I have some of these devices available for free plus shipping cost.
Lantronix XPort embedded serial server.
Part number: XP1001000-05SR (or similar).
XPort devices are a current production product.
You can get all the technical info from the Lantronix web site.
I use an XPort device on my AVT-853 product. There are times I remove it from a board for customer specific modification.
All the devices I am giving away are removals. They were brand new, usually only powered on once - to set the parameters and test the board. All of them work.
(I can not, in good conscience, use them on a new board. Hence, I have a bunch.)
Here's what's available for the asking. (Updated 1000 hrs ET, 5 March.)
qty. 4 - one small shield tab is broken off each unit. It does not affect operation. Heat transfer is possibly affected a little, but for most applications, it's irrelevant. - All gone.
qty. xxx - perfectly good. - All gone.
qty. 1 - with wires attached and modified for prototyping work. - Gone.
You can respond to this posting or write me directly: MRILEY@AVT-HQ.COM
Thanks to everyone for their interest.
Good luck, Mike.
