At work we recently moved to a new building and people got rid of some stuff since we knew space will be less.
I recovered an AT89C52 board that will be great for someone who wants to do some microcontroller stuff based on it.
I'm not 100% sure if the board works or not as you can see in the picture is a pretty simple development board, what I can see is a variable power supply based on LM317, a 40 pin DIP AT89C52, a couple of 74HC244N, and some passive components, it has 2 or 3 ports where connections can be made. It runs in a 12 MHz XTAL. It also seems to have the space to add a couple of keys.
I applied power and it turned on, the ICs are in a base, so if you need to replace any you don't need to desolder it.
I'm giving this away for free if you are willing to pay the shipping cost, what we can do is that I will charge you the money once I have sent the unit to you so we know the price.
Let me know, hopefully this board can get in the hands of someone that will use it.
