Agreed.
If you want interest, a part number alone is not very enticing. A description and basic specs are a must-have ... and a photo would be nice:
*** DISCLAIMER *** The following is based on a search on the part number providedCoil Voltage:
12VDCContact Configuration:
DPDTContact Current:
1AProduct Range: EA2
Relay Mounting: Through Hole
Coil Type: Non Latching
Relay Terminals: Solder
Contact Voltage VAC: 250V
Contact Voltage VDC: 220V
Contact Material: Silver Alloy
Coil Resistance: 1.028kohm
