Cleaning up the shop. Got a few handfuls of stuff that somebody else might need or want. I don't have any use for any of it any more.
#1 - Project box, black, phenolic, comes with lid, but no screws
Measurements:
Outside = 4"L x 2.868"W x 1.568"
Inside the walls = 2.646"L x 3.780"W x 1.4"deep
Inside the lid mounting holes = 2.92"L x 2.1"W
Nearest Digikey part number I can find is 705K
Have 100+, $5/each
#2 - Project box lid (not for the box above), black, phenolic, no screws
Measures 5.7"L x 3.2"W at the mounting holes, total 6" x 3.5" at the outside edges
Nearest Digikey part number I can find is 2043K
Have 48, $1/each
#3 - SPST switch, 46202LR SPST, 3A AC, .5A DC, 125V AC/DC, part number is correct.
Have 73, $.50/each
#4 - Long lever switch, BZ-2RW805551-A2, 15A AC, .5A DC, 125-480VAC, part number is correct.
Have 30, $7/each
#5 - CM7382 bulb, part number works.
Have 300+, $.50/each
#6 - P-303-CCT 3 pin male and female connectors, part number seems to be right.
Have 150+, $2/each
#7 - P-306-CCT 6 pin male and female connectors, part number seems to be right.
Have 40+, $2/each
#8 - P-308-CCT 8 pin male only connector (Ya, I know, kinda useless without the female part right?), part number seems to be right.
Have 40+, $1/each
#6-#7-#8 all have solder tabs with holes for wire hookup
Have to add shipping for each of them, UPS or FedEx preferred. Shipping from 58701 if you want to calculate shipping for yourself.
PM me if you want/need some of this...
