I'm selling some old low-noise triax cables which I no longer need for cheap, comparable in price with Chinese non-low-noise cables (careful about the blue ones, they can be twinax
). Shipping from Switzerland by Swiss Post,
all prices excluding shipping and tax. As I'm usually busy during working hours, please allow some delay in reply and shipping. Price negotiation and comments (public or private) welcomed. Most cables are only visually inspected, only continuity and mating are guaranteed, as I don't have the capability to characterize them yet (still planning for a DIY test fixture for my 617 or waiting for one to appear on ebay). I didn't manage to create inline attachments, the filenames should correspond to items, please PM if you want to see more pictures. 1 CHF=1 EUR if preferred.
1. Keithley 6011, 1.5 m (5 ft) of triax cable (SC-22) terminated with a
2-slot triax plug on one end, originally should come with alligator clips, but the alligator clips were replaced with banana jacks by a previous owner. The clear jacket around the red center connector are a bit aged and showing signs of cracking, but it should not matter much as there should be another layer of shielding inside, asking for 40 EUR.
2. Keithley 7025, 3 m (10 ft) low noise triax input cable (SC-22) terminated on one end with
2-slot male triax connector.
Number 1 has some sign of damage on the outer jacket, but the outer jacket is not penetrated and it should still work.
Number 2 has another kind of damage penetrated the outer jacket , but the grounding outer shield is not penetrated and it should also still work.
Asking 35 EUR each or 55 EUR together.
3. Keithley 7024-3, 0.9 m (3 ft) Low noise triax cable (SC-22) with
2-slot male triax connectors on each end. In perfect condition. Asking for 40 EUR.
4. Keithley 237-ALG-2, Low noise triax cable (SC-22) terminated with a
3-slot male triax connector on one end and 3 alligator clips on the other, 2 m (6.6 ft) length. The ground clip is slightly deformed, but should be trivial to bend back and it's still able to clamp firmly, minor cosmetic damage from solvents on the cable to the red clip. Otherwise the cable is in very good condition. More firmly asking for 120 EUR.
Extra 1: Original 2-lug triax connector on my Keithley 617, once suspected to have leakage problem, but may not be the case. For free together with any other purchase, only one.
Extra 2: Suhner triax cables with Suhner BNT connector on both ends. Weird connector that mates with BNC but not usual 2-slot triax, one can use them for the cable for DIY or just use as ordinary BNC cable with better shielding. For free together with any other purchase. One short and one long.
Extra 3: NI CB-68/SCB-68 breakout card and/or box. For free together with any other purchase.
