in excellent working condition, 19" rack mount.
FEI-ZYFER GPStarplus 565 time frequency system GPSDO, with Motorola oncore M12M GPS, Morion MV201 OCXO inside, no 1024 weeks rollover problem until 2099 (if still live);
please check the second picture for 100s sample (100 times) short term test result, frequecmy peak to peak value, Allan dev and Stardard dev.
please check the datasheet with Google from Fei-Zyfer web site, but I can not find the user guide for GPStarplus 565, only find the GPStarplus 365, operating is same, you can refer it;
the unit is Made in USA of 2014 or 2013;
you can get 10MHz 5MHz or 1MHz for the 3 output port (default setting), also you can set all ports as 10MHz, just by you;
the I/O port of the GPStarplus 565 is a DB25 port, which include 2 RS-232 port combined, one is for control command (3 pins), one is for TOD stream (2 pins).
the auction include:
one used FEI-ZYFER GPStarplus 565-210-01;
one new Trimble GPS mag antenna (with 5 meters cable);
one new USB to RS232 adapter (with 0.5m cable)
one new DB15 connector
one softcopy for how to connect the GPStarplus 565 to a PC.
ship to US 48 states in free.
picture please see here:
https://www.ebay.com/itm/186184531129
