Author Topic: FS( EU / World ) ASL F250 thermometer in good shape no probes  (Read 1408 times)
Online OverspeedTopic starter
« on: September 10, 2024, 10:20:12 am »
Hello
For sale Thermometer ASL F250 ( rebranded Gallenkamp / Sanyo )
good shape with some paint scratch on the top cover
No probes , ( 4 wires Pt100 )
Price 750 Euro
Note picture are labelled F25 but that a F250 . I have also a F25 so no need two thermometers
Ship by UPS or tracked Post office parcel
Regards
OS
« Last Edit: September 10, 2024, 11:23:24 am by Overspeed »
Offline nfmax
Re: FS( EU / World ) ASL F250 thermometer in good shape np probes
« Reply #1 on: September 10, 2024, 11:21:37 am »
Just to check, is this a working instrument? Have you tested it with a PRTof some sort, or a standard resistor?
Re: FS( EU / World ) ASL F250 thermometer in good shape no probes
« Reply #2 on: September 10, 2024, 11:25:02 am »
Hello
Yes I will test it again and take pictures ....
I will connect  a simulator AOIP but not run any calibration
Regards
OS
« Last Edit: September 10, 2024, 11:45:19 am by Overspeed »
« Reply #3 on: September 10, 2024, 01:47:39 pm »
Hello
The pics of a quick test with a 0.1C simulator from AOIP ( as it as I am overloaded ) , simulator was connected to rear panel connector
Both channel with unit change / values change
Regards
OS
« Last Edit: September 10, 2024, 01:51:48 pm by Overspeed »
Offline nfmax
« Reply #4 on: September 12, 2024, 07:39:11 pm »
Those errors seem a bit large, unless the simulator is out of specification. What does your F25 read when connected to the simulator? Were you using a 4-wire connection?
Oh, and do you have the key for the calibration enable switch? ;)
« Reply #5 on: September 13, 2024, 05:33:21 am »
Hello
this simulator is basic simulator +/- 0.1 C from the 80's and not a calibrator , the purpose was to show this ASL works and is not '' out of order ''
Asap I have time I will connect a 100 ohm 0.01 % or any other value
Regards
OS
« Last Edit: September 13, 2024, 07:35:08 am by Overspeed »
« Reply #6 on: September 15, 2024, 08:03:42 am »
Hello
I have check with other simulator , I link the Time Electronic PDF , hard to locate  simulator better than 0.1 C except in the high price range as ADR-3204GR Precision Programmable Resistance Box from Alpha Electronics
Vishay propose foil resistor with 0.005 % , I have one in 175 Ohms  I will make a trial
I sale my ASL F250 as it I don't want to spend money in calibration costs
Regards
OS
« Last Edit: September 15, 2024, 08:18:32 am by Overspeed »
Offline bastl_r
« Reply #7 on: September 15, 2024, 05:41:09 pm »
For me, the values seems correct because there are no 4 wire connections.
Offline nfmax
« Reply #8 on: September 15, 2024, 07:50:09 pm »
Certainly, the errors are in the right direction for a two-wire effect. I think the risk might be damage to the reference resistor, or a self-balancing bridge issue. Both would be difficult and/or expensive to fix :(
« Reply #9 on: September 16, 2024, 08:38:02 am »
Hello
Ok I will make the test with a 4 wire resistor to provide the proof of the displayed value
Regards
OS
The following users thanked this post: nfmax
« Reply #10 on: September 16, 2024, 03:07:29 pm »
Hello
Point 1 ) My AOIP simulator is a two wires model but the connection ( rear and front ) are 4 wires and I have respected the wiring , that impossible to read resistor value with only two wires connected as that mandatory to provide current to the resistor and measure the voltage
Point 2 ) The ASL F250 can be ''bespoke'' calibrated and that possible to change calibration regarding the probes you fit on , that clearly explain in the doc in PDF I have linked ( page 13 to 27 in detail )
Point 3) I always respect the measuring equipment .
Point 4 ) I have used this ASL F250 only to measure delta temperature variation so I never change the initial calibration setup
Regards
OS
« Last Edit: September 17, 2024, 07:32:49 am by Overspeed »
« Reply #11 on: October 01, 2024, 10:38:05 am »
Hello
Price reduced to 675 Euro
Regards
OS
