Author Topic: Reels Needed  (Read 770 times)
Offline hp23Topic starter
Reels Needed
« on: April 16, 2024, 05:48:38 pm »
All,
Obviously the manufacturer is not essential for the discrete components. Does anyone in the UK have partial or full reels of the following:
Yageo   PE2010FKE070R02L   RES 0.02 OHM 1% 1/2W 2010
Rohm Semiconductor   PMR50HZPJV4L0   RES 0.004 OHM 5% 1W 2010
Samsung Electro-Mechanics   CL21B104KBCNNNC   CAP CER 0.1UF 50V X7R 0805
Murata Electronics   GRM21BR71H474KA88L   CAP CER 0.47UF 50V X7R 0805
Wurth Elekronik   7443551600   FIXED IND 6UH 12A 8.4 MOHM SMD
Wurth Elekronik   7443550320   FIXED IND 3.2UH 16A 5.3 MOHM SMD
ST Micro Electronics   ST730M33R   IC REG LINEAR 3.3V 300MA SOT23-5
Analog Devices / Maxim Integrated   DS2485Q+T   ADVANCED 1-WIRE MASTER WITH MEMO
Yageo   RC0805JR-070RL   RES 0 OHM JUMPER 1/8W 0805
Analog Devices Inc   LT8391EFE#PBF   IC LED DRIVER CTRLR PWM 28TSSOP
Analog Devices / Maxim Integrated   MAX3221EEUE+   IC TRANSCEIVER FULL 1/1 16TSSOP
Chemi-Con   HHXC630ARA330MHA0G   CAP ALUM HYB 33UF 20% 63V SMD
Nichicon   GYC1H470MCQ1GS   CAP ALUM HYB 47UF 20% 50V SMD
Vishay Sprague   293D104X9035A2TE3   CAP TANT 0.1UF 10% 35V 1206
Cheers,
Pete
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Reels Needed
« Reply #1 on: April 17, 2024, 05:41:57 am »
Silly question, why not use Digi-Key?
Offline mariush
Re: Reels Needed
« Reply #2 on: April 17, 2024, 06:59:22 am »
Shipped from EU, so should get quite fast to UK.
CL21B104KBCNNNC - https://www.tme.eu/gb/details/cl21b104kbcnnnc/mlcc-smd-capacitors/samsung/
Capacitor: ceramic; MLCC; 100nF; 50V; X7R; ±10%; SMD; 0805
521 300 pcs in stock
Prepack information
Reel = 4000 pcs
Cardboard = 20000 pcs
Cardboard = 40000 pcs
potential alternative
CC0805KRX7R9BB104 YAGEO - https://www.tme.eu/gb/details/cc0805krx7r9104/mlcc-smd-capacitors/yageo/cc0805krx7r9bb104/
Manufacturer part number:
CC0805KRX7R9BB104
1 646 799
pcs in stock
Prepack information
Reel = 4000 pcs
Murata Electronics   GRM21BR71H474KA88L   CAP CER 0.47UF 50V X7R 0805   - https://www.tme.eu/gb/details/grm21br71h474ka88l/mlcc-smd-capacitors/murata/
Vishay Sprague   293D104X9035A2TE3   CAP TANT 0.1UF 10% 35V 1206 - almost half a reel (988 out of 2k) here : https://www.tme.eu/gb/details/293d104x9035a2te3/smd-tantalum-capacitors/vishay/
No, but potential alternatives
0805S8J0000T5E   Resistor: thick film; SMD; 0805; 0Ω; 0.125W; -55÷125°C  (165k in stock) - https://www.tme.eu/gb/details/0805s8j0000t5e/smd-resistors/royal-ohm/
0805W8J0000T5E  Resistor: thick film; SMD; 0805; 0Ω; 125mW; ±5%; -55÷155°C (170k in stock) - https://www.tme.eu/gb/details/0805w8j0000t5e/smd-resistors/royal-ohm/
CS10FTJTR020 VIKING   -  https://www.tme.eu/gb/details/cs2010-0r02-1%25-hp/smd-resistors/viking/cs10ftjtr020/
Resistor: thick film; sensing; SMD; 2010; 20mΩ; 1W; ±1%; -55÷155°C
Manufacturer part number: CS10FTJTR020
Reels of 1000  / 2000 / 4000 , 2400 in stock as I write
WW20NR020FTL WALSIN - https://www.tme.eu/gb/details/ww20nr020ftl/smd-resistors/walsin/  - 1000+ in stock, 4000 per reel.
Resistor: power metal; sensing; SMD; 2010; 20mΩ; 1W; ±1%; -55÷155°C
Manufacturer part number: WW20NR020FTL
For the resistors, if you search you'll find similar specc'ed
Re: Reels Needed
« Reply #3 on: April 17, 2024, 10:01:52 am »
It's not a silly question. There are two reasons.
(1) I'll grab stuff before it ends up in a landfill. Feels a bit more sustainable.
(2) It'll be a little cheaper as we're a startup.
If there's no surplus available, then I'll be going to digikey.
Pete
