make ac/dc current transfer measurements up to 20A.
The 5790A may be used alone or as a transfer standard with an external dc source. In either case the normally tedious switching and calculations are performed automatically by the 5790A, and the resulting ac/dc difference is displayed directly on the easy-to-read vacuum fluorescent display.
AC V Measurement:
Range: 700 mV to 1000V 10 Hz to 1 MHz
Best 1-Year Specification: ± 24 ppm
Wideband Measurement:
Range: 700 mV to 7V 10 Hz to 30 MHz
Best 1-Year Specification: ± 0.35%
Asking for $4200
« Last Edit: February 02, 2025, 12:01:35 am by AMS09 »
