General => Buy/Sell/Wanted => Topic started by: TopLoser on May 24, 2015, 04:15:50 pm
http://uk.farnell.com/pro-signal/psg01319/plug-xlr-free-black-5pole/dp/1280935 (http://uk.farnell.com/pro-signal/psg01319/plug-xlr-free-black-5pole/dp/1280935)
XLR plugs 5 pole 15 for £5
http://uk.farnell.com/lem/htfs-800-p/current-transducer/dp/9135758 (http://uk.farnell.com/lem/htfs-800-p/current-transducer/dp/9135758)
Very handly AC/DC current transducer with onboard signal conditioning £5 each
http://uk.farnell.com/multicomp/spc15386/plug-d-high-density-pcb-78way/dp/1564244 (http://uk.farnell.com/multicomp/spc15386/plug-d-high-density-pcb-78way/dp/1564244)
78 way pcb mount high density D-type plug 10 for £5
http://uk.farnell.com/fct-a-molex-company/f25s1g1/d-sub-receptacle-db-25way/dp/2433303 (http://uk.farnell.com/fct-a-molex-company/f25s1g1/d-sub-receptacle-db-25way/dp/2433303)
25 way pcb mount D-type socket 10 for £5
http://uk.farnell.com/te-connectivity-amp/1658621-1/connector-receptacle-idc-2-54mm/dp/1098498 (http://uk.farnell.com/te-connectivity-amp/1658621-1/connector-receptacle-idc-2-54mm/dp/1098498)
10 way IDC socket 50 for £5
http://uk.farnell.com/harwin/d01-9973242/socket-sil-32way-pc-board/dp/1023035 (http://uk.farnell.com/harwin/d01-9973242/socket-sil-32way-pc-board/dp/1023035)
SIL 32 way turned pin socket 20 for £5
http://uk.farnell.com/vishay-sfernice/eco78csa502w6817/potentiometer-5k/dp/1213262 (http://uk.farnell.com/vishay-sfernice/eco78csa502w6817/potentiometer-5k/dp/1213262)
High quality rotational transducer 1 for £5
http://uk.farnell.com/fischer-elektronik/akk-127/heat-sink-to-3-14-c-w/dp/4621360 (http://uk.farnell.com/fischer-elektronik/akk-127/heat-sink-to-3-14-c-w/dp/4621360)
TO3 heatsinks 10 for £5
http://uk.farnell.com/te-connectivity-amp/0-0881545-2/jumper-with-handle-2-54mm-2way/dp/4218176 (http://uk.farnell.com/te-connectivity-amp/0-0881545-2/jumper-with-handle-2-54mm-2way/dp/4218176)
Those handy little 0.1" jumpers (with handle) bag of 1000 for £10
02 June additions
http://uk.farnell.com/bulgin/mpi002-28-gn/switch-spst-0-05a-24vdc-green/dp/3248902 (http://uk.farnell.com/bulgin/mpi002-28-gn/switch-spst-0-05a-24vdc-green/dp/3248902)
Vandal resistant 1P66 illuminated push buttons 2 for £5
http://uk.farnell.com/multicomp/6601-84-pps-f6/socket-ic-plcc-tube-15-84way/dp/1103863 (http://uk.farnell.com/multicomp/6601-84-pps-f6/socket-ic-plcc-tube-15-84way/dp/1103863)
84 way PLCC sockets 16 for £5
25 July additions
http://uk.farnell.com/vishay/mal209525152e3/cap-alu-elec-1500uf-350v-snap/dp/2342167 (http://uk.farnell.com/vishay/mal209525152e3/cap-alu-elec-1500uf-350v-snap/dp/2342167)
Vishay 1500uF 350V capacitors 2 for £5
15 August additions
http://uk.farnell.com/radiall/r317580000/rf-coaxial-shv-straight-jack-50ohm/dp/4196491 (http://uk.farnell.com/radiall/r317580000/rf-coaxial-shv-straight-jack-50ohm/dp/4196491)
RADIALL SHV Coax bulkhead jacks 50R, 10 for £5
http://uk.farnell.com/thermodisc/g4a01072c/fuse-thermal-72-c-10a-250vac/dp/476560 (http://uk.farnell.com/thermodisc/g4a01072c/fuse-thermal-72-c-10a-250vac/dp/476560)
Microtemp thermal fuse 72 degrees C, 100 for £5
http://uk.farnell.com/multicomp/mcos38008/switch-3a-250vac-spdt-blade/dp/1606956 (http://uk.farnell.com/multicomp/mcos38008/switch-3a-250vac-spdt-blade/dp/1606956)
Cute little Emergency Stop buttons, 5 for £5
http://uk.farnell.com/omron-electronic-components/d3v-16-3c6/microswitch-spst-no-16a-pin/dp/2068257 (http://uk.farnell.com/omron-electronic-components/d3v-16-3c6/microswitch-spst-no-16a-pin/dp/2068257)
Omron microswitches 50 for £5
http://uk.farnell.com/saia-burgess/f5t8/microswitch-plunger/dp/1162613 (http://uk.farnell.com/saia-burgess/f5t8/microswitch-plunger/dp/1162613)
Very cute little microswitches, 20 for £5
http://uk.farnell.com/harting/09-18-564-7914/header-straight-s-latch-64way/dp/1106767 (http://uk.farnell.com/harting/09-18-564-7914/header-straight-s-latch-64way/dp/1106767)
64 way PCB mount header 25 for £5
http://uk.farnell.com/neutrik/nke6s-10/cable-ethercon-cat6-10m/dp/1390161 (http://uk.farnell.com/neutrik/nke6s-10/cable-ethercon-cat6-10m/dp/1390161)
Neutrik 10m ethernet cables £5 each (only 3)
http://www.farnell.com/datasheets/390294.pdf (http://www.farnell.com/datasheets/390294.pdf)
RF Solutions Shadow Tracker GPS stalker thing £20 each (only 2)
http://uk.farnell.com/mentor/1322-1640/748-3mm-blue-hi-brightness-leds/dp/1773120 (http://uk.farnell.com/mentor/1322-1640/748-3mm-blue-hi-brightness-leds/dp/1773120)
M-Tube 750mm blue LED lighting strip 2 for £5 (only 7)
http://uk.farnell.com/multicomp/440005p/battery-connector-pp3-type-1-150mm/dp/1183123 (http://uk.farnell.com/multicomp/440005p/battery-connector-pp3-type-1-150mm/dp/1183123)
9V battery clips pack of 10, 10 packs (100 clips) for £2.50
http://uk.farnell.com/nmb-technologies/3110kl-05w-b50-p00/fan-80mm-24vdc/dp/1012773 (http://uk.farnell.com/nmb-technologies/3110kl-05w-b50-p00/fan-80mm-24vdc/dp/1012773)
Fan 24V 80mmx25mm, 3 for £5
16 August additions
http://uk.farnell.com/tenma/72-10177/oscilloscope-pc-4-ch-60mhz-afg/dp/2146567 (http://uk.farnell.com/tenma/72-10177/oscilloscope-pc-4-ch-60mhz-afg/dp/2146567)
Tenma 72-10177 60MHz 0.2GS/s 4 channel PC based oscilloscope / AWG 16 Mpts, demo stock £150 (1 only)
It's a rebadged Hantek DSO3064A 4in1 Oscilloscope Arbitrary Waveform Generator
http://uk.farnell.com/tenma/72-1016/multimeter-digital-bench-5999/dp/1196432?ost=1196432 (http://uk.farnell.com/tenma/72-1016/multimeter-digital-bench-5999/dp/1196432?ost=1196432)
Tenma 72-1016 bench meter with USB and RS232, boxed as new with leads, demo stock, £50 (1 only)
Lots of most of these items available.
I'll keep adding to this list as and when I can be arsed
Shipping at cost, the more you buy in one go the better it is for everybody involved.
No VAT to be added to any of these prices, I'll sort all that out in my own way!
PM sent
PM Sent
PM sent.
PM...
Received 2 rolls of kynar today,
Thanks very much, great service :D
Reveived my "Random stuff" yesterday :-+
Thanx TL
/Bingo
More stuff added, sold stuff taken away
Items added to the list
couple more items added, still got all the other stuff listed.
Oddments added
bah, just missed the Oki/Metcal fume extractor I think... ;(
A few more bits, mostly test equipment
a box of awesome arrived, thank you!! :-+
Use them irresponsibly please ;)
I also got my µRuler today, now just waiting for the PIs :)
A beautifully packaged box of lab supplies arrived. Thanks Ian! Should keep the lab basics ticking over for a few more months!
>:D > :-/O > :bullshit: > :scared:
Metcal fume extractor a some switches are here.
Tomorrow I will be opening it.
Thanks Ian.
I could have sold that extractor 5 times over, you got a bargain. If it works ;)
Never stop selling, please :)
Quote from: TopLoser on Today at 18:06:55 (https://www.eevblog.com/forum/index.php?topic=48363.msg736168#msg736168)
>Quote from: EdoNork on Today at 14:52:18 (https://www.eevblog.com/forum/index.php?topic=48363.msg736023#msg736023)Metcal fume extractor a some switches are here.
If it doesn't you will have another chance to sell it. >:D
Bundle of goodies arrived earlier this week, thanks.
Mine came today safe and sound as always, thank you Ian.
