Author Topic: FS: PREMA 5017SC 7.5 digit DMM (location Germany near Heidelberg)  (Read 2843 times)
Offline quarks
As I want  to make room in my lab I can offer:
Prema 5017 in very good fully working condition
comes with scanner card (option 3110) for max. of 80 channels
it had full maintenance and fresh calibration by PREMA Germany (the original manufacturer) in May 2018
comes with full calibration data and original packaging
picking it up is possible
if it needs to be shipped you have to pay for insured shipping
weight is over 5kg
Voltage is 230V (switchable to 115V)
If anyone is interested please contact me via PM
« Last Edit: January 19, 2020, 02:51:52 pm by quarks »
Offline Zucca
  • EE meid in Itali
ON SALE: HP 6642A 20V 10A
Offline The E Engineer
Re: FS: PREMA 5017SC 7.5 digit DMM (location Germany)
« Reply #2 on: October 17, 2018, 01:34:20 pm »
price and city?
Offline quarks
« Reply #3 on: October 18, 2018, 09:03:30 am »
here is a picture
for any details send me a PM
Offline branadic
« Reply #4 on: November 01, 2018, 06:29:37 pm »
if you don't want bluescreens on your meter, this one is the perfect choice MADE IN GERMANY and for sure well aged, thus it performs much better then spec'ed.
Advantages:
- illuminated LCD display --> no fading like VFDs
- it uses standard components --> in case easy to repair
- no sheet metal case, but massive aluminium corpus --> no corrosion
- no fan inside --> silent operation
Description: PREMA 5017 SC, 7 1/2 digit multimeter
- functions: Vdc, Vac, Idc, Iac, R, T, f, ...
- high resolution: 10nV, 10µOhm, 100pA, 0,001ºC
- stability: 24-hour 4ppm, 1-year 20ppm
- math functions: offset, %-deviation, ratio, ax+b
- display format: ±30.100.000 (plus an extra digit when using math function by hiding leading zeros)
- measurement period: 20ms ... 100s
- temperature measurement with Pt10, Pt25, Pt100, Pt500, Pt1000
- interfaces: IEEE488 and RS232
- build in multiplexer/scanner with 80x channels common ground / 40x channels 2W / 20x channel 4W
I highly recommend this meter.
-branadic-
Metrology Meeting 2020 on 06.06.2020
Offline coromonadalix
« Reply #5 on: November 03, 2018, 03:53:45 pm »
Received an +/- 800 euro price, but exchanges rates are killing me.
« Last Edit: November 03, 2018, 03:58:47 pm by coromonadalix »
Offline quarks
« Reply #6 on: November 04, 2018, 08:59:43 am »
because I was asked to show more photos, here are rear, side, top and bottom views
Offline quarks
« Reply #7 on: January 11, 2020, 02:12:50 pm »
as I still have two of these, please contact me via PM if you are interested
« Last Edit: January 13, 2020, 02:38:19 pm by quarks »
Offline quarks
Re: FS: PREMA 5017SC 7.5 digit DMM (location Germany near Heidelberg)
« Reply #8 on: January 15, 2020, 10:38:32 am »
because I was asked where I am located, I added  (location Germany near Heidelberg) in the subject
