Specification
Infrared image resolution: 384*288
Detector type: uncooled infrared focal plane detection
Temperature measurement range: -20℃ to 400℃
Test measurement accuracy: ±3℃ or ±3%
Lens: 13mm
Working band: 8 – 14μm
Pixel pitch: 17μm
Noise equivalent temperature difference: ≤60mk
Frame rate: 25Hz
Temperature detection: maximum/minimum/center value
Temperature correction: manual/automatic
Temperature output: real-time parallel output
Image enhancement: multi-level detail enhancement
Image correction: shutter correction
Palette: white hot, black hot, rainbow, and many other false color plates
Video recording/photographing: support
Working temperature: -10℃~50℃
Storage temperature: -20℃~60℃
Plug: Type-C (with micro USB adapter)
Power supply voltage: 3.8-5.5V DC
Product size: 49.5*36.1*29.3MM
Weight: 45g
New, acquired to be used in energy projects but canceled.
Perfect for electronics failure detection.
Plug on any Android smartphone UBC C
Support provided, check picture.
Price 600€ including shipping in EU.
