i'm selling parts of a HP 8922/83220 system, i had to trash it since i badly needed the space and no one wanted it. The system was working, it passed the selftests and i checked it against a R&S CMU so the parts should all be okay (although i haven't tested them individually). Most of the RF parts should be the same stuff that's found in HP spectrum analyzers, so probably mostly useful if you're repairing one of those things.
step attenuators:
-2x HP 33321SC
-1x HP 33321SD
-1x HP 33321SG
65€ each
power splitter/combiners:
-2x Mini-Circuits ZAPD-21-4
18€ each
mixer:
-1x Mini-Circuits ZEM-4300-2
25€
coaxial switch:
-1x HP 8765A opt. 15
30€
attenuators:
-2x Inmet AH18-03H 3dB 18 GHz
-1x HP 0955-0122 10dB 8 GHz
20€ each
OCXO:
-1x OFC OSC92-38
20€
other stuff:
-1x RLC Electronics F-10954 1.8-2 GHz bandpass 20€?
-1 OmniVision LP0615E3Y CRT, according to someone from this forum it should be a drop-in replacement for 8590 series SAs. Without the protective glass you can see slight burn-in, but i've never noticed that when i used it. 70€?
-20ish SMB and SMA to BNC cables
The prices are roughly based on the ebay prices that i could find, but i'm open to suggestions. Stuff is located ~50 km south of Stuttgart if you want to come and test it/pick it up.
